Hello
I'd like to activate TPMS on wife's touran, WVGZZZ1TZ9W04xxxx.
I've read some threads how to, so I decided to guess, and I'v done:
Change coding in 46, tried both TPMS/65 and TPMS II/4C
change coding in 03, 0021190,to,0004806
change coding in 19,
Address 19,1K0 907 530 Q,recoded (Long Coding),from,EDA07F060002028002,to,EDB07F060002028002,
Address 46,1K0 959 433 BT,recoded (Long Coding),from,8190020851030C7F2D06840570084FC6F0FC00,to,8190020851030C7F2D06840570084FC6F0DC00,
Address 03,1K0 614 517 AC,recoded (Short coding),from,0021190,to,0004806
CAN gateway reported
03109 - Tire Pressure Monitoring Control Module 2 (J793)
With new coding, at switch ignition off/on, TPMS led turns on for few seconds in instrument cluster, with original coding it does not.
ABS controller has some data regarding TPMS, channels 016-018
21:06:04 Group 016: Tire Pressure Monitoring (TPMS) I
0 km Mileage at last Warning
N/A
N/A
N/A
21:06:04 Group 017: Tire Pressure Monitoring (TPMS) II
0 km Mileage at last Initialization
N/A
N/A
N/A
21:06:04 Group 018: Tire Pressure Monitoring (TPMS) III
Not Oper. TPMS Button Status (E492)
Activated Parking Brake Status
N/A
N/A
Q, should I install reset button or reset could be done via MFD?
Log of whole playing is attached, auto-scan as well.
What am I missing/doing wrong? CAN gateway...
Thanks, Arne
P.S.
Meanwhile I've changed also Coming/leaving home.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Thanks, Arne
P.S.
Friday,03,November,2017,20:18:07:38184
VCDS Version: 17.8.0.1 (x64)
VIN: WVGZZZ1TZ9W04xxxx License Plate:
Mileage: 95560km-59378mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ9W04xxxx Mileage: 95560km-59378miles
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 C HW: 03C 906 032 C
Component: MED17.5.1 G 6461
Revision: 96H07--- Serial number: VWX7Z0H73NL0PF
Coding: 0000075
Shop #: WSC 07105 298 67268
VCID: 1D3A30ACC424E6AE81-8048
Part No SW: 02E 300 051 N HW: 02E 927 770 AM
Component: GSG DSG AG6 511 1952
Revision: 05351112 Serial number: 00001011100269
Shop #: WSC 04940 001 00001
VCID: 1E3837A0C922FDB698-804A
Address 03: ABS Brakes Labels: 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0021190
Shop #: WSC 01324 785 00200
VCID: 68D451785BE6F30622-803C
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 69D2547C40ECCA0E3D-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000008850236
Coding: 018F8F2100040F0047120C000000000000197F075C00012C000000000000
VCID: 336EF61452A040DE47-8066
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 120808 021 0501
Coding: 00038805
Shop #: WSC 01324
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 C HW: 1T0 919 475
Component: PARKHILFE PLA H07 0009
Revision: -------- Serial number: 61730822403808
Coding: 100101
VCID: 3B7EDE34BAF0889E9F-806E
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D0A9HH3
Coding: 0012340
Shop #: WSC 01324 020 00200
VCID: 3668CF0041D255F660-8062
Subsystem 1 - Serial number: 6332QSME3E0016289
Subsystem 2 - Serial number: 6342QSME58020C3CI
Subsystem 3 - Serial number: 6352QSME7C543811I
Subsystem 4 - Serial number: 6362QSME7F36185F
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0012122
VCID: 78F401380B466386B2-802C
Component: E0221 002 0010
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Part No SW: 1T0 920 874 HW: 1T0 920 874
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H73NL0PF
Coding: 0007103
Shop #: WSC 02343 002 1048576
VCID: 73EE3614122000DE87-8026
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 210808F1001222
Coding: EDA07F060002028002
VCID: 356AC80C5CD45EEE69-8060
