MK6 GLI OEM bi-xenon retrofit - coding or bridge or something else?
zedo
C?ID=215712
Hey folks. Some idiot crashed into my car ('12 Jetta GLI) while it was parked and among other things I had to replace the headlights. I got OEM bi-xenons and had the repair shop install them. I purchased Kufatec adapters for 10 to 12 pin halogen to xenon which have enabled me to turn on the lights and activate the high beam shutter. Unfortunately no matter how I code with VCDS I can't get the LED DRLs to come on and I'm getting a bunch of bulb out warnings. I did not install any of the AFS/leveling components at this time. Right now I just want to get the DRLs to work and remove the error warnings.
I know there are many postings on this topic. I have read through all the threads I could find but thus far haven't found a solution. Some posts indicated that it may be necessary to create a bridge between two of the pins on the harness to provide power to the DRLs but I'm not sure how to do that nor do I wish to damage anything. I'm also not sure that is the correct solution.
I've been through coding nightmares before and I know how finicky it can be... hoping an expert might be able to offer recommendation. I previously very brilliantly bricked my BCM while doing a different xenon retrofit of aftermarket assemblies. I am very wary about messing with byte 18 now.
I enabled all the appropriate bits in VCDS, tried different combinations, changed the region setting for the lights, etc. to no avail.
Do I need to make further coding changes or do I need to perhaps bridge pins 10 and 12 as mentioned in some other threads? If so, how do I do that? I don't want to fry the electrics.
Here is my scan. Some of the lights errors are old but still in computer while some errors remain active and are related to the retrofit problem.
Tuesday,05,September,2017,15:01:51:48450
VCDS Version: 17.8.0.1
VIN: 3VW4A7AJ3CM048038   License Plate: 090517
Mileage: 110850km-68878mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 4F 52 56 62
          72 77
VIN: 3VW4A7AJ3CM048038   Mileage: 110850km-68878miles
   Part No SW: 06J 997 029 E    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 03 1510
   Revision: PAH04---    Serial number:
   Coding: 040301081C070160
   Shop #: WSC 04881 002 1048576
   VCID: 3957C43E70E4D08E8D-806C
   Part No SW: 02E 300 057 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2730
   Revision: 05351113    Serial number: 00001103201160
   Shop #: WSC 00066 000 00000
   VCID: 181121BA2B2EE98652-804C
   Revision: 00H31001
   Coding: A14B600C49260002850B06E792210041A70800
   VCID: 7BDB1E36FA58229EDF-802E
02214 - Tire Pressure Warning
                    Reset counter: 183
                    Mileage: 110220 km
                    Date: 2011.11.06
                    Time: 16:25:35
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 48897
                    Count: 251
Address 08: Auto HVAC
   Part No SW: 5K0 937 086 L    HW: 5K0 937 086 L
   Component: BCM PQ35 M    011 0048
   Revision: BJ011001
   Coding: 2F200ABAE02F06C480080000250009E8456C008841A08D22E48C00040040
   Shop #: WSC 64979 001 104857
   VCID: 3D5FD02EA4CCECAEA1-8068
   Component: RLS 200914 05  54  0403
   Coding: 0330AD
25 Faults Found:
                    Fault Status: 00100111
                    Reset counter: 213
                    Mileage: 110810 km
                    Date: 2012.01.27
                    Time: 13:22:60
                        Term 15 On
                    Voltage: 13.70 V
                    Fault Status: 00101010
                    Reset counter: 213
                    Mileage: 110766 km
                    Date: 2011.12.16
                    Time: 10:34:27
                        Term 15 On
                    Voltage: 12.70 V
                    Reset counter: 213
                    Mileage: 110810 km
                    Date: 2012.01.27
                    Time: 13:22:60
                        Term 15 On
                    Voltage: 13.70 V
                    Reset counter: 213
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 10:51:59
                        Term 15 On
                    Voltage: 11.85 V
00984 - Left Tail Light (M4)
                    Fault Frequency: 6
                    Reset counter: 213
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 13:37:58
                        Term 15 On
                    Voltage: 11.75 V
00985 - Right Tail Light (M2)
                    Fault Frequency: 10
                    Reset counter: 213
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 13:37:58
                        Term 15 On
