CECM Swap to high
Tristan1412
New Member
Spain
samebody know if it is posible to swap medium cecm to high cecm (5k0 937 087 ab) manteining the halogens bulbs (instead xenon)? Thanks very much.
downtime
C?ID=280813
Yes. Record current BCM coding by taking screenshots NOT by just copying the code. Highline BCM has more bytes so coding is different.
Do the physical swap and code the new BCM manually.
Tristan1412
New Member
Spain
Thank you!! I will code manually.
Tristan1412
New Member
Spain
My car is an european VW Touran (year 2014) with halogen bulbs and 434mHz frecuency. Now I have a BCM Medium 5k0937086Q... According to etka, the high bcm would be 5K0937087AB or other reference? Thanks
Spacewalker
C?ID=159607
Please wait till Rosstech check your VCDS number, and then we can talk
