Problem with basic settings of auto hvac on 2013 passat tdi ....
emserg
C?ID=39273
the battery was disconnected for several weeks, the auto hvac lost basic settings, a/c doesnt work, asking to do basic settings..
when i try to do basic settings it gives me an error:
for flap basic settings: error: request out of range
and same errors for compressor run in auto
and compressor run in manual...
here is the auto scan
VCDS Version: Beta 14.7.0 (x64)
Data version: 20140601
edge motors
Friday,11,July,2014,11:34:01:23346
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A34DC110454   Mileage: 27180km-16888miles
Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
   Part No SW: 03L 906 012 BN    HW: 03L 907 309 S
   Component: R4 2,0L EDC   H24 4804
   Revision: 71H24---    Serial number:
   Coding: 001D0012042400008000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM20TDI01103L906012BN 004007
   ROD: EV_ECM20TDI01103L906012BN.rod
   VCID: F1AA93DB20F2A8B210-80A4
Readiness: 0 0 0 1 1
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3527
   Revision: 05651213    Serial number: 00001212210466
   VCID: A404AA8F67804D1AAB-80F1
   Revision: 00H31001
   Coding: C54BC0F5492300FAA30F03E9921D0042A71000
   VCID: FDB2BFEB64AADCD284-80A8
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0193663223
   Coding: 130C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: B4245ACF1F60DD9A3B-80E1
6 Faults Found:
          U1400 00 [008] - -
                    Reset counter: 8
                    Time: 00:00:00
65812 - Supply voltage
          U1012 00 [008] - Voltage too High
                    Reset counter: 8
                    Mileage: 27173 km
                    Date: 2014.07.04
                    Time: 00:37:57
65813 - Supply voltage
                    Reset counter: 8
                    Mileage: 27172 km
                    Date: 2014.07.03
                    Time: 23:29:31
1052935 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 11 [008] - Short to Ground
                    Reset counter: 8
                    Time: 00:00:00
1053191 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 11 [008] - Short to Ground
                    Reset counter: 8
                    Time: 00:00:00
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
                    Fault Frequency: 7
                    Reset counter: 8
                    Mileage: 27022 km
                    Date: 2014.06.25
                    Time: 05:17:53
   Part No SW: -----------    HW: -----------
   Component: Climatronic   0405
   Revision: --------
   Coding: 0010001012
   ROD: EV_ACClimaBHBVW411.rod
   VCID: EFAE95A336C6BE4206-80BA
6 Faults Found:
9473138 - Motor for Left Temperature Flap
          B108C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9473394 - Motor for Right Temperature Flap
          B108D 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9474162 - Motor for Defroster Flap
          B1090 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9474418 - Motor for Front Air Distribution Flap
          B1091 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9472882 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:58
9477872 - AC Compressor First Run-In
          B109E F0 [009] - Not Performed
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
   Shop #: WSC 07985 444 103304
   VCID: F4A49ACF57E09D9AFB-80A1
   Component: RLS 221112 05  54  0403
   Coding: 22300A
   Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
   Component: AirbagVW10G   014 0851
   Serial number: 003MWM00TAMB
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: F5A2A7CB549A8492CC-80A0
   Serial number: 6940000Y130000RBTX0S
   Coding: 303047
   Serial number: 3572MSME42481476ZZZT
   Serial number: 3582MSME13094375ZZZQ
   Serial number: 3516KSME42556821ZZZM
   Serial number: 3526KSME48686821ZZZX
   Serial number: 3556LSME61453721ZZZN
   Crash sensor for front airbag; passenger side:
   Serial number: 3566LSME49533721ZZZT
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20121214100997
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FDB2BFEB6CAADCD284-80A8
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-YVJ  H07 0022
   Coding: E20000
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 9C74926F97F075DA13-80C9
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 16021303290713
   Coding: 461000
   VCID: F6A0A0C7419C8F8AC5-80A3
   Component: IMMO          H07 0705
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EA9884B70D245B6A51-80BF
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000002993005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B02C56DFEB78E1BA5F-80E5
13635840 - Supply voltage
                    Reset counter: 8
                    Mileage: 27172 km
                    Date: 2014.07.03
                    Time: 23:24:47
13893888 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
