Hey folks. Some idiot crashed into my car ('12 Jetta GLI) while it was parked and among other things I had to replace the headlights. I got OEM bi-xenons and had the repair shop install them. I purchased Kufatec adapters for 10 to 12 pin halogen to xenon which have enabled me to turn on the lights and activate the high beam shutter. Unfortunately no matter how I code with VCDS I can't get the LED DRLs to come on and I'm getting a bunch of bulb out warnings. I did not install any of the AFS/leveling components at this time. Right now I just want to get the DRLs to work and remove the error warnings.
I know there are many postings on this topic. I have read through all the threads I could find but thus far haven't found a solution. Some posts indicated that it may be necessary to create a bridge between two of the pins on the harness to provide power to the DRLs but I'm not sure how to do that nor do I wish to damage anything. I'm also not sure that is the correct solution.
I've been through coding nightmares before and I know how finicky it can be... hoping an expert might be able to offer recommendation. I previously very brilliantly bricked my BCM while doing a different xenon retrofit of aftermarket assemblies. I am very wary about messing with byte 18 now.
I enabled all the appropriate bits in VCDS, tried different combinations, changed the region setting for the lights, etc. to no avail.
Do I need to make further coding changes or do I need to perhaps bridge pins 10 and 12 as mentioned in some other threads? If so, how do I do that? I don't want to fry the electrics.
Here is my scan. Some of the lights errors are old but still in computer while some errors remain active and are related to the retrofit problem.
Thoughts? Any help is very much appreciated!
:beer:
Tuesday,05,September,2017,15:01:51:48450
VCDS Version: 17.8.0.1
VIN: 3VW4A7AJ3CM048038 License Plate: 090517
Mileage: 110850km-68878mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 4F 52 56 62
72 77
VIN: 3VW4A7AJ3CM048038 Mileage: 110850km-68878miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 997 029 E HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 03 1510
Revision: PAH04--- Serial number:
Coding: 040301081C070160
Shop #: WSC 04881 002 1048576
VCID: 3957C43E70E4D08E8D-806C
Part No SW: 02E 300 057 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2730
Revision: 05351113 Serial number: 00001103201160
Shop #: WSC 00066 000 00000
VCID: 181121BA2B2EE98652-804C
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: A14B600C49260002850B06E792210041A70800
VCID: 7BDB1E36FA58229EDF-802E
02214 - Tire Pressure Warning
Reset counter: 183
Mileage: 110220 km
Date: 2011.11.06
Time: 16:25:35
Count: 32768
Count: 4608
Count: 16401
Count: 48897
Count: 251
Address 08: Auto HVAC
Part No SW: 5K0 937 086 L HW: 5K0 937 086 L
Component: BCM PQ35 M 011 0048
Revision: BJ011001
Coding: 2F200ABAE02F06C480080000250009E8456C008841A08D22E48C00040040
Shop #: WSC 64979 001 104857
VCID: 3D5FD02EA4CCECAEA1-8068
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 200914 05 54 0403
Coding: 0330AD
25 Faults Found:
Fault Status: 00100111
Reset counter: 213
Mileage: 110810 km
Date: 2012.01.27
Time: 13:22:60
Voltage: 13.70 V
Fault Status: 00101010
Reset counter: 213
Mileage: 110766 km
Date: 2011.12.16
Time: 10:34:27
Voltage: 12.70 V
Reset counter: 213
Mileage: 110810 km
Date: 2012.01.27
Time: 13:22:60
Voltage: 13.70 V
Reset counter: 213
Mileage: 110769 km
Date: 2012.01.21
Time: 10:51:59
Voltage: 11.85 V
00984 - Left Tail Light (M4)
Reset counter: 213
Mileage: 110769 km
Date: 2012.01.21
Time: 13:37:58
Voltage: 11.75 V
00985 - Right Tail Light (M2)
Reset counter: 213
Mileage: 110769 km
Date: 2012.01.21
Time: 13:37:58
Voltage: 11.75 V
Reset counter: 213
Mileage: 110769 km
Date: 2012.01.21
Time: 13:38:47
Voltage: 11.70 V
Fault Frequency: 8
Reset counter: 213
Mileage: 110769 km
Date: 2012.01.21
Time: 13:38:47
Voltage: 11.70 V
Reset counter: 213
Mileage: 110767 km
Date: 2011.12.23
Time: 07:56:18
Voltage: 13.85 V
01495 - Bulb for High-Beams; Left (M30)
Fault Status: 01101010
Reset counter: 162
Mileage: 110766 km
Date: 2011.12.16
Time: 10:34:26
Voltage: 11.80 V
Reset counter: 209
