- May 16, 2014
- 5,469
- 5,936
- Melbourne, Australia
- C?ID=194404
Hello VCDS gurus!
I come seeking advice from those with knowledge about the settings for the Expanded electronic differential lock on a mkVII Golf. Specifically, I'm trying to alter the XDS setting on my car. I have understood from various forums that it is possible to change the setting from “Standard”, “Not activated”, “Weak”, “Medium”, or “Strong” via the adaptation channel for the ABS module.
The process that I have attempted to use is as follows :
1, Select [03] ABS
2. Select 10 Adaptation
3. From the pull down menu, select “Expanded electronic differential lock”
4. In the New value box select : “Standard”, “Not activated”, “Weak”, “Medium”, “Strong”
(These instructions have been taken from " http://golf7vcds.moonfruit.com/driver-convenience/4581555424"
My problem is that that I can't get to step 4 above because of the error message on the following pic:
I had thought that there was perhaps a security code for the ABS module, but there is no mention of this in any of the forums that discuss this tweak.
Has anyone else experienced this problem and if so how has it been resolved?
Thanks in advance for your replies
Oh... here's the autoscan report from my car
1, Select [03] ABS
Wednesday,25,June,2014,12:25:31:03521
VCDS Version: 14.6.1.0
Data version: 20140601
VIN: License Plate:
Mileage: 9713km Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: Mileage: 9713km-6035miles
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1,4l R4 TSI H08 7615
Revision: WAH08---
Coding: 01250032242405082000
Shop #: WSC 20604 001 1048576
ASAM Dataset: EV_ECM14TFS01104E906016G 002010
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 26431A2059EACC0A4B-8073
Readiness: 0000 0001
Part No SW: 0CW 300 045 HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4510
Revision: 00043014 Serial number: CU501212296246
Shop #: WSC 00028 028 00025
ROD: EV_TCMDQ200021_AU37.rod
VCID: 76E30A60C9CAFC8A3B-8023
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
VCID: 7DF1154CECFCAFD27A-8028
Part No SW: 5G0 907 044 Q HW: 5G0 907 044 Q
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00120004200100011005000012101800
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 3561CD6C944CB792F2-8060
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011234701612
Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
ROD: EV_BCMBOSCH_SE37.rod
VCID: 4385A3B4CA9819224C-8016
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A
Component: WWS 121120 042 0551
Serial number: 121206042218
Coding: 0E4DD5
Component: RLFS 024 0042
Serial number: Y13M01D03H20M05S37S1
Coding: 06A8DD
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231233000504
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3A7BDE50BD5258EA1F-806F
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Serial number: 003F5R01UHNZ
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00061
VCID: 408FACB8DB8E023A51-8015
Subsystem 1 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 357670000007612C7C0W
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 358670000006332C7C0V
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 301 13
Serial number: 3516502AF0CD5EC471C+
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 201 13
Serial number: 3526502B30CD5EC2136J
Subsystem 5 - Part No SW: ----------- HW: 480 401 112 12
Serial number: 3556502B30CD5EC4008M
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Component: Lenª007 0070
Revision: -------- Serial number: 08011304220489
Coding: 0500
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 79F9015CF8D493F256-802C
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 235 0555
Coding: 27A401082380000801087A00040000
VCID: 65C15D2C646C071282-8030
Part No SW: 5Q0 907 530 E HW: 5Q0 907 530 E
Component: GW MQB Mid 121 1109
Revision: -------- Serial number: 0000188941
Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_AU37.rod
VCID: 3365F3749A38A9A2DC-8066
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H13 0035
Serial number: 02120005290300060291
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3451678601
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000046453458
Coding: 003A02208001020000001000
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 020B66B09502D02A07-8057
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Serial number: 00000000000000502227
Coding: 0D0000
Coding: 01
ROD: EV_SteerAssisMQB.rod
VCID: 3D71D54CAC7C6FD23A-8068
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000048027940
Coding: 003A00208E01020000801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 010969BC9004CB321E-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Serial number: 00000000000000502825
Coding: 050000
Part No SW: 5G0 035 846 A HW: 5G0 035 846
Component: MU-S-N-ER 039 0421
Serial number: V1F00501130081
Coding: 02730008FF00000011510001000900001F0100960100010247
Shop #: WSC 43847 000 1048576
ROD: EV_MUStd4CPASE_SE37.rod
VCID: 275D17245EE0D50270-8072
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H44 0022
Serial number: VWZ8Z9M3400KZM
Engine Control Module 2:
Subsystem 2 - Part No SW: 5G0 919 866 A HW: -----------
Component: ROW 2013 --- 0022
End-------------------------(Elapsed Time: 03:14)--------------------------
