Has anyone else dealt with this error on the revised 1.4TSI Dual charged engines with low pressure issues?
i have 2 different ones with the same 2009 CAVD engines that have this problem.
the oil pressure gauge starts at 1.8Bar when cold then drops to 0.2Bar at full operating temperature. so i am sure it is an actual low pressure fault and
not a faulty sender.
On the first one i've replaced:
Oil pump (checked and cleaned the pickup first)
Main and conrod bearings. (clearances are within 0.05.mm)
Crankshaft!
Stripped and rebuilt the engine after flushing it with flushing oil and replacing the oil filter (4 times)
1 conrod was replaced earlier.
Using Gulf fully synthetic oil that is SAE 40 and on the VW approved list for the 502 00/ 505 00 list
Ive used SAE 50 oil which masked the fault but you'd hear the tappets rattling when hot.
anyone know if theres known issues on this engine?
the scan is below if anyone is interested.
Crankshaft!
Monday,03,October,2016,16:19:32:58772VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: WVWZZZ1KZ9U017684 License Plate: KCD 880C
Mileage: 84830km-52710mi Repair Order: naushad
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9U017684 Mileage: 84830km-52710miles
Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
Part No SW: 03C 906 027 BA HW: 03C 906 027 F
Component: MED17.5.5 G 8913
Revision: L1H08--- Serial number: VWX7Z0H624K0D5
Coding: 0000077
Shop #: WSC 73340 981 67656
VCID: 61CF4765B8AC3E4AC7-8034
7 Faults Found:
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 000 - Slow Response - Intermittent
Fault Frequency: 114
Mileage: 84593 km
Time: 14:41:32
RPM: 1133 /min
Load: 29.0 %
Speed: 10.0 km/h
Temperature: 87.0°C
Temperature: 38.0°C
Absolute Pres.: 820.0 mbar
Voltage: 13.589 V
P0300 - 000 - - Intermittent
Mileage: 84820 km
Time: 18:02:31
RPM: 893 /min
Load: 27.8 %
Temperature: 62.0°C
Temperature: 33.0°C
Voltage: 13.716 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent
Mileage: 84646 km
Time: 11:04:45
RPM: 887 /min
Load: 19.6 %
Temperature: 49.0°C
Temperature: 29.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.970 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Mileage: 84820 km
Time: 18:02:31
RPM: 893 /min
Load: 27.8 %
Temperature: 62.0°C
Temperature: 33.0°C
Voltage: 13.716 V
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow
Mileage: 84687 km
Time: 12:57:04
RPM: 1469 /min
Load: 18.4 %
Speed: 45.0 km/h
Temperature: 87.0°C
Temperature: 42.0°C
Voltage: 13.589 V
004256 - Control Circuit for Intake Air Regulating Flap
P10A0 - 000 - Electrical Malfunction - MIL ON
Fault Status: 11100000
Mileage: 84832 km
Time: 15:05:13
RPM: 913 /min
Load: 15.7 %
Temperature: 84.0°C
Temperature: 54.0°C
Voltage: 12.700 V
P10A0 - 000 - Electrical Malfunction - Intermittent
Mileage: 84826 km
Time: 09:27:00
RPM: 1420 /min
Load: 52.9 %
Speed: 33.0 km/h
Temperature: 84.0°C
Temperature: 32.0°C
Voltage: 13.589 V
Readiness: 0010 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2668
Revision: 00043014 Serial number: CU501303067011
Shop #: WSC 73340 981 98115
VCID: 3B73D50D7A80349ABD-806E
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 133B600D21230001C81106EC841D0080B100
Shop #: WSC 00046 412 00000
VCID: 75E70335DC24A2EA8B-8020
01169 - Door Contact Switch Driver Side (F2)
Reset counter: 149
Mileage: 84597 km
Count: 16384
Count: 32768
Count: 12800
Count: 147
Count: 48414
Count: 1091
Part No SW: 1K0 907 044 CT HW: 1K0 907 044 CT
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 7BF3150D3A00F49AFD-802E
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000008808549
Coding: E4850F2700041500470A00000F000000000959035C000100000000000000
Shop #: WSC 00046 412 31414
VCID: 326DF829ADCAF5D26E-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 131108 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 140808 046 0204
Coding: 00733221
Shop #: WSC 00046
02389 - Release Signal Transmission; Position P/N
Reset counter: 146
Mileage: 84583 km
Voltage: 13.05 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 56 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BUU2K
Coding: 0013622
VCID: 6CD126514F6E632264-8038
Subsystem 1 - Serial number: 6332MSME3F612C67N
Subsystem 2 - Serial number: 6342MSME3E320C77K
Subsystem 3 - Serial number: 6351HSME1819212D4
Subsystem 4 - Serial number: 6361HSME181832630
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 752 0101
Coding: 0010041
Shop #: WSC 00000 000 31414
VCID: 03036DED42F08C5AB5-8056
Part No SW: 1K0 920 864 A HW: 1K0 920 864 A
Component: KOMBIINSTRUMENT 3HL 1212
Revision: V0002000 Serial number: VWX7Z0H624K0D5
Coding: 0019503
Shop #: WSC 73340 981 187765
VCID: 2A5DE049851ABD12D6-807E
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 240808F2001293
Coding: ED807F060002021003
VCID: 3567C3355CA4E2EA4B-8060
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1520
Revision: 71009005 Serial number: 00000056988523
Coding: 0004790
VCID: 71EF3725684C8ECA57-8024
Fault Status: 00100101
Reset counter: 153
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 91900A0001060C7F2D04840560081F03E0FCA0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1520
Revision: 71009005 Serial number: 00000514288502
Coding: 0005046
VCID: 72ED38296D4AB5D2AE-8026
Reset counter: 151
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Fault Status: 00101100
Fault Frequency: 251
Reset counter: 172
Mileage: 84587 km
Fault Status: 00111000
Fault Frequency: 84
Reset counter: 172
Mileage: 84587 km
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 183 HW: 1K0 035 183
Component: Radio RCD310 012 0029
Revision: 00000000 Serial number: VWZ1Z2H5715334
Coding: 0500040004
VCID: 60C9426173A63742C8-8034
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000003058300
Coding: 0000144
VCID: 3D77DB1564943AAA83-8068
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000003091886
Coding: 0000144
Shop #: WSC 00046 000 31414
VCID: 3E75DC19699221B29A-806A
End-------------------------(Elapsed Time: 02:14)--------------------------
