Klimatronic error vw touareg gp R5TDI 2008
klf
Pirate
Walking the Plank
Russia
Hi.
VCDS gave this error:
Контроллер 08: Климат-контроль Описания: 7L6-907-040.clb
Номер детали: 7L6 907 040 AF
Компонент:: CLIMAtronic R/L 4331
Кодировка: 0000020
Код сервиса:: WSC 31414 790 00001
VCID: 74EDCBA0130D81BE80B-8021
1 Ошибка найдена:
00003 - Блок управления
014 - Неисправно
Момент неисправности:
(нет данных): 2.0
Температура: 3.0°C
Температура: 23.0°C
Об/мин: 0 /min
There were two errors.
one disappeared after connecting the sensor to air pollution (before it was turned off)
but this stayed
the system itself works correctly...
what is this error?
klf
Pirate
Walking the Plank
Russia
We're done here.
GaryM
Oxford, UK
C?ID=226919
Even with the poor Rouble exchange rate, 4500 RUB (~68 USD) is way too cheap for a genuine VCDS cable. If you want to check, download the latest v14.10.1 release of VCDS...
Then run VCDS with the cable connected and do a firmware update on the cable when prompted to do so. If it fails then you have a counterfeit cable and should send it back to the supplier for a full refund.
EDIT: This is the expected amount you would be paying from an authorised VCDS distributor...