                    Voltage: 11.75 V
                    Fault Frequency: 10
                    Reset counter: 213
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 13:38:47
                        Term 15 On
                    Voltage: 11.70 V
                    Fault Frequency: 8
                    Reset counter: 213
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 13:38:47
                        Term 15 On
                    Voltage: 11.70 V
                    Fault Frequency: 6
                    Reset counter: 213
                    Mileage: 110767 km
                    Date: 2011.12.23
                    Time: 07:56:18
                        Term 15 On
                    Voltage: 13.85 V
                    Fault Status: 01101010
                    Reset counter: 162
                    Mileage: 110766 km
                    Date: 2011.12.16
                    Time: 10:34:26
                        Term 15 On
                    Voltage: 11.80 V
                    Reset counter: 209
                    Mileage: 110766 km
                    Date: 2011.12.16
                    Time: 09:37:38
                        Term 15 On
                    Voltage: 12.35 V
                    Reset counter: 213
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 13:12:06
                        Term 15 On
                    Voltage: 11.80 V
                    Reset counter: 166
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 12:13:15
                        Term 15 On
                    Voltage: 11.75 V
                    Reset counter: 206
                    Mileage: 110766 km
                    Date: 2011.12.16
                    Time: 10:34:26
                        Term 15 On
                    Voltage: 11.80 V
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 166
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 13:37:50
                        Term 15 On
                    Voltage: 11.65 V
                    Reset counter: 208
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 16:30:46
                        Term 15 Off
                    Voltage: 12.05 V
                    Fault Frequency: 60
                    Reset counter: 213
                    Mileage: 106728 km
                    Date: 2017.05.11
                    Time: 13:26:26
                        Term 15 On
                    Voltage: 12.05 V
                    Reset counter: 203
                    Mileage: 110767 km
                    Date: 2011.12.23
                    Time: 07:56:11
                        Term 15 On
                    Voltage: 11.40 V
                    Fault Frequency: 19
                    Reset counter: 167
                    Mileage: 110766 km
                    Date: 2011.12.16
                    Time: 09:51:52
                        Term 15 Off
                    Voltage: 12.35 V
                    Fault Frequency: 21
                    Reset counter: 173
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 12:13:19
                        Term 15 On
                    Voltage: 11.85 V
                    Reset counter: 162
                    Mileage: 110766 km
                    Date: 2011.12.16
                    Time: 10:34:30
                        Term 15 On
                    Voltage: 13.75 V
                    Reset counter: 166
                    Mileage: 110769 km
                    Date: 2012.01.21
                    Time: 12:13:15
                        Term 15 On
                    Voltage: 11.70 V
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                    Reset counter: 173
                    Mileage: 110810 km
                    Date: 2012.01.27
                    Time: 14:15:40
                        Term 15 On
                    Voltage: 13.10 V
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                    Reset counter: 173
                    Mileage: 110810 km
                    Date: 2012.01.27
                    Time: 14:15:40
                        Term 15 On
                    Voltage: 13.10 V
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 173
                    Mileage: 110810 km
                    Date: 2012.01.27
                    Time: 14:15:40
                        Term 15 On
                    Voltage: 13.00 V
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM01SU44
   Coding: 00003937
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3449F50A9F862DE65E-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100007C8F0B
   Coding: 303245
   Serial number: 3572MSME192B1262ZZZR
   Serial number: 3582MSME772C7161ZZZ.
