Hello everyone.
This is my "almost" first message ;-)
My English will not always be perfect and I apologize for any mistakes :-)
I recently have a VW PASSAT B7 Variant (365) 1.4 TSI EcoFuel from 2013 + DSG in a high version but I miss a few things that I would like to modernize successively.
I have already managed to encode some of them in the original VCDS version.
Now let's deal with my problem.
The main thing he does is install the active cruise control (ACC). In my version I have to replace and add a few things.
I started by replacing the MF Cruise Control Stalk Wiper Switch & Module - 5K0953569T
After the exchange, I made the basic setting of the steering angle according to the instructions in WIKI.
There are several errors that I can't deal with and I need help. At the very bottom I will post a full scan but before that I would like to tell you about the next stages that I plan.
After replacing and getting rid of any errors, I would like to run the normal cruise control until I replace the ABS pump and mount the radar and harness.
I did CCS coding but it doesn't work properly. I checked in the measuring blocks of group 66 and after switching on ON the following value appears to me 00000001 and I read somewhere that there should be two ones at the end, i.e. 00000011
I wonder if CCS does not work because of these errors or something is faulty and to be replaced?
Let's deal with the first liquidation of errors and then the launch of CCS and the subsequent stages to launch ACC
I would also like to activate the tire pressure sensor. I have installed sensors in the wheels but the system is not working properly. I need to find out if my car has a TPMS driver module - 3AA907273D. If it is not present, can someone show me the location where it should be mounted and should there be a bundle in this place or should I pull the cables?
Thank you in advance to everyone for your support and good word that will direct the solution.
Maciej
Thursday,14,November,2019,22:07:11:24806VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZDE143770 License Plate:
Mileage: Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 37 42 44 46 4C 4F 52 53
55 56 5C 61 62 65 6C 72 77 A5
VIN: WVWZZZ3CZDE143770 Mileage:
5C-Lane Maintain. -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
Address 01: Engine (CDG) Labels: 03C-906-021-CDG.clb
Part No SW: 03C 906 021 Q HW: 03C 907 309 D
Component: 4414 CNG 14K31 G 6368
Revision: E8H06--- Serial number: VWZCZ000000000
Coding: 0000077
Shop #: WSC 27360 000 1048576
VCID: 291AEBE98099C407D0-807C
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - Intermittent
Mileage: 205965 km
Date: 2014.04.06
Time: 00:03:24
RPM: 740 /min
Load: 12.2 %
Temperature: 83.0°C
Temperature: 44.0°C
Absolute Pres.: 950.0 mbar
Voltage: 12.700 V
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal - Intermittent
Mileage: 205965 km
Date: 2014.04.06
Time: 00:27:13
RPM: 720 /min
Load: 20.0 %
Temperature: 90.0°C
Temperature: 56.0°C
Voltage: 13.208 V
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Fault Frequency: 9
Mileage: 205965 km
Date: 2014.04.06
Time: 00:27:17
RPM: 735 /min
Load: 20.8 %
Temperature: 90.0°C
Temperature: 54.0°C
Voltage: 13.970 V
Readiness: 0010 0001
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5279
Revision: 00043014 Serial number: CU501505296123
Shop #: WSC 30268 001 1048576
VCID: 3E3028B5691753BF95-806A
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AQ HW: 3AA 614 109 AQ
Component: J104 C2 450M VD47 0030
Revision: --H07--- Serial number: 00000006844616
Coding: 0132465
Shop #: WSC 21354 231 45312
VCID: 7CB4E2BD3F8B81AFFB-8028
Part No SW: 3AA 907 044 AJ HW: 3AA 907 044 AJ
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004802
VCID: 78BCFEADC3B3AD8F9F-802C
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 Q HW: 3AA 937 087 Q
Component: BCM PQ47 H+ 422 0474
Revision: BC422001
Coding: 000A000000000000009802887400297427D54B88636DAD60E48046240041
VCID: 48DC4E6DFBD31D0F2F-801C
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 25021 10 0603
Coding: 00B795
Component: RLS 150313 05 54 0403
