Golf 7 Multifunction retrofit
   #61
Nuje
Canada
C?ID=120875
Hmmm....so it *should* work.
Thanks for the reply, DV52!
My problem, I guess, then, is that I can't get 16-Steering Wheel-CODING to accept my coding change. I'm sure I tried every option in the drop-down (in your example, changing 0100 to 6100; mine stock is 0410 - I tried changing it to 6410 numerous times
but every time I got "Coding not accepted" or "rejected" or wording to that effect.
Is there a "Security Access" that I need to access / re-code that module?
   #63
Nuje
Canada
C?ID=120875
Auto-scan:
2016.12.28. AUTO-SCAN
VIN: 3VWCA7AUXFMxxxxxx
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 2B 42 44 47 52 55 5F
Address 01: Engine  (CRUA J623)	Labels: 04-01.lbl
	Part No SW: 04L 906 021 D	HW: 04L 907 309
	Component: R4 2,0L EDC   H23 8278
	Revision: 85H23---
	Coding: 011D0012832410081000
	Shop #: WSC 00066 790 00221
	ASAM Dataset: EV_ECM20TDI01104L906021D 001013
	ROD: N/A
	VCID: 260F659BCD38852CB87FA4DB12-8073
	No ASAM data for: "EV_ECM20TDI01104L906021D"
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Part No SW: 0D9 300 041 N	HW: 02E 927 770 AQ
	Component: DQ250-6F MQB  H53 4506
	Revision: 03253104
	ROD: N/A
	VCID: 23097C8FBE0A7004DF6185B729-8076
	No ASAM data for: "EV_TCMDQ250021"
Address 03: ABS Brakes  (J104)	Labels: None
	Part No SW: 3Q0 907 379 P	HW: 3Q0 907 379 C
	Revision: 00000000
	Coding: 04FA6AA12420096C0079020981CC2520562490004081A4B210630050C002
	Shop #: WSC 01383 790 50316
	ROD: N/A
	VCID: 47D1C81F6A727C2463C911477D-8012
	No ASAM data for: "EV_Brake1UDSContiMK100ESP"
016401 - ROD - Unknown faultcode
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 A	HW: 5Q0 959 435
	Revision: 00021000
	Coding: 030C0C
	ROD: N/A
	VCID: 3A37A1EB298011CCEC4780AB16-806F
	No ASAM data for: "EV_KessyHellaMQBAB"
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5GM 907 044 A	HW: 5GM 907 044 A
	Revision: 00001K01
	Coding: 02020124200100010005000000101400
	ROD: N/A
	VCID: 42C7D90B4150590CB497D80BBE-8017
	No ASAM data for: "EV_ACClimaBHBVW37X"
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.lbl
	Part No SW: 5Q0 937 087 R	HW: 5Q0 937 087 R
	Revision: --------
	Coding: 00511B464041A2E949E44000091407001800000000000000000000000000
	Shop #: WSC 00066 790 07031
	ROD: N/A
	VCID: 4AD7F12B7960814C7CE7306B26-801F
	No ASAM data for: "EV_BodyContrModul1UDSBosc"
	Subsystem 1 - 	Part No SW: 5GM-955-119	Labels: 5Qx-955-119-V1.clb
	Component: MÝ
	Subsystem 2 -
	Subsystem 3 - 	Component:
	Subsystem 4 - 	Component:
	Subsystem 5 -
534549 - ROD - Unknown faultcode
329480 - ROD - Unknown faultcode
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 D	HW: 5Q0 907 572 D
	Coding: 01001000280438
	Shop #: WSC 00066 790 00194
	ROD: N/A
	VCID: 3833BBE3178C03DC1A336AB338-806D
	No ASAM data for: "EV_ACCMRRBoschVW372"
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 5Q0 959 655 T	HW: 5Q0 959 655 T
	ROD: N/A
	VCID: 51E5E6479436B2943D2D7FDFC3-8004
	No ASAM data for: "EV_AirbaVW20SMEVW37X"
	Subsystem 1 - 	Part No SW: 4M0-959-339-B
	Component: 016
	Subsystem 2 - 	Component: ---
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
Address 16: Steering wheel  (J524)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 521 AT	HW: 5Q0 953 569 A
	Revision: FF032032
	Coding: 0410
	ROD: N/A
	VCID: 844B9F139BC4173C462BAE2354-80D1
	No ASAM data for: "EV_SMLSVALEOMQB"
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5G1 920 741	HW: 5G1 920 741
	Component: KOMBI         243 4270
	Coding: 0BA4121929808809028868011000000000000000
	ROD: N/A
	VCID: E48BBF937B84B73CE6EBCEA374-80B1
	No ASAM data for: "EV_DashBoardVDDMQBAB"
Address 19: CAN Gateway  (J533)	Labels: 5Q0-907-530-V1.clb
	Part No SW: 5Q0 907 530 AC	HW: 5Q0 907 530 M
	Revision: --------
