hi guys so abs long coding has been deleted now its shows 0000000.....
whats the spolutions??? dealers price local garage just howwww?????
here is full scan
here is full scan
Thursday,26,January,2017,16:16:06:38492
VCDS Version: 16.8.4.2 (x64)
VIN: VSSZZZ5FZDR035153 License Plate:
Mileage: 34480km-21424mi Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZDR035153 Mileage: 34480km-21424miles
Address 01: Engine (J623-CKFC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 011D0012032501090000
Shop #: WSC 00049 770 00124
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AFBDEBBFD49059287-802E
10065 - Mass Air Flow Sensor (G70)
P0104 00 [175] - Intermittent
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Coolant temperature: 29 °C
Intake air temperature: 23 °C
Voltage terminal 30: 11.940 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9999
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Charge air pressure specified value: 0 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 998.8 hPa
Mean injection quantity: 0.00 mg/stroke
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Longitudinal acceleration: raw value: 32.767 m/s²
Vehicle inclination acceleration angle: raw value: 0.000 m/s²
Status: incline angle-Bit 0: 1
Longitudinal acceleration: 0.000 m/s²
Longitudinal acceleration sensor: status-Bit 0: 1
Vehicle lateral acceleration: raw value: 0.00 g
Vehicle lateral acceleration: 0.00 g
U0428 00 [047] - -
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 4
Drivetrain coordinator: brake function status-Bit 0: 0
Drivetrain coordinator: brake function status-Bit 8: 0
Acceleration: 0.000 m/s²
Readiness: 1 1 0 0 1
Part No SW: 0D9 300 040 A HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 3613
Revision: 05652103 Serial number: TFK01303020666
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1521ED07F417CAEA0A-8040
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 A HW: 5Q0 907 379 A
Component: ESC H75 0333
Revision: 00000000 Serial number:
Coding: 0000000000000000000000000000000000000000000000000000000000
Shop #: WSC 00049 770 00104
ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
ROD: EV_Brake1UDSContiMK100ESP_008.rod
VCID: 3A7B1EBBBDC9C592C7-806E
10 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
0295 - Steering angle sensor
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
8269 - Databus
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.26
Time: 23:24:51
8278 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
8290 - Coding Not Possible
U10BC 00 [008] - -
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.26
Time: 23:24:51
8306 - Databus
Reset counter: 58
Mileage: 34480 km
Date: 2016.09.24
Time: 20:01:41
8308 - Control Module Incorrectly Coded
U1014 00 [008] - -
Reset counter: 58
Mileage: 34480 km
Date: 2016.09.24
Time: 19:52:39
Part No SW: 5F0 907 044 HW: 5F0 907 044
Component: Climatronic H02 0503
Revision: 00001K05
Coding: 00100104202100011005000000101000
ROD: EV_ACClimaBHBVW37X_002.rod
VCID: 63C583DF6AC3E45AB4-8036
Air quality sensor:
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Outside air temperature: 4.0 °C
Engine speed: 0 /min
Temperature after evaporator: 13.7 °C
System run time-Terminal 15 on: 255 s
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011308500483
Coding: 0B001842C2C100DB0BA44000B11C0728102A000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
VCID: 46837A4BF931B172B3-8012
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130227 041 0574
Serial number: 130228110048
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY130590H2Q
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000056379927
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20304420
0531 - Footwell Illimunation
B11FF 01 [009] - Electrical Failure
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
786954 - Heater for Spray Nozzles
B1224 15 [009] - Open or Short to Plus
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:12:04
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231305901663
Coding: 0031051011
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000_VW37.rod
B10FC 13 [008] - Open Circuit
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
13637426 - Databus
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Part No SW: 3Q0 959 655 R HW: 3Q0 959 655 R
Component: Airbag VW20 011 0186
Revision: -------- Serial number: 003NPP3AQC97
Coding: 98CCC000000000005C0000CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 4D9145671C47422A72-8018
Subsystem 1 - Part No SW: ----------- HW: 454 000 303 13
Serial number: 3576U000000C44153C06
Subsystem 2 - Part No SW: ----------- HW: 454 000 303 13
Serial number: 3586U000000D80053C07
Subsystem 3 - Part No SW: ----------- HW: 454 802 702 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R00030901000000C
Subsystem 4 - Part No SW: ----------- HW: 454 802 702 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R772B2101000000V
Subsystem 5 - Part No SW: ----------- HW: -----------
Component: FrontSensor_D --- ----
7 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
9440283 - Driver side knee airbag igniter
B100C 1B [137] - Resistance Too High
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:46
B13BC F2 [137] - No function
Mileage: 34480 km
Date: 2016.09.24
Time: 01:12:04
Part No SW: 5Q0 953 507 AJ HW: 5Q0 953 549 A
Revision: -------- Serial number: 27031304220595
Coding: 9400
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 7EF3D2ABE16129B2BB-802A
Part No SW: 5F0 920 970 G HW: 5F0 920 970 G
Component: KOMBI 336 0556
Coding: 23A402082980260001086A00000000
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 2D5125E77C87622A52-8078
16776973 - Databus
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 125 1109
Revision: -------- Serial number: 0000468627
Coding: 030100F40B087300EF0006C81C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 346730839FAD33E21D-8060
Subsystem 2 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004050316762
197169 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
Supply voltage: Terminal 30: 11.8 V
Terminal 15: On
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000053697492
Coding: 00100220DC01020000001000
VCID: 020BA65B95994D52DF-8056
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000131905
Coding: 2D0000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 0002
Shop #: WSC 06314 790 00021
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 4385635FCA03845A94-8016
15873 - Steering angle sensor
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Motor status: 00
Supply voltage: 11.75 V
Temperature: 18.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uioUdNotFilt_xdu16: 11.81 V
uAdSensI_SwitchedKl30_xdu16: 11.82 V
19204 - Databus
Reset counter: 58
Mileage: 34480 km
Date: 2016.09.24
Time: 01:12:05
Motor status: 01
System status: Driving mode
Supply voltage: 11.50 V
Temperature: 17.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 21
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000053641240
VCID: 0109A957909F564AC6-8054
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000113691
Coding: 350000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Component: LWR-ECU 005 0070
Coding: 048A000001000000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75E1CD87D4576AEAEA-8020
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:45
13705992 - Databus
Fault Frequency: 6
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:44
Part No SW: 5F0 035 858 HW: 5F0 035 858
Component: MU-S-ND-ER 039 0151
Serial number: E5F01203131223
Coding: 04730001D70A000021111101000800002F0101060100010046
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE_VW37.rod
VCID: 68DF94F393E5870261-803C
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H45 0020
Serial number: SEZ8Z9N5600BGN
U1111 00 [009] - -
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:47
Voltage terminal 30: 11.8 V
BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 18
Mileage: 34480 km
Date: 2016.09.24
Time: 01:03:50
End-------------------------(Elapsed Time: 03:41)--------------------------