   Serial number: 3516KSME291F5012ZZZO
   Serial number: 3526KSME39265312ZZZL
   Serial number: 3556LSME09211712ZZZH
   Serial number: 3566LSME6F5A3212ZZZ$
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20110614300276
   Coding: 089A140000
   Shop #: WSC 00066 000 00187
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76CD0F02C97A7FF6A0-8022
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Coding: 830000
   Part No SW: 5C6 920 971 B    HW: 5C6 920 971 B
   Component: KOMBI         H04 0617
   Coding: 271E01
   Shop #: WSC 00066 000 00118
   VCID: 2C79ED6A47B6752606-8078
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 06091101290627
   Coding: 351002
   Shop #: WSC 64979 001 1048576
   VCID: 3851C13A8BEEC98672-806C
   Part No SW: 561 919 965     HW: 561 919 965
   Revision: 00001000    Serial number: 1829227R046005
   VCID: 63EB4656A2E8FA5EF7-8036
   Component: IMMO          H04 0617
   VCID: 6AF52B728DC2AB1634-803E
   Revision: A1001003    Serial number: 7660408300
   VCID: 2977147E4044600EFD-807C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3449F50A57862DE65E-8060
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K 0362
   Revision: --------    Serial number: BP225319948226
   VCID: 3041F91A6B9E11C63A-8064
   Component: EZE_2         H40 1620
   Coding: 01030100
   VCID: 6FC33A66BE204E3E63-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH0002SAFP
   Coding: 180000
   Part No SW: 561 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0003299509
   Coding: 0004B4
   Shop #: WSC 01383 790 50316
   VCID: 5C997DAA5796C5A6B6-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1508
   Serial number: 00000006033705
   Coding: 000490
   Part No SW: 1K0 035 180 AD    HW: 1K0 035 180 AD
   Component: Radio Prem-8  H04 0018
   Revision: -----17S    Serial number: VWZ4Z7L3192332
   Coding: 0102000001
   Shop #: WSC 00066 123 12345
   VCID: 62E543527DF2F356FC-8036
            000 -  -
                    Reset counter: 60
                    Mileage: 90572 km
                    Date: 2016.01.22
                    Time: 16:25:50
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660558605
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 354FC80E94FC34EE69-8060
End-------------------------(Elapsed Time: 02:22)--------------------------
Thoughts? Any help is very much appreciated! :banghead::beer:
zedo
C?ID=215712
I'm sorry I forgot to mention that I also have OEM LED tail lights installed, in case that affects the coding requirement, particularly for byte 18. These tail lights have worked fine for two years with my current coding. Don't want to mess that up either!
zedo
C?ID=215712
Oh, apologies but I just thought of yet another detail that may or may not be relevant. I am using a euro headlight switch and I previously retrofitted rain and light sensors without issue.
m87a
Bosnia and Herzegovina
C?ID=156900
you will have to play with byte 18 to get everything to work as is
zedo
C?ID=215712
I assumed that would likely be part of the solution, however because of my experience bricking the BCM last time I tried a bunch of different settings for 18, I am hesitant to do too much with it until I find better guidance. I already did try a couple different settings with no success.
zedo
C?ID=215712
Alright, so here is where I stand:
2012 Jetta GLI Autobahn halogens
Working correctly and installed a while ago:
Retrofitted LED tails w/ no fogs
Retrofitted rain/light sensor
Euro switch
Problematic retrofit of OEM Xenons:
Installed 10-12 pin adapter from Kufatec
Enabled appropriate settings in central electronics 9
Lights turn on and high beams function properly via shutter.
LED DRLs do not turn on (one setting for byte 18 turned them on as parking lights so I know they are getting power)
No parking/side lights error warning, parking/side lights do not activate
I have not installed the leveling sensor or other external components. At this time I want to just get the lights functioning normally and may install level sensor later.
Here is my latest scan after clearing out old errors:
Friday,08,September,2017,16:20:53:48450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
VCDS Version 17.8.0.1
VIN: 3VW4A7AJ3CM048038   License Plate: SEPT8-2
Mileage: 110870km-68891mi   Repair Order:
          72 77
VIN: 3VW4A7AJ3CM048038   Mileage: 110870km-68891miles
   VCID: 3957C43E70E4D08E8D-806D
Readiness: 1110 1101
   VCID: 181121BA2B2EE98652-804D
   Revision: 00H31001
   VCID: 7BDB1E36FA58229EDF-802F
   Revision: BJ011001
   Coding: 2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040
   VCID: 3D5FD02EA4CCECAEA1-8069
   Coding: 0330AD
                    Reset counter: 179
                    Mileage: 110872 km
                    Date: 2012.01.30
                    Time: 16:10:48
                        Term 15 On
                    Voltage: 13.65 V
                    Reset counter: 179
                    Mileage: 110872 km
                    Date: 2012.01.30
                    Time: 16:10:48
                        Term 15 On
                    Voltage: 13.55 V
                    Reset counter: 179
                    Mileage: 110872 km
                    Date: 2012.01.30
                    Time: 16:10:48
                        Term 15 On
                    Voltage: 13.55 V
Address 15: Airbags
   Coding: 271E01
   VCID: 2C79ED6A47B6752606-8079
   Coding: 351002
   VCID: 3851C13A8BEEC98672-806D
   VCID: 63EB4656A2E8FA5EF7-8037
Address 25: Immobilizer
   VCID: 2977147E4044600EFD-807D
   Revision: 00H20000
   VCID: 3449F50A57862DE65E-8061
   Component: KonzernAmp10K H06 0362
   VCID: 3041F91A6B9E11C63A-8065
