- Oct 29, 2017
- 17
- 5
- Newport, Wales
- C?ID=174908
Hi
I have retrofitted the cupholder lights to my Jan 2014 Audi A3 8V and would like to get the level of brightness controlled by the MMI as per the OEM interior light pack. I have followed the official wiring diagram and wired the positive to pin 3 of the 73pin C connector of the BCM and the negative to a ground point and coded using my genuine VCDS cable as per entries I can find online.
All wiring has been checked but there is no light output. I checked voltage across the pins and it only rises to 0.6v when the lights are turned on, dropping back to zero on lights out. So I think I have a coding issue but as there are so many possible adaptions for the BCM, I think I need to see an adaption map for 09 for an eqivalent car with the light pack installed. Is there anyone who has the ILP installed and an admap they would be willing to share please?
Thanks in advance
Adsm
Thanks in advance
Adsm