	Coding: 0901000800087300EF00020A1C0F00000001050000000000000000000000
	Shop #: WSC 00066 790 07026
	ROD: N/A
	VCID: 72A749CB3170A98CE477E84B2E-8027
	No ASAM data for: "EV_GatewConti"
	Subsystem 1 -
	Subsystem 2 - 	Component: (ÿÿ
	Subsystem 3 -
131632 - ROD - Unknown faultcode
Address 20: High Beam Assist.  (J844)	Labels: 8X0-857-511.clb
	Part No SW: 5G0 857 511 D	HW: 5G0 857 511
	Component: FLA           H04 0002
	Revision: AA001001
	Coding: 02018864727264565625393E01
	ASAM Dataset: EV_HighBeamAssisAU37X 001009
	ROD: N/A
	VCID: 2B1994AFD6DAB84467B1DD17D1-807E
	No ASAM data for: "EV_HighBeamAssisAU37X"
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 5D00000000000000
	ROD: N/A
	VCID: 342B8FD30BE4E7BC360B3E6344-8061
	No ASAM data for: "EV_ELVMarquMQB"
Address 42: Door Elect, Driver  (J386)	Labels: 5QX-959-X93-42.clb
	Part No SW: 5Q0 959 593 B	HW: 5Q0 959 593 B
	Coding: 003A13200000040000000000
	ROD: N/A
	VCID: 40C3D3034F5C4B1CA283C213A0-8015
	No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 R	HW: 5Q0 909 144 R
	Component: EPS_MQB_ZFLS  126 1061
	Coding: 0102
	ROD: N/A
	VCID: 43C9DC0F5E4A5004BFA1E53789-8016
	No ASAM data for: "EV_SteerAssisMQB"
Address 47: Sound System  (J525)	Labels: None
	Part No SW: 5G0 035 456	HW: 5G0 035 456
	Component: MIB_lite_amp  H40 0060
	Coding: 22000000AAAAAA0000
	ASAM Dataset: EV_AMPMst11CALPI 001006
	ROD: N/A
	VCID: E389BC8F7E8AB0041FE1C5B769-80B6
	No ASAM data for: "EV_AMPMst11CALPI"
Address 52: Door Elect, Pass.  (J387)	Labels: 5QX-959-X92-52.clb
	Part No SW: 5Q0 959 592 B	HW: 5Q0 959 592 B
	ROD: N/A
	VCID: 3FC1D0FF32A234E4DB79B9E7D5-806A
	No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Part No SW: 7P6 907 357 D	HW: 7P6 907 357 A
	Revision: --------
	Coding: 060A00010B000400
	ROD: N/A
	No ASAM data for: "EV_HeadlRegulVWAFSMQB"
	Subsystem 1 - 	Part No SW: 5N0-941-329	Labels: 3D0-941-329.clb
	Component: .
Address 5F: Information Electr.  (J794)	Labels: 5G-5f.lbl
	Part No SW: 5G0 035 876	HW: 5G0 035 876
	Component: MU-S-NS-US    014 0645
	Coding: 027302020000000021220002001800001F02023401000101C6
	ROD: N/A
	VCID: E995AEA79CA6EA54D51D07FF3B-80BC
	No ASAM data for: "EV_MUStd4CPASE"
	Subsystem 1 - 	Part No SW: 5G0-919-605-K
	Component: ABT_Std_Nav
	Subsystem 2 -
000020 - ROD - Unknown faultcode
End-------------------------(Elapsed Time: 03:07)--------------------------
   #64
hmmm.......... No, I didn't need a SA to make the changes on my module. I don't have access to ETKA, so I don't know if your "AT" version firmware supports ACC (my firmware is E version). If you can change another Bit in Byte 0 in your module (try Bit 2 - rear wiper installed) and you can't change Bit 4-6, perhaps this might be an explanation - just guessing?
   #65
Spacewalker
Poland
C?ID=159607
Seems is supporting ELECTRONIC CCS via MFSW only
But better is to use google to find this same SWCM and compare coding
ETKA not always right
   #66
Spacewaker: Thanks - that's odd then! Found lots of 5Q0 953 521 AT examples on the net, but they ALL had code-strings of 0410, or 0400
   #67
Nuje
Canada
C?ID=120875
The "AT" firmware (I can see the reference to it in the auto-scan): Is that the button hardware itself? Or is that a module located somewhere in the bowels under the dash (or elsewhere)?
(Just wondering what my "upgrade" options might be should it come to that...)
   #68
Nuje: It's the thing that I have labelled "Steering Wheel module" in the picture of my test bench below (which also contains the coil)
In its "basic form", it breaks down to just the thing in the picture below
Nuje
Canada
C?ID=120875
That, my friend, is an impressive setup!
(Thanks for clarifying.)
I'd hesitate to spend on a different module without knowing if the ECU/BCM will accept it...and then get caught in a parts chase.