   Coding: 01030100
   VCID: 6FC33A66BE204E3E63-803B
   Coding: 180000
   Coding: 0004B4
   VCID: 5C997DAA5796C5A6B6-8009
   Slave Passenger:
   Coding: 000490
   Coding: 0102000001
   VCID: 62E543527DF2F356FC-8037
            000 -  -
                    Reset counter: 179
                    Mileage: 110872 km
                    Date: 2012.01.30
                    Time: 16:10:44
End-------------------------(Elapsed Time: 01:52)--------------------------
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C208841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C208841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C978841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C978841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C048841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C048841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C068841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C068841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456CA08841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456CA08841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C028841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C028841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C038841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C038841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C548841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C548841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C558841A08D22F48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C558841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040,(64979/001/104857),
Address 09: DTCs cleared
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8457C008841A08D22E48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8457C008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009E8457C008841A08D22E48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009E8457C008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009E8457D008841A08D22E48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009E8457D008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D008841A08D22E48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D218841A08D22E48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D218841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D1F8841A08D22E48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D1F8841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C00040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C08040040,(64979/001/104857),
Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C08040040,to,2F200ABAE02F06C480080000250009A8456D068841A08D22E48C00040040,(64979/001/104857),
I have been unable to locate a list of hex settings for byte 18 to help find the right combination. Does such a list exist anywhere? Anyone have any other suggestions on coding changes?
Thanks for any help!
m87a
C?ID=156900
try byte 18: 88
also you could try 53, 55, 8C and report
zedo
C?ID=215712
Great thanks for the suggestions! I'll go try them shortly.
zedo
C?ID=215712
None of those worked properly, unfortunately. When I do Eos ROW I can get the LEDs to come on as parking lights but not as DRLs/automatic via light sensor and the parking/side/corner lights also don't come on and I get error warnings. :confused:
try byte 18: 88
m87a
C?ID=156900
which hex value?
also try 14, 2B, 40, 4C, 8D
zedo
C?ID=215712
Wow, ok, I tried those but alas no luck. I dug around and finally found a byte 18 list but it's hard to understand and none of the DOZENS of codes I tried worked. Still get various errors. I can get the DRLs to come on as parking lights, that's as close as I can get.
which hex value?
zedo
C?ID=215712
Welp. Now my BCM is bricked. Any magic solutions to fix besides just leaving unplugged for a while? This is a never ending nightmare. All because someone hit my car. :banghead:
hadez16
C?ID=289891
With bricked you mean....?
zedo
C?ID=215712
Fried. Address 9 unreachable. Car electronics such as lights, wipers, locks, etc. all totally haywire. :cry:
I'm guessing this cannot be salvaged but I'd love to hear if any experts have thoughts. Nobody from Ross Tech has chimed in on my thread thus far :(
I've already ordered a replacement (used) but it will take time to get here and although the car drives no lights work including turn signals.
The Mk.6 generation of BCMs is a total PITA. It's as if VW spec'd them to fail if you try too hard with Byte 18.
zedo
C?ID=215712
Not to mention 10,000 versions of what is supposedly the same part, each with different esoteric and totally indecipherable part numbers, which, if you "mess up" (ps what action constitutes is also unknown), either your car will have a wonderful bevy of new features all for free, or your car may explode.
Fun.
So Uwe once I get the new BCM... any suggestions for coding OEM Xenon's onto a halogen-equipped 2012 Jetta GLI w/ already retrofitted RLS, euro switch and LED tails? I am also using a Kufatec halogen to xenon adapter.
Also, anyone want to buy a red 2012 GLI? It's got fresh paint on the front bumper!
If I did, I would have posted them already. :D
vastechnics
C?ID=143747
Have you already installed other bcm? The taillights are ROW. I have the good codingg for the total package but I need to know this. And the BCM must be at least software level 0173 to get the taillights work without fault.
Let me know.
zedo
C?ID=215712
Let me know.
I haven't installed the new BCM, I am waiting for it to arrive tomorrow hopefully. This is what I purchased, I hope this is correct!
Thanks for your help! Functional coding would be so wonderful at this point :D
