Retrofitting cupholder light to Jan 2014 Audi A3 8V
adamal
Newport, Wales
C?ID=174908
Hi
I have retrofitted the cupholder lights to my Jan 2014 Audi A3 8V and would like to get the level of brightness controlled by the MMI as per the OEM interior light pack. I have followed the official wiring diagram and wired the positive to pin 3 of the 73pin C connector of the BCM and the negative to a ground point and coded using my genuine VCDS cable as per entries I can find online.
All wiring has been checked but there is no light output. I checked voltage across the pins and it only rises to 0.6v when the lights are turned on, dropping back to zero on lights out. So I think I have a coding issue but as there are so many possible adaptions for the BCM, I think I need to see an adaption map for 09 for an eqivalent car with the light pack installed. Is there anyone who has the ILP installed and an admap they would be willing to share please?
Thanks in advance
Adsm
hadez16
C?ID=289891
First of all, do post an adaptation map of your BCM please, and a full Auto-Scan.
^^^ hmm......... I assume that the cupholder lighting is coincident with the footwell lighting. According to a BCM admap that I have for a 2017 A3 in my database, the Leuchte-set for pin 3, socket C is Leuchte17TFL R BLK SRB3TFL R BLK SR KC3. This is the Leutche-set that controls the rear right turn signal.
So, if I'm correct in my assumption, the Leuchte-set for the footwell lighting, is Leuchte30FR LC72, or the 19 x adaptation channels that control pin #72 on socket C. This is the Leuchte-set that is controlled in the MMI (I think).
Hence my question: I don't have access to a WD for an A3 8V -but how certain are you about pin#3 on socket C?
hadez16
C?ID=289891
Yeah, good point. I double-checked an 09 Adpmap of a 2014 8V and Pin 3 of connector C seems to be the rear turning signal!?!?
(If all this wiring pin stuff in the adaptation map is right...)
hadez16: On MQB platform vehicles, the link between the Leutche-set naming convention and the pin/socket numbers on the BCM is factual!!
adamal
Newport, Wales
C?ID=174908
Thank you for the responses. I am away with work this week but will post scans as soon as I get home.
I have spent ages looking at that leuchte channel thinking it is related but just couldn't get my head around it and I agree its supposed to be related to the turn signal. Its different wiring for a car with halogens vs bi xenons though and my use of pin 3 is based on inspection of the official wiring diagrams for a car with halogen lights. I will post this too but its number 61/4 if you also have access.
My understanding is the cupholder is supposed to work independently of the footwell lights and should be controlled separately in tbe MMI.
Regards
Adam
hadez16
C?ID=289891
Oh, you're right!
Pin 3 of connector C is Ambient Light in a halogen car.
I had a look in only Xenon Adpmaps ;)
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Ambientelicht 2
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,46 - LED Kleinleistung
This could be enough to get it to work regarding adaptations.
Coding of BCM:
Activate Bit 2 in Byte 17
adamal
Newport, Wales
C?ID=174908
Thanks but that's what I tried with no joy. I will post scans and admap later tonight.
Adam
adamal
Newport, Wales
C?ID=174908
Here is the admap for 09 BCM:
Elapsed Time: 02:09
;SW:5Q0-937-084-AD   HW:5Q0-937-084-AD ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M+  H16 0124	 Coding:07140846C24102FD03844004B31407A8000C000000000000000000000000
;EV_BCMCONTI	12001	EV_BCMBOSCH_012.rod
;Sunday	29	October
;VCDS Version: Release 17.8.0 (x64)  Data version: 20170721 DS276.2
;VCID: 7AFDB7DEFDFC5496C4-802E
IDE00001-ENG99061-Production mode-Access control	not active 	3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
IDE00002-Transport mode	active 	1
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	active 	9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	8	9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active 	9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	not active 	9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	active 	9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating 	9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	active 	9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	1000 ms	9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	1000 ms	9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	1000 ms	9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	1000 ms	9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	1000 ms	9
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active 	9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	active 	9
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active 	9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active 	9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	9
IDE01550-Service position	133.197670 °	2
IDE02152-Characteristics in production mode	2000 ms	1
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	Yes 	2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active 	2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	Yes 	2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal 	2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	2
IDE02332-Deactivate production mode	0	3
IDE02488-DWA Interior monitoring	100%	1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	active 	3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	3
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active 	3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	3 s	3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	1 s	3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	5 s	3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	5 s	3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	not active 	3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active 	3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel	not enabled 	4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	89%	4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	89%	4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	89%	4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	Enabled 	4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed 	4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-0.25 °	13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	OFF 	13
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	13
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	90 °	13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	30 °	13
IDE03638-ENG116676-static AFS light-Upper speed threshold	32.0 km/h	13
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R48 	13
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separate 	3
IDE04923-ENG115774-Turn signal control-Komfortblinken	active 	3
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	3	3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	SMLS 	3
IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled 	3
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active 	3
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	3
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.25%	3
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	1.00%	3
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h	14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h	14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	separate 	14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active 	14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig 	14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung aktivieren 	14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	60 km/h	14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided 	14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active 	14
IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus	active 	14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	active 	14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active 	14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	not active 	14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min	14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Fog light 	5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	automatic 	5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door 	5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	16	5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	2	5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled 	5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	20 s	5
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	60 s	5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active 	5
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active 	5
IDE04927-IDE01446-Window heater-Running time of heated front window	600 s	8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung	35.0 °C	8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung	35.0 °C	8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s	8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	Default 	8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	1
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	driver door contact thatcham 	1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme 	1
IDE04928-ENG148904-Anti-theft device-Überwachung Innenentriegelungshebel	active 	1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active 	4
IDE05142-ENG116621-Access control-automatisches Entriegeln	active 	4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active 	4
IDE05142-ENG116706-Access control-Autounlock NAR	not active 	4
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	not active 	4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active 	4
IDE05142-ENG115722-Access control-Electrical rear lid	not active 	4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active 	4
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active 	4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active 	4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable 	4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	active 	4
IDE05142-ENG115755-Access control-Notschließfunktion	not active 	4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	4
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	4
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always 	4
IDE05142-ENG148954-Access control-Softtouch-Betätigung senden	nur wenn freigeben 	4
IDE05142-ENG115758-Access control-Valet Parking	not active 	4
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active 	4
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active 	4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active 	4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active 	4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung 	4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	active 	4
IDE05144-Read parameter address	00 00 00 	3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34	560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E 	560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10	0	560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11	0	560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12	38	560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13	42	560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0	560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0	560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0	560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0	560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18	8	560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19	18	560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2	35	560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20	10	560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21	20	560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29	560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A 	560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A 	560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28	560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26	11	560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27	21	560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B 	560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B 	560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3	3F 	560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0	560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0	560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0	560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0	560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0	560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A 	560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44	560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36	560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40	560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8	37	560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9	41	560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize 	560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize 	560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize 	560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize 	560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize 	560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize 	560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize 	560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize 	560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize 	560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize 	560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize 	560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize 	560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize 	560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	maximize 	560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	maximize 	560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize 	560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize 	560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize 	560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize 	560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize 	560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize 	560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize 	560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize 	560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize 	560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize 	560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize 	560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize 	560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize 	560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize 	560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	maximize 	560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	maximize 	560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize 	560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize 	560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize 	560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize 	560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize 	560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize 	560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize 	560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize 	560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize 	560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize 	560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize 	560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize 	560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize 	560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize 	560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize 	560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize 	560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize 	560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize 	560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize 	560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize 	560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize 	560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize 	560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize 	560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize 	560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize 	560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize 	560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize 	560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize 	560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize 	560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize 	560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize 	560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize 	560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize 	560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	minimize 	560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	minimize 	560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize 	560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize 	560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize 	560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize 	560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize 	560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize 	560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize 	560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize 	560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize 	560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize 	560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize 	