Coding: 06302A
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261307502042
Coding: 348106
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 44C45A5DCFFB396FC3-8010
Part No SW: 5N0 959 655 AE HW: 5N0 959 655 AE
Component: J234__10H VW10 HI 2318
Revision: 27019000 Serial number: 003N5P3LW76$
Coding: 0012360
Shop #: WSC 05311 000 00000
VCID: 004C964D5363E54FA7-8054
Subsystem 1 - Serial number: 6332MTS630410633
Subsystem 2 - Serial number: 6342MTS621680633
Subsystem 3 - Serial number: 6351HTS620FCRBKR
Subsystem 4 - Serial number: 6361HTS6CJ52RBKJ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0135
Revision: FF010036 Serial number: 20100703201071
Coding: 399A250001
VCID: 75A2F799D4A1D0E784-8020
Component: E221__MFL-TK6 H07 0022
Coding: E30000
Part No SW: 3AA 920 880 J HW: 3AA 920 880 J
Component: KOMBI H05 0505
Coding: 161F01
VCID: 3A3824A5BD3F7F9FA9-806E
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Reifendrucküberwachung: keine Kommunikation]
Reset counter: 70
Mileage: 205982 km
Date: 2019.11.14
Time: 01:19:42
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 5K0 963 272 B
Component: Standheizer 022 3907
Revision: 00022000 Serial number: 09020188000000
Coding: 0031032
Shop #: WSC 35410 001 1048576
VCID: 2F2E05F1BE7DAA370E-807A
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 200313F1003004
Coding: 462006
VCID: 78BCFEADCBB3AD8F9F-802C
Reset counter: 70
Mileage: 205982 km
Date: 2014.04.06
Time: 01:19:47
02797 - Control Module for Directional Stabilization Assistance (J759)
Reset counter: 70
Mileage: 205982 km
Date: 2014.04.06
Time: 01:19:43
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 043 0404
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 383C3EAD4B336D8F5F-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H11 5274
Revision: AB001001 Serial number: VWZ6Z7T0094028
Coding: 04000402040000A02011
Shop #: WSC 35104 001 1048576
VCID: 3B3621A1BA054697B2-806E
Component: EU West V9 7918
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0006733303
Coding: 0010FF
Shop #: WSC 05311 115 00000
VCID: 35223799942190E744-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 B HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0503
Serial number: 00000003385025
Coding: 0100D8
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.309 1401
Revision: 1BH04739 Serial number: 00151970032101
Coding: 0000258
VCID: 41CA534918E92C47E8-8014
Component: KSG PQ47 ELV 043 0638
Coding: 00910A0052830E76340A941570084F0B605800
Part No SW: 7N0 907 532 HW: 7N0 907 530 AJ
Component: EZE_2 H51 1634
Coding: 050B0508
VCID: 6FAEC5F1BEFDEA374E-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0006724988
Coding: 0010FE
VCID: 3620309589279BFF4D-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 B HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0503
Serial number: 00000003365562
Coding: 0100D8
Revision: H19 Serial number: 00000000866854
Coding: 0022157
VCID: 3620309541279BFF4D-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 021200000B000200
VCID: 373E3D918E2D62F756-8062
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0012
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H04 0012
Coding: 230000
Address 5C: Lane Maintain.
Part No SW: 7N0 907 534 HW: 7N0 907 530 AJ
Component: Batt.regelung H51 1634
Coding: 33260864
VCID: 71AAC389A8C9FCC758-8024
Component: J367-BDM H07 0180
Serial number: 40082527551490303795
Address 65: Tire Pressure
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525PA8-J4Z0185
Coding: 0020007
VCID: 689CAEED5B133D0F0F-803C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 70
Mileage: 205982 km
Term 15 On
Reverse OFF
Count: 3
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603550691
Coding: 020100000000000000000000
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_A02.rod
VCID: 2306F9C12AB51E579A-8076
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0193033225
Coding: 010101010102020D0200000000010000
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
VCID: 393A3BA9B8397487A0-806C
End----------(Elapsed Time: 01:56, VBatt start/end: 12.1V/12.0V)-----------
Maciej
