the battery was disconnected for several weeks, the auto hvac lost basic settings, a/c doesnt work, asking to do basic settings..
when i try to do basic settings it gives me an error:
for flap basic settings: error: request out of range
and same errors for compressor run in auto
and compressor run in manual...
here is the auto scan
VCDS Version: Beta 14.7.0 (x64)
Data version: 20140601
edge motors
Friday,11,July,2014,11:34:01:23346
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A34DC110454 Mileage: 27180km-16888miles
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 BN HW: 03L 907 309 S
Component: R4 2,0L EDC H24 4804
Revision: 71H24--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012BN 004007
ROD: EV_ECM20TDI01103L906012BN.rod
VCID: F1AA93DB20F2A8B210-80A4
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3527
Revision: 05651213 Serial number: 00001212210466
VCID: A404AA8F67804D1AAB-80F1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: C54BC0F5492300FAA30F03E9921D0042A71000
VCID: FDB2BFEB64AADCD284-80A8
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0193663223
Coding: 130C0C
ROD: EV_KESSYPQ35G.rod
VCID: B4245ACF1F60DD9A3B-80E1
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 8
65812 - Supply voltage
U1012 00 [008] - Voltage too High
Reset counter: 8
Mileage: 27173 km
Date: 2014.07.04
Time: 00:37:57
65813 - Supply voltage
Reset counter: 8
Mileage: 27172 km
Date: 2014.07.03
Time: 23:29:31
1052935 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 11 [008] - Short to Ground
Reset counter: 8
1053191 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 11 [008] - Short to Ground
Reset counter: 8
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Open Circuit
Reset counter: 8
Mileage: 27022 km
Date: 2014.06.25
Time: 05:17:53
Address 08: Auto HVAC (J255) Labels: None
Part No SW: ----------- HW: -----------
Component: Climatronic 0405
Revision: --------
Coding: 0010001012
ROD: EV_ACClimaBHBVW411.rod
VCID: EFAE95A336C6BE4206-80BA
9473138 - Motor for Left Temperature Flap
B108C 54 [009] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 27186 km
Date: 2014.07.11
Time: 23:21:57
9473394 - Motor for Right Temperature Flap
B108D 54 [009] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 27186 km
Date: 2014.07.11
Time: 23:21:57
9474162 - Motor for Defroster Flap
B1090 54 [009] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 27186 km
Date: 2014.07.11
Time: 23:21:57
9474418 - Motor for Front Air Distribution Flap
B1091 54 [009] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 27186 km
Date: 2014.07.11
Time: 23:21:57
9472882 - Motor for Fresh Air / Recirculated Air Flap
B108B 54 [009] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 27186 km
Date: 2014.07.11
Time: 23:21:58
9477872 - AC Compressor First Run-In
B109E F0 [009] - Not Performed
Reset counter: 229
Mileage: 27186 km
Date: 2014.07.11
Time: 23:21:57
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
Shop #: WSC 07985 444 103304
VCID: F4A49ACF57E09D9AFB-80A1
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 221112 05 54 0403
Coding: 22300A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM00TAMB
Coding: 00005033
ROD: EV_AirbaVW10SMEVW360.rod
VCID: F5A2A7CB549A8492CC-80A0
Serial number: 6940000Y130000RBTX0S
Coding: 303047
Serial number: 3572MSME42481476ZZZT
Serial number: 3582MSME13094375ZZZQ
Serial number: 3516KSME42556821ZZZM
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME48686821ZZZX
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME61453721ZZZN
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME49533721ZZZT
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20121214100997
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: FDB2BFEB6CAADCD284-80A8
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Part No SW: 561 920 970 E HW: 561 920 970 E
Component: KOMBI H07 0705
Coding: 231E01
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 9C74926F97F075DA13-80C9
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 16021303290713
Coding: 461000
VCID: F6A0A0C7419C8F8AC5-80A3
Component: IMMO H07 0705
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EA9884B70D245B6A51-80BF
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000002993005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: B02C56DFEB78E1BA5F-80E5
13635840 - Supply voltage
Reset counter: 8
Mileage: 27172 km
Date: 2014.07.03
Time: 23:24:47
13893888 - Function Restricted due to Exessive Voltage
U1401 00 [008] - -
Reset counter: 8
Mileage: 27173 km
Date: 2014.07.04
Time: 00:00:02
U1400 00 [008] - -
Reset counter: 8
Mileage: 27172 km
Date: 2014.07.03
Time: 23:23:45
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
Reset counter: 8
Mileage: 27173 km
Date: 2014.07.04
Time: 01:28:19
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664273002
Coding: 010100
VCID: AA1844B7C5A49B6A91-80FF
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000049778182
Coding: 00581B0000000000000021010100202020202120202020
VCID: E08CE69FF318113A8F-80B5
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 G HW: 3C0 035 684 G
Component: RNS-MID H02 3696
Revision: AB001001 Serial number: VWZ6Z7M7348035
Coding: 04090042010000A6000B
VCID: A71EBD83D6B6A6028E-80F2
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0006115775
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
VCID: B73E6DC3C61636821E-80E2
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0008458
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: A600B087D9BCBF0AB5-80F3
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: EFAE95A33EC6BE4206-80BA
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0006088962
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 9D729F6B8CEA7CD2E4-80C8
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663990824
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: BA3874F73D042BEAE1-80EF
End-------------------------(Elapsed Time: 02:30)--------------------------