560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize 	560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize 	560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize 	560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize 	560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize 	560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize 	560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize 	560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize 	560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize 	560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize 	560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize 	560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize 	560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize 	560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize 	560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize 	560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize 	560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize 	560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize 	560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize 	560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize 	560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize 	560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize 	560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize 	560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize 	560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize 	560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize 	560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize 	560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize 	560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100	560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100	560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10	0	560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11	0	560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12	100	560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13	100	560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0	560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0	560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16	100	560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17	100	560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18	100	560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19	100	560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100	560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100	560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100	560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100	560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23	27	560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24	27	560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25	100	560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26	100	560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27	100	560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28	100	560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29	100	560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100	560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30	100	560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31	100	560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32	100	560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33	100	560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34	100	560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4	100	560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5	100	560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6	100	560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7	100	560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8	100	560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9	100	560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0	560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0	560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0	560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0	560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12	100	560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13	100	560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0	560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0	560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0	560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0	560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0	560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0	560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2	0	560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20	25	560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21	25	560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0	560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23	0	560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24	0	560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0	560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0	560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0	560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0	560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0	560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3	0	560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0	560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0	560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0	560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0	560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0	560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4	0	560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5	0	560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0	560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0	560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0	560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0	560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0	560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0	560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0	560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0	560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0	560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0	560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0	560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0	560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0	560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0	560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0	560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0	560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2	0	560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20	25	560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21	25	560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0	560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0	560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0	560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0	560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26	13	560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27	13	560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0	560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0	560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3	0	560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0	560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0	560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0	560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0	560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0	560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4	0	560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5	0	560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0	560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0	560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0	560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0	560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0	560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0	560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0	560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0	560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0	560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0	560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0	560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0	560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0	560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0	560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0	560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0	560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0	560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0	560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0	560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0	560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0	560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0	560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0	560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0	560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0	560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0	560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0	560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0	560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0	560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0	560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0	560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0	560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0	560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0	560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0	560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0	560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0	560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0	560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0	560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14	560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15	560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	0	560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	0	560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	22	560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	23	560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0	560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0	560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	3	560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	4	560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	16	560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	18	560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	26	560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	39	560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3A 	560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C 	560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29	560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A 	560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30	560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	2E 	560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	2F 	560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31	560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32	560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	27	560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	2	560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	3	560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	4	560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	5	560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	6	560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	20	560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	21	560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A 	560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B 	560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	1C 	560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	1D 	560
IDE05145-ENG115873-Light configuration-Lasttyp 0	12 - Blinkleuchten 	560
IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten 	560
IDE05145-ENG116062-Light configuration-Lasttyp 10	not active 	560
IDE05145-ENG116081-Light configuration-Lasttyp 11	not active 	560
IDE05145-ENG116100-Light configuration-Lasttyp 12	23 - allgemeine Scheinwerfer 	560
IDE05145-ENG116119-Light configuration-Lasttyp 13	23 - allgemeine Scheinwerfer 	560
IDE05145-ENG116138-Light configuration-Lasttyp 14	not active 	560
IDE05145-ENG116157-Light configuration-Lasttyp 15	not active 	560
IDE05145-ENG116176-Light configuration-Lasttyp 16	46 - LED Kleinleistung 	560
IDE05145-ENG116195-Light configuration-Lasttyp 17	46 - LED Kleinleistung 	560
IDE05145-ENG116214-Light configuration-Lasttyp 18	12 - Blinkleuchten 	560
IDE05145-ENG116233-Light configuration-Lasttyp 19	12 - Blinkleuchten 	560
IDE05145-ENG115910-Light configuration-Lasttyp 2	8 - allgemeine Glühlampe 12W 	560
IDE05145-ENG116252-Light configuration-Lasttyp 20	13 - Bremsleuchten 	560
IDE05145-ENG116271-Light configuration-Lasttyp 21	13 - Bremsleuchten 	560
IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte 	560
IDE05145-ENG116309-Light configuration-Lasttyp 23	9 - allgemeine Glühlampe 27W: auch H15 	560
IDE05145-ENG116328-Light configuration-Lasttyp 24	9 - allgemeine Glühlampe 27W: auch H15 	560
IDE05145-ENG116347-Light configuration-Lasttyp 25	43 - allgemeine LED 	560
IDE05145-ENG116366-Light configuration-Lasttyp 26	9 - allgemeine Glühlampe 27W: auch H15 	560
IDE05145-ENG116385-Light configuration-Lasttyp 27	9 - allgemeine Glühlampe 27W: auch H15 	560
IDE05145-ENG116404-Light configuration-Lasttyp 28	8 - allgemeine Glühlampe 12W 	560
IDE05145-ENG116423-Light configuration-Lasttyp 29	8 - allgemeine Glühlampe 12W 	560
IDE05145-ENG115929-Light configuration-Lasttyp 3	8 - allgemeine Glühlampe 12W 	560
IDE05145-ENG116442-Light configuration-Lasttyp 30	46 - LED Kleinleistung 	560
IDE05145-ENG116461-Light configuration-Lasttyp 31	not active 	560
IDE05145-ENG116480-Light configuration-Lasttyp 32	not active 	560
IDE05145-ENG116499-Light configuration-Lasttyp 33	not active 	560
IDE05145-ENG116518-Light configuration-Lasttyp 34	not active 	560
IDE05145-ENG115948-Light configuration-Lasttyp 4	9 - allgemeine Glühlampe 27W: auch H15 	560
IDE05145-ENG115967-Light configuration-Lasttyp 5	9 - allgemeine Glühlampe 27W: auch H15 	560
IDE05145-ENG115986-Light configuration-Lasttyp 6	11 - Abblendlicht 	560
IDE05145-ENG116005-Light configuration-Lasttyp 7	11 - Abblendlicht 	560
IDE05145-ENG116024-Light configuration-Lasttyp 8	23 - allgemeine Scheinwerfer 	560
IDE05145-ENG116043-Light configuration-Lasttyp 9	23 - allgemeine Scheinwerfer 	560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always 	560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always 	560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always 	560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always 	560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always 	560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always 	560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always 	560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always 	560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always 	560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always 	560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always 	560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always 	560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always 	560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always 	560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always 	560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always 	560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	Always 	560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	Always 	560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always 	560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	only_if_closed 	560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	only_if_closed 	560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	Always 	560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	Always 	560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always 	560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always 	560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always 	560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always 	560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always 	560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always 	560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always 	560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always 	560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always 	560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always 	560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always 	560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always 	560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0	560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	30	560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2	560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4	560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	0	560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	0	560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	18	560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	19	560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0	560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0	560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	45	560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	46	