                    Reset counter: 8
                    Mileage: 27173 km
                    Date: 2014.07.04
                    Time: 00:00:02
          U1400 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 8
                    Mileage: 27172 km
                    Date: 2014.07.03
                    Time: 23:23:45
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
                    Reset counter: 8
                    Mileage: 27173 km
                    Date: 2014.07.04
                    Time: 01:28:19
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664273002
   Coding: 010100
   VCID: AA1844B7C5A49B6A91-80FF
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000049778182
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: E08CE69FF318113A8F-80B5
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
   Component: RNS-MID       H02 3696
   Revision: AB001001    Serial number: VWZ6Z7M7348035
   Coding: 04090042010000A6000B
   VCID: A71EBD83D6B6A6028E-80F2
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0525
   Revision: 12110009    Serial number: 0006115775
   Coding: 0405FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: B73E6DC3C61636821E-80E2
Address 47: Sound System (R12)       Labels: 3T0-035-456.clb
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0008458
   VCID: A600B087D9BCBF0AB5-80F3
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: EFAE95A33EC6BE4206-80BA
   Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0525
   Revision: 14110009    Serial number: 0006088962
   Coding: 0405FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 9D729F6B8CEA7CD2E4-80C8
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663990824
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: BA3874F73D042BEAE1-80EF
End-------------------------(Elapsed Time: 02:30)--------------------------
emserg
C?ID=39273
can you tell me the channel numbers for those basic settings so i can try to do it with my other scan tool???
The HVAC control module uses the UDS/ODX protocol. There are no channel numbers.
Have you tried clearing fault codes immediately prior to running basic settings?
emserg
C?ID=39273
yes, tried clearing before basic settings, tried with ignition on enigne running, ignition on engine off. no luck
emserg
C?ID=39273
ok did the basic settings with launch scan tool...
all to the dot as i tried with vcds.....
emserg
C?ID=39273
didnt have to clear the codes before doing basic settings, just had to do adaptation and change compressor run in time from `120 to 120...
Andy
Sector 7G
HC424490
Thanks for the feedback. I have confirmed by trying to run Basic Settings for "Adapt flap end stops" in a 2012 Passat using Beta 14.7.0, that the HEX-NET does not allow it while the HEX-USB+CAN does. We believe we have a fix in the works for the next update.
Out of curiosity does your HVAC still show weird dashes?
Revision: --------
Coding: 0010001012
Mine looks much different:
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 561 907 044 D HW: 561 907 044 D
Component: Climatronic 042 0102
Revision: 00001001
Coding: 0010001002
Which is now ready for testing.
Sergey: Please try 14.7.1. It's available for download from this page.
emserg
C?ID=39273
will do now.
the dashes i dont know, had to give the car back to customer...
the launch didread the part numbers of the module and software though...
emserg
C?ID=39273
wait, i think thats the version i was using on that passat...
when did you make the update ?
cause i have not updated it since that car and that is the version i have now...
emserg
C?ID=39273
my bad, im not sure if i was trying it with the new version or the old one... i have 3 different computers that i use the vag with, just checked and one of them had the 14.7 not the 14.7.1 in it....
nikopk
C?ID=386424
Hey emserg, I am having similar issues Audi a6 c6 HVAC gives me basic setting error.... is this somethign vcds cant handle and i need to use another scan tool?
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000053    Serial number: 00000000442499
   Coding: 0524328
   Shop #: WSC 02325 758 00200
   VCID: 1C61D3088AA2AC4BAF3-8048
                    Fault Status: 01100101
                    Reset counter: 20
                    Mileage: 185384 km
                    Date: 2020.06.19
                    Time: 00:09:41
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
                    Fault Status: 00100101
                    Reset counter: 60
                    Mileage: 187277 km
                    Date: 2020.07.01
                    Time: 23:52:36
                    Voltage: 13.70 V
                    (no units): 16.0
                    (no units): 251.0
Have you actually tried doing the Basic Settings in this module? Group 001.
PS: The most recent post in this thread before yours is just about six years old!