Mileage: 110766 km
Date: 2011.12.16
Time: 09:37:38
Voltage: 12.35 V
Reset counter: 213
Mileage: 110769 km
Date: 2012.01.21
Time: 13:12:06
Voltage: 11.80 V
Reset counter: 166
Mileage: 110769 km
Date: 2012.01.21
Time: 12:13:15
Voltage: 11.75 V
Reset counter: 206
Mileage: 110766 km
Date: 2011.12.16
Time: 10:34:26
Voltage: 11.80 V
01502 - Bulb for Rear Fog; Left (L46)
Reset counter: 166
Mileage: 110769 km
Date: 2012.01.21
Time: 13:37:50
Voltage: 11.65 V
Reset counter: 208
Mileage: 110769 km
Date: 2012.01.21
Time: 16:30:46
Term 15 Off
Voltage: 12.05 V
Fault Frequency: 60
Reset counter: 213
Mileage: 106728 km
Date: 2017.05.11
Time: 13:26:26
Voltage: 12.05 V
Reset counter: 203
Mileage: 110767 km
Date: 2011.12.23
Time: 07:56:11
Voltage: 11.40 V
Fault Frequency: 19
Reset counter: 167
Mileage: 110766 km
Date: 2011.12.16
Time: 09:51:52
Term 15 Off
Voltage: 12.35 V
Fault Frequency: 21
Reset counter: 173
Mileage: 110769 km
Date: 2012.01.21
Time: 12:13:19
Voltage: 11.85 V
Reset counter: 162
Mileage: 110766 km
Date: 2011.12.16
Time: 10:34:30
Voltage: 13.75 V
Reset counter: 166
Mileage: 110769 km
Date: 2012.01.21
Time: 12:13:15
Voltage: 11.70 V
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
Reset counter: 173
Mileage: 110810 km
Date: 2012.01.27
Time: 14:15:40
Voltage: 13.10 V
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
Reset counter: 173
Mileage: 110810 km
Date: 2012.01.27
Time: 14:15:40
Voltage: 13.10 V
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 173
Mileage: 110810 km
Date: 2012.01.27
Time: 14:15:40
Voltage: 13.00 V
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM01SU44
Coding: 00003937
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3449F50A9F862DE65E-8060
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100007C8F0B
Coding: 303245
Serial number: 3572MSME192B1262ZZZR
Serial number: 3582MSME772C7161ZZZ.
Serial number: 3516KSME291F5012ZZZO
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME39265312ZZZL
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME09211712ZZZH
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME6F5A3212ZZZ$
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110614300276
Coding: 089A140000
Shop #: WSC 00066 000 00187
ROD: EV_SMLSNGVOLWS.rod
VCID: 76CD0F02C97A7FF6A0-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Coding: 830000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5C6 920 971 B HW: 5C6 920 971 B
Component: KOMBI H04 0617
Coding: 271E01
Shop #: WSC 00066 000 00118
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 2C79ED6A47B6752606-8078
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 06091101290627
Coding: 351002
Shop #: WSC 64979 001 1048576
VCID: 3851C13A8BEEC98672-806C
Part No SW: 561 919 965 HW: 561 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1829227R046005
Coding: 0000002
VCID: 63EB4656A2E8FA5EF7-8036
Component: IMMO H04 0617
VCID: 6AF52B728DC2AB1634-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660408300
VCID: 2977147E4044600EFD-807C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 3449F50A57862DE65E-8060
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K 0362
Revision: -------- Serial number: BP225319948226
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 3041F91A6B9E11C63A-8064
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 01030100
VCID: 6FC33A66BE204E3E63-803A
Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Serial number: WRH0002SAFP
Coding: 180000
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0003299509
Coding: 0004B4
Shop #: WSC 01383 790 50316
VCID: 5C997DAA5796C5A6B6-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1508
Serial number: 00000006033705
Coding: 000490
Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
Component: Radio Prem-8 H04 0018
Revision: -----17S Serial number: VWZ4Z7L3192332
Coding: 0102000001
Shop #: WSC 00066 123 12345
VCID: 62E543527DF2F356FC-8036
Reset counter: 60
Mileage: 90572 km
Date: 2016.01.22
Time: 16:25:50
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660558605
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 354FC80E94FC34EE69-8060
End-------------------------(Elapsed Time: 02:22)--------------------------