560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	2	560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	4	560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	8	560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24	560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24	560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24	560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	8	560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	8	560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8	560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	26	560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	26	560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25	560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25	560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	8	560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	43	560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	45	560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	45	560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	45	560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	45	560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20	560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20	560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11	560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12	560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	13	560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	14	560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0	560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0	560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	0	560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	0	560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	22	560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	23	560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0	560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0	560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0	560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0	560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0	560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	9	560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0	560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0	560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0	560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	30	560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	30	560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	30	560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0	560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0	560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0	560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0	560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	10	560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0	560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0	560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0	560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0	560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0	560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0	560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0	560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	0	560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	0	560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	15	560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	15	560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	3	560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	5	560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0	560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0	560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	30	560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0	560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0	560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0	560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0	560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	3	560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	5	560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	0	560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	8	560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	8	560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0	560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	0	560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	0	560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0	560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0	560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0	560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0	560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0	560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	0	560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0	560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0	560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0	560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0	560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0	560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	0	560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	0	560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0	560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0	560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0	560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0	560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0	560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0	560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0	560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0	560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0	560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0	560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0	560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0	560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0	560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0	560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0	560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0	560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	0	560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	9	560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	10	560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0	560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	0	560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	0	560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0	560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0	560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0	560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0	560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0	560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	0	560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0	560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0	560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0	560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0	560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0	560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	0	560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	0	560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0	560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0	560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0	560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0	560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0	560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0	560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0	560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0	560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0	560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0	560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0	560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0	560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0	560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0	560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0	560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0	560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	0	560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	30	560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	30	560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0	560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0	560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0	560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0	560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	8	560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	8	560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0	560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0	560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	0	560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0	560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0	560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0	560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0	560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0	560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	15	560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	15	560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0	560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0	560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0	560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0	560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0	560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0	560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0	560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0	560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0	560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0	560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0	560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0	560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0	560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0	560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0	560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0	560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0	560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0	560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0	560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0	560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0	560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0	560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0	560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	30	560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	30	560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0	560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0	560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0	560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0	560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0	560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0	560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0	560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0	560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0	560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0	560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0	560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0	560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0	560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0	560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0	560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0	560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0	560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0	560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0	560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0	560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0	560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0	560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0	560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0	560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0	560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0	560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0	560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0	560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0	560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0	560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0	560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0	560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0	560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0	560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0	560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0	560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0	560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0	560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0	560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0	560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0	560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0	560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0	560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0	560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0	560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0	560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0	560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0	560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0	560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0	560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0	560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0	560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0	560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0	560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0	560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0	560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0	560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0	560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0	560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0	560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0	560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0	560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0	560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0	560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0	560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0	560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0	560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0	560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0	560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0	560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0	560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0	560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0	560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0	560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0	560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0	560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0	560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0	560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0	560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0	560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0	560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0	560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0	560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0	560
IDE05822-DWA Vehicle inclination sensor	100%	1
IDE05823-DWA Interior monitoring parameter set	01 09 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 FF F6 06 00 0F 1E 00 85 0F 32 F7 64 23 45 21 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 FF F6 56 00 0F 1E 00 86 28 32 F7 65 0F 43 21 57 1B 03 32 3F 3A 69 58 93 0D 09 A3 03 F5 F6 26 00 0F 19 00 88 0F 2D F7 68 1E 45 21 57 1B 03 22 3F 3A 69 58 93 0C 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 66 23 45 21 57 9B 23 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 20 24 2B 3F 	172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	14
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	14
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	20.00 °C	14
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	19.00 °C	14
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	28.00 °C	14
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	27.50 °C	14
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	14
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	35.00 °C	14
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	41.00 °C	14
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	40.50 °C	14
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	50.00 °C	14
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	49.00 °C	14
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	63.00 °C	14
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	62.50 °C	14
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	not active 	6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active 	6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active 	6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	active 	6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	not active 	6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung	active 	6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	50%	6