Component: IMMO VDD 2416
Part No SW: 1T0 959 701 M HW: 1T0 959 701 M
Component: Tuer-SG 008 2007
Coding: 0000181
VCID: 4182ACDC181CE24EC5-8014
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A50EB70856A0116F4-807E
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 8190020851030C7F2D06840570084FC6F0FC00
VCID: 030E66D44280305E97-8056
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 01324
Subsystem 6 - Part No: 1K0 951 605 C
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No SW: 1T0 959 702 M HW: 1T0 959 702 M
Coding: 0000181
VCID: 4280A3D01D1AF956DC-8016
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3H3346090
Coding: 0500040004
VCID: 65CA584C6CF4EE6E19-8030
Part No SW: 1K0 959 703 AK HW: 1K0 959 703 AK
Component: Tuer-SG 007 2002
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 79F2043C304C7A8ECD-802C
Part No SW: 1K0 959 704 AK HW: 1K0 959 704 AK
Coding: 0000144
VCID: 7AF01B30354A7196C4-802E
End-------------------------(Elapsed Time: 01:54)--------------------------
Address 09,3C8 937 049 E,recoded (Long Coding),from,018F8F2100040F0047120C000000000000197F075C00012C000000000000,to,818F8F2100040F0047120C000000000000197F075C00012C000000000000,(01324/785/00200),
Address 19,1K0 907 530 Q,recoded (Long Coding),from,EDA07F060002028002,to,EDB07F060002028002,(07105/298/67268),
Address 46,1K0 959 433 BT,recoded (Long Coding),from,8190020851030C7F2D06840570084FC6F0FC00,to,8190020851030C7F2D06840570084FC6F0DC00,(01324/785/00200),
Address 03,1K0 614 517 AC,recoded (Short coding),from,0021190,to,0004806,(01324/785/00200),
Address 19,1K0 907 530 Q,recoded (Long Coding),from,EDB07F060002028002,to,EDA07F070002028002,(07105/298/67268),
Address 19: DTCs cleared
Address 19,1K0 907 530 Q,recoded (Long Coding),from,EDA07F070002028002,to,EDB07F060002028002,(07105/298/67268),
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 56 62 72
4C-Tire Pressure II -- Status: Cannot be reached 1100
Coding: 0000075
Revision: 00H14001
Coding: 0004806
Coding: 818F8F2100040F0047120C000000000000197F075C00012C000000000000
Coding: 00038805
Shop #: WSC 01324
Coding: 100101
Coding: 0012340
Coding: 0012122
00576 - Terminal 15
Coding: 0007103
Coding: EDB07F060002028002
Reset counter: 87
Mileage: 95563 km
Time: 20:42:28
Coding: 0000181
Revision: 00H15000
Coding: 8190020851030C7F2D06840570084FC6F0DC00
Coding: 00000000
Shop #: WSC 01324
Address 4C: Tire Pressure II
Coding: 0000181
Coding: 0500040004
Coding: 0000144
Coding: 0000144
End-------------------------(Elapsed Time: 01:55)--------------------------
Address 03: ABS Brakes (1K0 614 517 AC)
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Address 03,1K0 614 517 AC,recoded (Short coding),from,0004806,to,0021190,(01324/785/00200),
Address 46,1K0 959 433 BT,recoded (Long Coding),from,8190020851030C7F2D06840570084FC6F0DC00,to,8190020851030C7F2D06840570084FC6F0FC00,(01324/785/00200),
Address 19,1K0 907 530 Q,recoded (Long Coding),from,EDB07F060002028002,to,EDA07F060002028002,(07105/298/67268),
Address 16: DTCs cleared
Coding: 0000075
Revision: 00H14001
Coding: 0021190
Coding: 00038805
Shop #: WSC 01324
Coding: 100101
Coding: 0012340
Coding: 0012122
Coding: 0007103
Coding: 0000181
Revision: 00H15000
Coding: 00000000
Shop #: WSC 01324
Coding: 0000181
Coding: 0500040004
Coding: 0000144
Coding: 0000144
End-------------------------(Elapsed Time: 01:49)--------------------------
Address 09,3C8 937 049 E,recoded (Long Coding),from,818F8F2100040F0047120C000000000000197F075C00012C000000000000,to,A18F8F2100040F0047120C000000000000197F075C00012C000000000000,(01324/785/00200),
