Tuesday,23,April,2024,16:52:23:60815
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ7HZNH006670 License Plate: DU68AUS
Mileage: 37530km-23320mi Repair Order: 23042024
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 44 55 5F 65 69 6C 75 D6
D7
VIN: WV1ZZZ7HZNH006670 Mileage: 37530km-23320miles
Address 01: Engine (J623-DNAA) Labels: None
Part No SW: 05L 906 023 JG HW: 05L 907 309 F
Component: R4 2.0l TDI H80 2670
Revision: N1H80--- CVN: F19C03D9F3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
Coding: 001900340344050800000000000000000000000000000000
Shop #: WSC 09107 004 1048576
ASAM Dataset: EV_ECM20TDI01105L906023JG 006002
ROD: EV_ECM20TDI01105L906023JG.rod
VCID: 76B5E8CC5849E54A05F-8022
VINID: 9E606AAAA1D8A9E600006187007D68BD3B
Readiness: 0 0 0 1 1
Part No SW: 7LB 614 517 B HW: 7LB 614 517
Component: ESC_base H01 0800
Serial number: 08501132210616
Coding: 10552752C847E68B085AE4AB13666726393324B8
Shop #: WSC 00012 790 00028
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3FDB4DE837F36402169-806A
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7LA 907 426 E HW: 7LA 907 426 E
Component: AC Manuell H01 0602
Coding: B03110000810030001000800504001050000000000011000800000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 45D75F00552F3ED25C5-8010
Part No SW: 2Q0 937 090 D HW: 2Q0 937 090 C
Component: BCM A0 Std+ H12 0954
Serial number: 01102117601614 Dataset Number: V03935350KN 0001
ASAM Dataset: EV_BCMA0 207001
ROD: EV_BCMA0_207_SK26.rod
VCID: 333311D80BBBB062E21-8066
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y21M06D10H18M01S31
Coding: 0218EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000051439750
Coding: 1F0007
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000051408103
Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 A HW: 5Q0 951 172 B
Component: Sensor, DWA 005 0403
Serial number: 000000000ZL21138CMUD
Serial number: 00000000000049677542
590853 - Window Regulator; Front Drivers Side
B14D1 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:37
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.6 V
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057322038 Dataset Number: V03935360WN 0001
Coding: 8B71567941
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_010_AU37.rod
VCID: 58E98674B29DB33A373-800C
12658704 - Databus
[Steuerger t f r elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:37
12664896 - Databus
[Bildverarbeitung - ARA_Sensor_02 - kein Signal/keine Kommunikation]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:38
12727554 - Databus
[Steuerger t f r Heading-Control - Gateway_79.LDW_02_alt - kein Signal/keine Kommunikation]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:39
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935335RG 0001
Coding: 2A04601B01FF8748949C815560509700000000000000000004
Shop #: WSC 00012 790 00160
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D341185B1B00E2721-8016
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 016 0506
Revision: -------- Dataset Number: V03935338FP 0001
Coding: 8800C000000000007C0000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F5B0DE87773A402569-802A
Address 17: Instruments (J285) Labels:| 7LA-920-XXX-V1.clb-SRI3
Part No SW: 7LA 920 941 A HW: 7LA 920 941 A
Component: KOMBI 202 8500
Coding: 27A50A822488260001882A2D6401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 3E2530EC30F96D0A1DF-806A
U1014 00 [00001001] - -
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:36
16776996 - Databus
[FCW_01 keine Kommunikation]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:36
Part No SW: 3Q0 907 530 AL HW: 3Q0 907 530 E
Component: GW MQB High 524 5463
Serial number: 08062110802964 Dataset Number: V03935338SA 0001
Coding: 030100044F056A0000000058000F00010001070000000000000000000000
GVL: 014C3C0000000000C04090008002480000000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 79AFE3F069578A3268D-802C
Generator:
Component: 5-00-11-00-04
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440036155215438
Coding: 2C0D00
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 77343301002105250133
Address 29: Left Light
Address 39: Right Light
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 00000563861325 Dataset Number: V03935334PN 0001
Coding: A2A54640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F23F029D74A3228D-806C
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 00000564886889
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 G HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7160
Dataset Number: V03935340DA 0001
Coding: 0306
ASAM Dataset: EV_SteerAssisMNB 002015
ROD: EV_SteerAssisMNB.rod
VCID: 46D5580C682935CA55F-8012
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 0C8A020009200001
ROD: EV_HeadlRegulAFSMQBMAX_VN46.rod
VCID: 41DF4B10410712F260D-8014
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3CN 035 869 A HW: 3CN 035 869 A
Component: MU-E-D-ER 720 0920
Serial number: 18052100021852 Dataset Number: V03935343RV 0001
Coding: 06570000AA00000041111101008002001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 44D142045E1507DA4BB-8010
0512 - Rear Right Bass Speaker
B1067 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:38
Voltage terminal 30: 12.5 V
0517 - Front Right Bass Speaker
B1062 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:38
0522 - Front Left Bass Speaker
B105F 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:38
0527 - Rear Left Bass Speaker
B1065 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:38
Part No SW: 5Q0 907 273 D HW: 5Q0 907 273
Component: RDKBERU30 H06 0010
Serial number: 30000000707352
ROD: EV_RDKBERU30_VW41.rod
VCID: 363528CC18C9A54AC5F-8062
12652550 - invalid data record
B2005 00 [00001001] - -
Reset counter: 46
Mileage: 37530 km
Date: 2024.04.23
Time: 16:45:05
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H0 907 383 C HW: 5H0 907 383
Component: Anhaenger H12 0058
Serial number: 000000000006247
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 2E0500ACE0999D8A8DF-807A
Component: RVC Compact H18 0231
Dataset Number: 81A909460E 0001
Coding: 0123010103002017000040
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0092
Serial number: 0000000105NVTD1 Dataset Number: V03935344U 0001
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW27.rod
VCID: 015F8B100187D2F220D-8054
1572115 - LTE Antenna 1
B17FD 13 [00001001] - Open Circuit
Mileage: 37530 km
Date: 2024.04.23
Time: 16:44:39
Part No SW: 992 941 571 AA HW: 992 941 571 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 619FAB90E1C772F240D-8034
Component: LED1R H08 9002
End----------(Elapsed Time: 01:40, VBatt start/end: 12.2V/12.5V)-----------