IDE06425-Roller test bench mode: functional	not active 	1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights 	2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	active 	2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active 	2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active 	2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active 	2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active 	2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active 	2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	2
IDE07007-ENG148891-A/C heater function via remote control-Anzahl zulaessiger Remotestarts	2	2
IDE07007-ENG148876-A/C heater function via remote control-RemoteStart Betrieb Dauer	10 min	2
IDE07356-Position during interval mode	21.197781 °	2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit 	5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	5
IDE08542-IDE02021-Access control 2-Comfort closing	active 	6
IDE08542-IDE02022-Access control 2-Comfort opening	not active 	6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	not active 	6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	not active 	6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s	6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active 	6
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active 	6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active 	6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	active 	6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key 	6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	Yes 	6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	Yes 	6
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	Yes 	6
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active 	6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active 	6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	active 	6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable 	6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active 	6
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active 	6
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	not active 	6
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active 	6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel	not active 	6
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once 	6
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active 	6
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	not_active 	6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	active 	6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	active 	6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active 	6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting 	6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	active 	6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	active 	6
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active 	6
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active 	6
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	not active 	6
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active 	6
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active 	6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	500 ms	4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active 	4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	800 ms	4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present 	4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	Not Present 	4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active 	4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active 	1
IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner	active 	1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	not active 	1
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	1
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active 	4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active 	4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active 	4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active 	4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active 	4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active 	4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active 	4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active 	4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active 	4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active 	4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active 	4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken	not active 	4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active 	4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active 	4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active 	4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active 	4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active 	4
IDE09595-ENG115658-Characteristic curve-x0	0 lx	18
IDE09595-ENG101574-Characteristic curve-X1	2000 lx	18
IDE09595-ENG99557-Characteristic curve-X2	4000 lx	18
IDE09595-ENG102140-Characteristic curve-X3	6000 lx	18
IDE09595-ENG102936-Characteristic curve-X4	8000 lx	18
IDE09595-ENG103548-Characteristic curve-X5	10200 lx	18
IDE09595-ENG148955-Characteristic curve-y1_0	0	18
IDE09595-ENG148956-Characteristic curve-y1_1	40	18
IDE09595-ENG148957-Characteristic curve-y1_2	90	18
IDE09595-ENG148958-Characteristic curve-y1_3	140	18
IDE09595-ENG148959-Characteristic curve-y1_4	190	18
IDE09595-ENG148960-Characteristic curve-y1_5	245	18
IDE09595-ENG148961-Characteristic curve-y2_0	0	18
IDE09595-ENG148962-Characteristic curve-y2_1	60	18
IDE09595-ENG148963-Characteristic curve-y2_2	110	18
IDE09595-ENG148964-Characteristic curve-y2_3	160	18
IDE09595-ENG148965-Characteristic curve-y2_4	210	18
IDE09595-ENG148966-Characteristic curve-y2_5	255	18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	10
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	10
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	10
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	10
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	10
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	10
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	10
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2	10
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	10
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	10
IDE09731-ENG148953-Int. light: 2nd generation-Helligkeit Türtafelbeleuchtung nicht berechnen	active 	10
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	10
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	10
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	10
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	10
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	10
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	10
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	10
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed 	2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	installed 	2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	installed 	2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung	3000 ms	10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit	1000 ms	10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige	0 s	10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz	25	10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor	0 W/m²	10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS	393210 lx	10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS	393210 lx	10
IDE09733-ENG147405-LED bar setting values-Sperrzeit	0 s	10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	12
IDE10298-Alternating park position 1	18.197784 °	2
IDE10299-Alternating park position 2	21.197781 °	2
MAS00194---no display--	5 s	1
MAS00194-ENG123004---no display---p_lx_regenlichtschwelle	6000 lx	2
MAS00194-ENG123002---no display---p_n_regenlichtschwelle_high	12 s	2
MAS00194-ENG123003---no display---p_n_regenlichtschwelle_low	6	2
MAS00194-ENG123005---no display---p_t_regenlicht	30 s	2
MAS01490-Energy management	active 	1
MAS05055-lower turn position	26.197776 °	2
MAS05056-upper turn position	166.197637 °	2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active 	3
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active 	3
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active 	3
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active 	3
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active 	3
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active 	3
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active 	3
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active 	3
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active 	3
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active 	3
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active 	3
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active 	3
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active 	3
ENG122925-DWA_Interior_Monitoring_Data_Set_Development	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	150
ENG122934-erase_error_table	5570560	3
ENG122933-error_mask	0	2
ENG117283-Frontwaschfunktion	10	2
ENG99457-ENG117394-Head area heater-blower_speed	1	2
ENG99457-ENG98971-Head area heater-Temperature	-3	2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms	22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms	22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms	22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms	22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms	22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms	22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms	22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms	22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms	22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms	22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms	22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%	22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	100.00%	22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%	22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	95.00%	22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	80.00%	22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	40.00%	22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	20.00%	22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	10.00%	22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	5.00%	22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	3.00%	22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	1.00%	22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0	22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50	22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0	22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100	22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200	22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253	22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0	22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0	22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0	22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0	22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0	22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx	22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx	22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx	22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx	22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200 lx	22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500 lx	22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0 lx	22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx	22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx	22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx	22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx	22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms	22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms	22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms	22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms	22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms	22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms	22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms	22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms	22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms	22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms	22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms	22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%	22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%	22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%	22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%	22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%	22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%	22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%	22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%	22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%	22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%	22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%	22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%	12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%	12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%	12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%	12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%	12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%	12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10	12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10	12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100	12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150	12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220	12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253	12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx	10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx	10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx	10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx	10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx	10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16.00%	10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16.00%	10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100.00%	10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100.00%	10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100.00%	10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx	10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx	10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx	10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx	10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx	10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6.00%	10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6.00%	10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100.00%	10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100.00%	10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100.00%	10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0	12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10	12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	100	12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	150	12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220	12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253	12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	6.00%	12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	6.00%	12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	16.00%	12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	30.00%	12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	60.00%	12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%	12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx	8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx	8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx	8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx	8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100.00%	8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100.00%	8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100.00%	8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100.00%	8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%	6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%	6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%	6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%	6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%	6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%	6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx	8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx	8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx	8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx	8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100.00%	8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100.00%	8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100.00%	8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100.00%	8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx	8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx	8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx	8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx	8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6.00%	8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6.00%	8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100.00%	8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100.00%	8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%	6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%	6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%	6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%	6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%	6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%	6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms	10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	2000 ms	10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	3000 ms	10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	4000 ms	10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	5100 ms	10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%	10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5	10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15	10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	40	10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100	10
ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0	0 lx	8
ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1	8 lx	8
ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2	50 lx	8
ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3	500 lx	8
ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0	6.00%	8
ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1	6.00%	8
ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2	100.00%	8
ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3	100.00%	8
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten 	16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	Blinken links Dunkelphase 	16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	100	16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	23 - allgemeine Scheinwerfer 	16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links 	16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	Coming Home oder Leaving Home aktiv 	16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	100	16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	23 - allgemeine Scheinwerfer 	16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts 	16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	Coming Home oder Leaving Home aktiv 	16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize 	16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize 	16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize 	16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0	16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0	16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0	16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0	16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0	16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0	16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active 	16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always 	16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active 	16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active 	16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active 	16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active 	16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active 	16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active 	16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active 	16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active 	16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	100	16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	3	16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	46 - LED Kleinleistung 	16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Ambientelicht 1 	16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	100	16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	4	16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	46 - LED Kleinleistung 	16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Ambientelicht 2 	16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100	16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8	16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten 	16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase 	16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	Blinken links Dunkelphase 	16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100	16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18	16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18	16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten 	16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase 	16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	Blinken rechts Dunkelphase 	16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	Blinken rechts Dunkelphase 	16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize 	16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	25	16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	25	16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	39	16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	10	16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	13 - Bremsleuchten 	16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active 	16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Coming Home oder Leaving Home aktiv 	16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize 	16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	25	16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	25	16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3A 	16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	20	16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	13 - Bremsleuchten 	16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active 	16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	Parking light right 	16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Coming Home oder Leaving Home aktiv 	16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100	16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active 	16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	27	16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0	16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Coming Home oder Leaving Home aktiv 	16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active 	16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	27	16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0	16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Coming Home oder Leaving Home aktiv 	16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active 	16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	100	16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	Coming Home oder Leaving Home aktiv 	16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100	16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	13	16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2E 	16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	11	16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	only_if_closed 	16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	Coming Home oder Leaving Home aktiv 	16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	100	16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	13	16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	2F 	16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	21	16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	only_if_closed 	16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	Coming Home oder Leaving Home aktiv 	16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100	16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	8 - allgemeine Glühlampe 12W 	16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100	16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	8 - allgemeine Glühlampe 12W 	16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0	16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0	16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	26	16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	35	16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	8 - allgemeine Glühlampe 12W 	16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active 	16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active 	16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active 	16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100	16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	46 - LED Kleinleistung 	16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	100	16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	3	16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	Ambientelicht 1 	16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	100	16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	4	16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	Ambientelicht 1 	16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	100	16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	5	16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	Ambientelicht 1 	16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	100	16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	6	16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	Ambientelicht 1 	16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0	16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0	16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	27	16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	3F 	16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	8 - allgemeine Glühlampe 12W 	16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	Parking light right 	16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active 	16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active 	16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active 	16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize 	16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	minimize 	16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	100	16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0	16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	20	16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A 	16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	not active 	16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Lichthupe generell 	16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active 	16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize 	16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	minimize 	16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	100	16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0	16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	21	16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44	16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	not active 	16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Lichthupe generell 	16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active 	16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	23 - allgemeine Scheinwerfer 	16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	23 - allgemeine Scheinwerfer 	16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize 	16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize 	16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize 	16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0	16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0	16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0	16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0	16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0	16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0	16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active 	16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always 	16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active 	16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active 	16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active 	16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active 	16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active 	16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active 	16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active 	16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active 	16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110.00%	12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.50%	12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
ENG122927-RLS_close_glazing	2.0 s	1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s	3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	9 s	3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h	3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h	3
ENG122929-RLS_LIN_Communication	4 s	1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	100 lx	1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	200 lx	1
ENG122935-RLS_Washer_Front	15 s	1
ENG122926-RLS_wiper_position_parking	15 s	1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
ENG116832-ENG122996-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute	42	3
ENG116832-ENG122997-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute	62	3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30	3
Elapsed Time: 02:12
and a scan
Thursday,02,November,2017,19:33:29:08973
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ8V6EA090562   License Plate: GY63FZG
Mileage: 55045km-34203mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8V6EA090562   Mileage: 55045km-34203miles
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AC    HW: 04E 907 309 G
   Component: 1,4l R4 TSI   H02 5757
   Revision: WKH02---
   Coding: 02190032234401082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906016AC 002007
   ROD: EV_ECM14TFS01104E906016AC.rod
   VCID: 63C3EABA6A76B55EF7-8036
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 628930000006D9
   Coding: 12F18AA224292A6C017C060641C5294851245480608294F2F42150388608
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 7BF3B2DAF2C66D9EDF-802E
   Component: AC Automat    H13 0040
   Revision: 20025000    Serial number: 00000000176143
   Coding: 03100014000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008017
   VCID: 33635AFA9A1665DE47-8066
   Serial number: 79E842D6000000000001
   Part No SW: 5Q0 937 084 AD    HW: 5Q0 937 084 AD
   Component: BCM MQBAB M+  H16 0124
   Serial number: 00011329700258
   Coding: 07140846C24102FD03844004B31407A8000C000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7AFDB7DEFDFC5496C4-802E
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130923  041 0580
   Serial number:         131002081434
   Coding: 0A47F7
   Serial number: 21868912
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 25 07 2013  00000100
   Serial number: 000000000ZY132460D3U
   Serial number: 00000000000058005593
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO24217820
   Coding: 901E00
   Part No SW: 5Q0 919 298 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0033
   Revision: --------    Serial number: 61131329201650
   Coding: 0110060041
   ASAM Dataset: EV_EPHVA2CAU3700000 003015
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 3E757BCEA154B8B6B8-806A
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 10101376510609
   Coding: 00200301FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 356764E294627BEE69-8060
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R03NAPT
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 4B93221AE2E61D1E2F-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 910 13
   Serial number: 35767000000CD641FD06
   Subsystem 2 - Part No SW: -----------    HW: 480 000 910 13
   Serial number: 358670000005D641FD00
   Subsystem 3 - Part No SW: -----------    HW: 480 401 810 13
   Serial number: 3516502BD11D1521824+
   Subsystem 4 - Part No SW: -----------    HW: 480 401 810 13
   Serial number: 3526502B911D152581B5
   Subsystem 5 - Part No SW: -----------    HW: 480 400 909 13
   Serial number: 35565029D1118715D188
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 110 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502BD1171FE4E13O
   Subsystem 7 - Part No SW: -----------    HW: 480 401 909 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502B311D1524B21
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 609 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C911D1522504U
   Part No SW: 8V0 953 521 BR    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 11101308491292
   Coding: E408
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0B13E21AA2665D1EEF-805E
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 970 P    HW: 8V0 920 970 P
   Component: KOMBI         H03 2211
   Coding: 27850900279046000180EA00100000
   VCID: 499F1812E89A0F0E1D-801C
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001155488
   Coding: 030100042B0864005B000258080B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3F8B06CAA65EB1BEB3-806A
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 03 10 2013  E0259656
   Serial number: 7024811503
   Serial number: 15101304081288
   Coding: 003D82205001040000001003
   VCID: 40890536DBA0CE46CA-8014
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8303
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 418F0032D0AAC74EC5-8014
   Serial number: 14101302090984
   Coding: 003D86205E01040000001003
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    040 0420
   Serial number: A7F02210131346
   Coding: 01730301FF0A000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 3B7372DAB246AD9E9F-806E
   Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
   Component:  ECE 2014  --- 0036
   Subsystem 2 - Part No SW: 8V0 919 603 B    HW: 8V0 919 603 B
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DM70086S
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000029081300010105
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 18101302090461
   Coding: 003D86204001040000001002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   VCID: 428D0F3ED5ACDC56DC-8016
   Component: TSG HBFS      020 0025
   Serial number: 18101303110475
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 04:04)--------------------------
^^^ admal: thank you for the admap - it's the first that I have seen with the "non" turn signal connected to pin #3 Socket C! So you were correct - my apology for doubting your assertion.
