Went to a VW/Audi event yesterday where I observed a guy doing coding on a car for someone who was having an issue doing it himself. His friend remarked "if this guy can't fix it, no one can". Sure enough, about 10 mins later, he had indeed solved the problem for the other guy. I introduced myself, explained the key mismatch situation and he said "have you taken it into the shop?" I told him no, not yet. He said that he's an ex-dealer tech (or something) and that only the dealer can fix stuff like this, something about a token exchange that isn't implemented in VCDS or other aftermarket tools.
I'm sure Uwe will have an opinion about that (oh, he was also using a tool called OBD-eleven and said that it's more advanced than VCDS although the latest beta makes them about even). Anyway, just reporting, not trying to be incendiary
Meanwhile, I ordered a spare key and will try pairing that. And if all else fails, guess I'll have to try the dealer.
A "token exchange" for matching remotes on a 2006 8P A3? Sorry, but I don't think so.Went to a VW/Audi event yesterday where I observed a guy doing coding on a car for someone who was having an issue doing it himself. His friend remarked "if this guy can't fix it, no one can". Sure enough, about 10 mins later, he had indeed solved the problem for the other guy. I introduced myself, explained the key mismatch situation and he said "have you taken it into the shop?" I told him no, not yet. He said that he's an ex-dealer tech (or something) and that only the dealer can fix stuff like this, something about a token exchange that isn't implemented in VCDS or other aftermarket tools.
Of course. The remotes that won't marry are the original ones from the car (I bought it from the original owner). The replacement remote is a two year newer remote but same FCC ID (NBG 009272 T).Did you verify the remotes you are trying to marry are the correct part # for the ones that didn't work from the beginning .....just as a quality check?
When I sadi something I said form my experience , I do not do bla, bla talk.So, quick update. Used key from eBay arrived.
Set group 0 to 0, reset. Set remotes to 1. New remote works instantly.
Set group 0 to 0, reset. Set remotes to 3. New remote works instantly, old ones do not. All flash the turn signal lights on pairing but only the new one works.
So... the controller is obviously working. There's no token exchange. Something wrong with the old remotes as Marin and Dana suggested.
So, if I keep this remote, I'll need to physically move the key over to the new remote, then I'm not sure about the immobilizer - is it part of the key itself or in the remote? I suspect the latter which means I'll need to get the SKC from the cluster right?
But still Jack will not admit I was right , of course that is our Jack
When you open key , if is old remote shell in good condition then you can just transfer remote circuit board form new key , this way immobilizer will be OK.
You will need very small torx screwdriver like one they use form Iphone screen kit.
