seat leon mk3 2013 abs long coding please HELP!
Kaunas1030
C?ID=231601
hi guys so abs long coding has been deleted now its shows 0000000.....
whats the spolutions??? dealers price local garage just howwww?????
here is full scan
Thursday,26,January,2017,16:16:06:38492
VCDS Version: 16.8.4.2 (x64)
VIN: VSSZZZ5FZDR035153   License Plate:
Mileage: 34480km-21424mi   Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZDR035153   Mileage: 34480km-21424miles
Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5520
   Revision: 83H22---
   Coding: 011D0012032501090000
   Shop #: WSC 00049 770 00124
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AFBDEBBFD49059287-802E
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [175] - Intermittent
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
                    Engine speed: 0.00 /min
                    Coolant temperature: 29 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 11.940 V
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Standardized airflow ratio: filtered: 3.9999
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Charge air pressure specified value: 0 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 998.8 hPa
                    Mean injection quantity: 0.00 mg/stroke
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: 0.000 m/s²
                    Status: incline angle-Bit 0: 1
                    Longitudinal acceleration: 0.000 m/s²
                    Longitudinal acceleration sensor: status-Bit 0: 1
                    Vehicle lateral acceleration: raw value: 0.00 g
                    Vehicle lateral acceleration: 0.00 g
          U0428 00 [047] - -
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
                    Drivetrain coordinator: ACC fault status-Bit 0: 0
                    Drivetrain coordinator: ACC fault status-Bit 8: 0
                    Drivetrain coordinator: brake fault status-Bit 0: 4
                    Drivetrain coordinator: brake function status-Bit 0: 0
                    Drivetrain coordinator: brake function status-Bit 8: 0
                    Acceleration: 0.000 m/s²
Readiness: 1 1 0 0 1
   Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 3613
   Revision: 05652103    Serial number: TFK01303020666
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1521ED07F417CAEA0A-8040
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Revision: 00000000    Serial number:
   Coding: 0000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 00049 770 00104
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_008.rod
   VCID: 3A7B1EBBBDC9C592C7-806E
10 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
8269 - Databus
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.26
                    Time: 23:24:51
8278 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
8290 - Coding Not Possible
          U10BC 00 [008] - -
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.26
                    Time: 23:24:51
8306 - Databus
                    Reset counter: 58
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 20:01:41
8308 - Control Module Incorrectly Coded
          U1014 00 [008] - -
                    Reset counter: 58
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 19:52:39
   Part No SW: 5F0 907 044     HW: 5F0 907 044
   Component: Climatronic   H02 0503
   Revision: 00001K05
   Coding: 00100104202100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002.rod
   VCID: 63C583DF6AC3E45AB4-8036
   Air quality sensor:
262658 - High Pressure Sensor
          B10AE 31 [009] - No Signal
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
                    Outside air temperature: 4.0 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 13.7 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011308500483
   Coding: 0B001842C2C100DB0BA44000B11C0728102A000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46837A4BF931B172B3-8012
   Subsystem 1 - Part No SW: 5F2 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130227  041 0574
   Serial number:         130228110048
   Coding: 0BC5FD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130590H2Q
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000056379927
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20304420
0531 - Footwell Illimunation
          B11FF 01 [009] - Electrical Failure
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
786954 - Heater for Spray Nozzles
          B1224 15 [009] - Open or Short to Plus
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:12:04
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231305901663
   Coding: 0031051011
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_VW37.rod
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [008] - Open Circuit
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
13637426 - Databus
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
   Part No SW: 3Q0 959 655 R    HW: 3Q0 959 655 R
   Component: Airbag VW20   011 0186
   Revision: --------    Serial number: 003NPP3AQC97
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 4D9145671C47422A72-8018
   Subsystem 1 - Part No SW: -----------    HW: 454 000 303 13
   Serial number: 3576U000000C44153C06
   Subsystem 2 - Part No SW: -----------    HW: 454 000 303 13
   Serial number: 3586U000000D80053C07
   Subsystem 3 - Part No SW: -----------    HW: 454 802 702 13
   Serial number: 3516R00030901000000C
   Subsystem 4 - Part No SW: -----------    HW: 454 802 702 13
   Serial number: 3526R772B2101000000V
   Subsystem 5 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_D  --- ----
7 Faults Found:
          B1000 1B [137] - Resistance Too High
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
          B1006 1B [137] - Resistance Too High
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:46
          B13BC F2 [137] - No function
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:12:04
   Part No SW: 5Q0 953 507 AJ    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 27031304220595
   Coding: 9400
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 7EF3D2ABE16129B2BB-802A
   Part No SW: 5F0 920 970 G    HW: 5F0 920 970 G
   Component: KOMBI         336 0556
   Coding: 23A402082980260001086A00000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   VCID: 2D5125E77C87622A52-8078
16776973 - Databus
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000468627
   Coding: 030100F40B087300EF0006C81C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 346730839FAD33E21D-8060
   Subsystem 2 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004050316762
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000053697492
   Coding: 00100220DC01020000001000
   VCID: 020BA65B95994D52DF-8056
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000131905
   Coding: 2D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 0002
   Shop #: WSC 06314 790 00021
   VCID: 4385635FCA03845A94-8016
15873 - Steering angle sensor
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 18.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 11.81 V
                    uAdSensI_SwitchedKl30_xdu16: 11.82 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
                    Reset counter: 58
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:12:05
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.50 V
                    Temperature: 17.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000053641240
   VCID: 0109A957909F564AC6-8054
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000113691
   Coding: 350000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Component: LWR-ECU       005 0070
   Coding: 048A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75E1CD87D4576AEAEA-8020
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:45
13705992 - Databus
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:44
   Part No SW: 5F0 035 858     HW: 5F0 035 858
   Component: MU-S-ND-ER    039 0151
   Serial number: E5F01203131223
   Coding: 04730001D70A000021111101000800002F0101060100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE_VW37.rod
   VCID: 68DF94F393E5870261-803C
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H45 0020
   Serial number: SEZ8Z9N5600BGN
          U1111 00 [009] - -
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:47
                    Voltage terminal 30: 11.8 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 18
                    Mileage: 34480 km
                    Date: 2016.09.24
                    Time: 01:03:50
End-------------------------(Elapsed Time: 03:41)--------------------------
Optimal solution: Always make an Auto-Scan before you start working on the car. That way, when you do something that kills the ABS coding, you know what the coding should be. ;)
Kaunas1030
C?ID=231601
anyone have any advise?
Kaunas1030
C?ID=231601
Uwe car come like that that wasnt my fault!
apart that coment do you have any solutions for it or advise ??
Kaunas1030
C?ID=231601
its my problem couse i bought the car from copart like that thats why!
Well, maybe somebody else has some ideas on how to code that ABS, but I don't.
The right way to do it via SVM, i.e. dealer or someone with access.
GaryM
Oxford, UK
C?ID=226919
Buying from an auction under "sold as seen" is always a gamble you take. as Uwe said and as I previously said HERE, it looks like you have no real options other than to get a dealer to restore the coding for you. The only way to find out the cost of that is to pick up the phone and ask them.
Kaunas1030
C?ID=231601
thanks Gary this is my plan for monday its just you know sometimes dealers could be bastards! and i happen to me that they told me they not abble to do it lol
what you think is it possible to get code from other car? same year model etc etc?