Anyhow, I searched deeper into my database and I found the following instructions - I must have borrowed these from the web (somewhere?) in my past perambulations on the net, but I have failed to record the source - so I can't provide attribution
Select BCM (@ address hex09)
Select function Coding-07
  • Set Byte 17, Bit 2=1
Select information electronics (@ address hex5F)
Select function Adaptation -10
  1. IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination -> Set to "activated"
  2. IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high -> Set to "activated"
  3. IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08 -> Set to "activated"
I've re-arranged the BCM code-string from your auto-scan below:
Byte	Hex	Binary
0	07	00000111
1	14	00010100
2	08	00001000
3	46	01000110
4	C2	11000010
5	41	01000001
6	02	00000010
7	FD	11111101
8	03	00000011
9	84	10000100
10	40	01000000
11	04	00000100
12	B3	10110011
13	14	00010100
14	07	00000111
15	A8	10101000
16	00	00000000
[B]17	[/B]0C	00001[B][COLOR="#0000FF"]1[/COLOR][/B]00
18	00	00000000
19	00	00000000
20	00	00000000
21	00	00000000
22	00	00000000
23	00	00000000
24	00	00000000
25	00	00000000
26	00	00000000
27	00	00000000
28	00	00000000
29	00	00000000
Notice that Byte 17, Bit 2 is set to 1 - so the BCM part of the instructions are OK
Also, from your admap, the active part of the Leuchte-set for pin#3, socket C is the AB alpha-pair which is:
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 -> Ambientelicht 2
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 -> not active
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 -> 100
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 -> Always
So- the Leuchte-set is set-up for ambient lighting which looks OK (IMO) - albeit there are 5 x "ambient lighting" settings as follows:
  • Ambientelicht 1
  • Ambientelicht 2
  • Ambientelicht 3
  • Ambientelicht 4
  • Ambientelicht 5
The only part that is yet to be confirmed is the adaptation settings in your MIB unit (@ address hex5F) - can you please check these settings and advise?
adamal
Newport, Wales
C?ID=174908
Thanks Don. Pretty sure my settings in 5F are ok - see below.
;SW:8V0-035-874-B   HW:8V0-035-874-B ---  Information Electr.
;Component:MU-S-ND-ER    040 0420	 Coding:01730301FF0A000021111101000A00002F0004460100010006
;EV_MUStd6C3PASE	2020	EV_MUStd6C3PASE_AU37.rod
;Saturday	28	October
;VCDS Version: Release 17.8.0 (x64)  Data version: 20170721 DS276.2
;VCID: 3B7372DAB246AD9E9F-806E
IDE00001-Production mode	00 00 00 	3
IDE00346-Summertime-automatic	manual 	1
IDE00758-Base volume of telephone	50%	1
IDE00759-Base volume of speech output	50%	1
IDE00760-Microphone sensitivity	6 dB	1
IDE00769-Number 1 for Info call	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE00770-Number 1 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE00845-Wheel circ.	0 mm	2
IDE02121-CD eject button	Enabled 	1
IDE02122-Developer mode	not activated 	1
IDE02330-Number 2 for Info call	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE02331-Number 2 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE02332-Deactivate production mode	0	3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	67	49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	85	49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	85	49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	85	49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	85	49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	85	49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	85	49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	85	49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	45	49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	45	49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	67	49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	85	49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	85	49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	85	49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	85	49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	85	49
IDE02502-Confirmation of installation change	14 1B 	2
IDE02607-Wheel pulse	0	2
IDE02699-Number 1 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE02701-Number 1 (roaming) for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus	Databus Infotainment 	8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school	Available 	8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school	Not available 	8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus	Comfort data bus 	8
IDE03581-ENG107608-Vehicle function list CAN-MFL	Available 	8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus	Databus Infotainment 	8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level	Not available 	8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus	Comfort data bus 	8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering	Not available 	8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus	Comfort data bus 	8
IDE03581-ENG98994-Vehicle function list CAN-Trailer	Not available 	8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus	Comfort data bus 	8
IDE03581-ENG99892-Vehicle function list CAN-VIN	Available 	8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus	Databus Infotainment 	8
IDE03902-Automatic ring break diagnostic	No automatic start 	1
IDE04292-Roadside assistance mode	Corresponding setting in MMI 	1
IDE04294-Number attempted dialing attempts for roadside assistance	3	1
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC	activated 	40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer	not activated 	40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off	not activated 	40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high	activated 	40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill	not activated 	40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key	activated 	40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer	not activated 	40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off	not activated 	40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high	activated 	40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill	not activated 	40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper	not activated 	40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer	not activated 	40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off	not activated 	40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high	not activated 	40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill	not activated 	40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination	activated 	40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer	not activated 	40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off	not activated 	40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high	activated 	40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill	not activated 	40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification	activated 	40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer	not activated 	40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off	not activated 	40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high	activated 	40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill	not activated 	40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating	not activated 	40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer	not activated 	40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off	not activated 	40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high	not activated 	40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill	not activated 	40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv	activated 	40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer	not activated 	40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off	not activated 	40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high	activated 	40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill	not activated 	40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE	not activated 	40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer	not activated 	40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off	not activated 	40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high	not activated 	40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill	not activated 	40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer	activated 	40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer	not activated 	40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off	not activated 	40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high	activated 	40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill	not activated 	40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function	not activated 	40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer	not activated 	40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off	not activated 	40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high	not activated 	40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill	not activated 	40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror	not activated 	40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer	not activated 	40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off	not activated 	40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high	not activated 	40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill	not activated 	40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking	activated 	40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer	not activated 	40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off	not activated 	40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high	activated 	40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill	not activated 	40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master	activated 	40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer	not activated 	40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off	not activated 	40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high	activated 	40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill	not activated 	40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma	activated 	40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer	not activated 	40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off	not activated 	40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high	activated 	40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill	not activated 	40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration	activated 	40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer	not activated 	40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off	not activated 	40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high	activated 	40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill	not activated 	40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock	activated 	40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer	not activated 	40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off	not activated 	40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high	activated 	40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill	not activated 	40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass	not activated 	40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer	not activated 	40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off	not activated 	40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high	not activated 	40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill	not activated 	40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school	not activated 	40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer	not activated 	40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off	not activated 	40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high	not activated 	40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill	not activated 	40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall	not activated 	40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer	not activated 	40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off	not activated 	40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high	not activated 	40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill	not activated 	40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination	activated 	40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer	not activated 	40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off	not activated 	40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high	activated 	40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill	not activated 	40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display	not activated 	40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer	not activated 	40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off	not activated 	40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high	not activated 	40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill	not activated 	40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid	not activated 	40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer	not activated 	40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off	not activated 	40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high	not activated 	40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill	not activated 	40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning	not activated 	40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high	not activated 	40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill	not activated 	40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker	activated 	40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer	not activated 	40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off	not activated 	40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high	activated 	40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill	not activated 	40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision	