Immobilizer measuring blocks ERROR
Warmshoe
C?ID=44235
2001 TTQ has (recently) new battery. Worked OK for some time but now will not start. Has a 17978 Engine Start Blocked by Immobilizer code. Cleared the code and it doesn't come back after subsequent start attempts (also still doesn't start). Went to check the measuring blocks (link below) and it showed "ERROR: Group xxx Not Available" for the ones shown 022, 023, 024 and surfed around to discover some but all were ERROR. How can I see these values?
Also, checked clutch switch and it changes state. Car key arms immobilizer when car is locked (red LED flashes). Will also try key #2 when I get my hands on it (currently it is out of town).
And... any other advice for success (have not shorted battery cables together yet)?
https://www.ross-tech.com/vag-com/cars/Immo3-measuring-blocks.html
Please advise,
Jon
Are you checking those blocks in 25-Immobilizer? IIRC on that car, you need to look in 17-Instruments instead.
Bruce
Near Philadelphia, PA, USA
Sorry to hear of your troubles. Could you post a complete autoscan of the TTQ please? We'd like to see what VCDS is seeing...
Warmshoe
C?ID=44235
Good call and thank you, was incorrectly looking at 25. Here are results for 17-Instruments:
Measuring Block - Values
022 - 1114
023 - 1116
024 - 0000
And scan:
Sunday,01,December,2019,16:23:54:02845
VIN: TRUWT28N211022421   License Plate:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine        Labels: 06A-906-032-AMU.lbl
   Part No: 8N0 906 018 K
   Component: 1.8L R4/5VT     G   0003
   Coding: 06710
   Shop #: WSC 01236
   VCID: 392F2DA12049231FCD7-513C
   TRUWT28N211022421     AUZ5Z0YN153207
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
   Part No: 8N0 907 379 E
   Component: ESP     20    CAN  V005
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E253EBD39670427F85-4B00
01324 - Control Module for All Wheel Drive (J492)
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 2809F8E5CBE3AA97A29-2580
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Address 15: Airbags        Labels: 8N8-909-601.lbl
   Part No: 8N8 909 601
   Component: Airbag Front+Seite 1005
   Coding: 10103
   Shop #: WSC 01236
   VCID: 77ABEB9956DDF56FFB3-50F4
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 930 J
   Component: KOMBI+WEGFAHRS. M73 D55
   Coding: 02244
   Shop #: WSC 02101
   VCID: 382928A51B433A17329-4B00
01039 - Coolant Temperature Sensor (G2)
            30-00 - Open or Short to Plus
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 1F1BE3399EAD6D2FD33-4B00
01312 - Powertrain Data Bus
            37-10 - Faulty - Intermittent
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N8 962 267 A
   Component: Central Lock/Alarm  D05
   Coding: 15884
   Shop #: WSC 01236
   VCID: 3FDB43B93E6D0D2FF33-4F0C
01616 - Signal Wire to Interior Monitor
            36-10 - Open Circuit - Intermittent
   Part No: 8N8 951 177
   Component: Innenraumueberw.    D09
   Coding: 00001
   VCID: 7CA1F4B56FFBD637961-50F4
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 6597B1D1FC7177FF59F-5184
End----(Elapsed Time: 02:38, VBatt start/end: 11.8V/11.7V. VIgn 11.6V)-----
Warmshoe
C?ID=44235
Thank you, see above...
MartinsX
Riga, Latvia
C?ID=268515
Car does not crank or cranks but does not start?
MartinsX
Riga, Latvia
C?ID=268515
In this model immo does not affect starter control.
Check starter, wiring to it, IGN switch terminal 50.
I believe 35-Central Locking can keep it from cranking if it thinks the car has not been unlocked appropriately.