not activated 	40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer	not activated 	40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off	not activated 	40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high	not activated 	40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill	not activated 	40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level	not activated 	40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer	not activated 	40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off	not activated 	40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high	not activated 	40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill	not activated 	40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc	activated 	40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer	not activated 	40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off	not activated 	40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high	not activated 	40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill	not activated 	40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk	activated 	40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer	not activated 	40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off	not activated 	40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high	not activated 	40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill	not activated 	40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load	not activated 	40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high	not activated 	40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill	not activated 	40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification	not activated 	40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer	not activated 	40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off	not activated 	40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high	not activated 	40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill	not activated 	40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration	not activated 	40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer	not activated 	40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off	not activated 	40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high	not activated 	40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill	not activated 	40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia	activated 	40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer	not activated 	40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off	not activated 	40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high	activated 	40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill	not activated 	40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant	not activated 	40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer	not activated 	40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off	not activated 	40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high	not activated 	40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill	not activated 	40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view	not activated 	40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer	not activated 	40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off	not activated 	40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high	not activated 	40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill	not activated 	40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons	not activated 	40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high	not activated 	40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill	not activated 	40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo	not activated 	40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer	not activated 	40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off	not activated 	40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high	not activated 	40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill	not activated 	40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin	activated 	40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer	not activated 	40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off	not activated 	40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high	activated 	40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill	not activated 	40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition	activated 	40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer	not activated 	40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off	not activated 	40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high	activated 	40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill	not activated 	40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows	not activated 	40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer	not activated 	40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off	not activated 	40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high	not activated 	40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill	not activated 	40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper	activated 	40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer	not activated 	40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off	not activated 	40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high	activated 	40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill	not activated 	40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05	activated 	53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus	Databus extended 	53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06	not activated 	53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus	Comfort data bus 	53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D	not activated 	53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus	Comfort data bus 	53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03	not activated 	53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus	Comfort data bus 	53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B	activated 	53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus	Databus extended 	53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23	not activated 	53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus	Comfort data bus 	53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26	not activated 	53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus	Comfort data bus 	53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D	activated 	53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus	Comfort data bus 	53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17	activated 	53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus	Terminal 15 	53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16	not activated 	53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus	Comfort data bus 	53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01	activated 	53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus	Comfort data bus 	53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02	not activated 	53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus	Comfort data bus 	53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11	activated 	53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus	Comfort data bus 	53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15	not activated 	53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus	Comfort data bus 	53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10	not activated 	53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus	Comfort data bus 	53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33	not activated 	53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33	Comfort data bus 	53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09	activated 	53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus	Comfort data bus 	53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04	not activated 	53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus	Comfort data bus 	53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D	not activated 	53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus	Comfort data bus 	53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08	activated 	53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus	Comfort data bus 	53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19	not activated 	53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus	Comfort data bus 	53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F	activated 	53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus	Comfort data bus 	53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34	activated 	53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34	Databus Infotainment 	53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E	not activated 	53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus	Comfort data bus 	53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18	not activated 	53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus	Comfort data bus 	53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A	activated 	53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus	Terminal 15 	53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20	not activated 	53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus	Comfort data bus 	53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F	not activated 	53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Comfort data bus 	53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12	activated 	53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus	Comfort data bus 	53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E	not activated 	53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus	Comfort data bus 	53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27	not activated 	53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus	Comfort data bus 	53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A	not activated 	53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus	Comfort data bus 	53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07	activated 	53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus	Comfort data bus 	53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21	not activated 	53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus	Comfort data bus 	53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14	not activated 	53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus	Comfort data bus 	53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13	activated 	53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus	Comfort data bus 	53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B	not activated 	53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus	Comfort data bus 	53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22	activated 	53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus	Databus Infotainment 	53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C	activated 	53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus	Comfort data bus 	53
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
IDE04521-Sporadic ring break detection	Visual 	1
IDE04522-Awakening ability on optical databus	OFF 	1
IDE04550-Bluetooth: Sniff mode	OFF 	1
IDE05111-Fee-based traffic information (TMC)	11	2
IDE05112-MAS02228-Image position-X coordinate	0	2
IDE05112-MAS02229-Image position-Y coordinate	0	2
IDE05113-Infotainment Recorder	activated 	1
IDE06698-MAS00839-Audio management input gain-TV Tuner	-128 dB	6
IDE06698-MAS00846-Audio management input gain-Satellite radio	-128 dB	6
IDE06698-MAS01984-Audio management input gain-Radio (FM)	-128 dB	6
IDE06698-MAS01985-Audio management input gain-Radio (AM)	-128 dB	6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB)	-128 dB	6
MAS00951-Bluetooth	On 	1
MAS01968-Fan	normal 	1
MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50	6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100	6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50	6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100	6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1	0	6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2	50	6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3	100	6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1	0	6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2	50	6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3	100	6
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1	0	12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2	10	12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3	100	12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4	150	12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5	220	12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6	253	12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1	0%	12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2	6%	12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3	16%	12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4	30%	12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5	60%	12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6	100%	12
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	50	12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	100	12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	150	12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%	12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	2%	12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	4%	12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	10%	12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	30%	12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
ENG117809-p_damping_Display	5 ms	1
ENG117808-p_HMI_Display	10%	1
Elapsed Time: 00:25
I'm beginning to doubt my BCM supports the cupholder. The other thing I have ruled out is a wiring issue, running an alternative wire with the same results (i.e. rising from 0V to only 0.6V when the lights are turned on).
Regards
Adam
^^^ yep - 5F unit OK. Your problem has captured my imagination - so if you are prepared to persevere, perhaps the following might be of interest?
Your observation of 0.6 Volts (across the cup-holder terminals-I assume) is strange! 0.6 volts is about the correct volt-drop for a normal diode, but a Light Emitting Diode, normally has a higher forward volt drop (i.e typically in the order of 1-2 Volts). With standard 12 volt LEDs, there is usually a current limiting resistor in circuit which means that the measured voltage across the fitting itself should be normal rail voltage of the car. The "dimmwert" value in the Leuchte-set for pin 3 socket C is 100, so the full driving signal from the BCM should be expected from pin 3, socket C.
Of course you will be aware that LED light fittings are "polarized", so I assume that the diode(s) in the cup-holder has the correct forward voltage bias. Perhaps some further experiments might be prudent - before you dismiss the BCM capacity to drive the cup-holder:
first: try driving the cup-holder from a separate battery source - even with a simple 9 Volt battery (one end earthed and the pin 3, socket C wire disconnected and +ve 9V terminal connected to the LED anode), it should light-up!
If the experiment above is successful, it means that the cup-holder electrics are OK. - if so, consider this: The beauty of Leuchte-sets is their ability to be readily re-programmed. If the cup holder is wired correctly, it's real easy to make it light-up when you select another light function in the car. So try temporarily programming the pin#3, socket C pin on the BCM to turn-on when you activate the right-side blinker like this:
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 ->change to Blinken rechts Hellphase (default Ambientelicht 2).
If the cup holder starts blinking after you operate the turn-signal stalk, it's wired correctly and the BCM supports pin3, socket C. In this case, try different "ambient lighting" settings in the channel above.
Sometimes I reminisce about the simpler days, when if you wanted to add some interior lighting, you just did so and simply ran a wire from it to wherever you could find terminal 58d. :)
Then again, I suppose we wouldn't sell a whole lot of scan tools if things were still like that. :eek:
adamal
Newport, Wales
C?ID=174908
The cupholder is polarised and lights red in one direction and white (as I have chosen) in the other. The 9v battery test works absolutely fine, as does wiring it to the cigarette lighter lighting circuit (I've set it up so I can switch plugs to use either the ciggy lighter or pin 3 of socket C).
I'd like to understand these leuchte sets better than I do and your response is starting to help me do that. I have alreadty tried different ambiente light settings (1 and 2) with no joy but was a little worried I could be doing some damage...
Are you saying that I can effectively reprogram the operation of pin C3 here?
Adam
adamal
Newport, Wales
C?ID=174908
Ha ha indeed. Actually I have settled for this option, but its not OEM and its doesn't sit well with me...
Adam
Adam: very valid questions indeed!! My personal view is that "damage" is highly unlikely and the reason for my confidence lies in a close inspection of your BCM admap!
If you have a look at your admap, you will find that your BCM has 665 x adaptation channels that contain the familiar descriptor "Leuchte". An even closer inspection will reveal an interesting pattern - all these adaptation channels have ostensibly the same structure: there are in fact 35 x groups of adaptation channels with each "set" having the same basic, 19 x adaptation channels.
As I said previously, the essential difference between the 35 x "Leuchte-set" descriptors is the pin number and socket number on the BCM! Within a particular Leuchte-set, the adaptation channel descriptors are basically the same (accepting the variance for pin/socket number - of course).
So - in typical mass production mode , my hypothesis is that the boffins @ VAG have simply provided the same facility for the BCM within MQB platform vehicles to control 35 x lights. The way to operate a particular light is just to select the appropriate turn-on and dimming level function.
There are other considerations in Leuchte programming when a lamp is asked to perform multiple functions (i.e. priory conflicts become important), but I'm confident that the VAG boffins have devised a simple system that caters for the 50% of Dealer mechanics that must an IQ <100 (by definition)!! so -this stuff can't be rocket science, once a basic understanding of the principles are obtained.
But apprehension is always a good thing when taking fledgling steps - and of course there is risk in every decision taken!! :thumbs:
Uwe: Isn't it odd how good fortune ALWAYS favors those that have foresight and those who work hard to achieve their vision?
adamal
Newport, Wales
C?ID=174908
Thanks for that. I had seen the pattern you mention but its not clear what all the 19 options allow-presumably its multifunction for each channel - or indeed what the abbreviations mean. Ill try what you suggest this weekend but am not hopeful that changing the light in question will have any impact due to the voltage issue. I was thinking my coding issue was more about enabling pin 3 than changing its behaviour.
Adam
adamal
Newport, Wales
C?ID=174908
Thanks again, your advice was invaluable...
Change the function to right turn signal and the voltage varied between 1 and 8 volts suggesting pin 3 is active. However, I tried all the ambient light options and the voltage didn't move from 0.6v, but I imagine there must be something I can use. I looked at "100% aktiv" and wondered about that - it does send a voltage down the wire...
Adam
admal: you could use Fussraumlicht (footwell) setting and adjust dimming via the MENU. Or, if you wanted the LED to illuminate only when the lights were switched-on, you could use Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) setting, then you could adjust the value of ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 to suit your illumination level liking
