Tuesday,02,August,2016,20:03:03:42330
VCDS Version: 16.8.0.0 (x64) HEX-NET CB: 0.4321.4
Data version: 20160731 DS254
VIN: WVWZZZAUZGW120364 License Plate: GOLF-7-1.4
Gateway Installation List: 5Q0 907 530 AF
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZAUZGW120364 Mileage: 55km-34miles
Address 01: Engine (J623-CZDA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 HD HW: 04E 907 309 BH
Component: R4 1.4l TFS H24 2325
Revision: R7H24---
Coding: 01250032230419083000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001004
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: ED9280043C34242AF8-80B8
CAN Converter 01:
Part No SW: 0CW 300 040 H HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0606
Revision: 00005005 Serial number: CU501508025884
ROD: EV_TCMDQ200021.rod
VCID: B93A645438FC488A24-80EC
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62435000000119
Coding: 01FA8AA12422116C077A060641C72980512488E0608294F300220038C202
VCID: F9BAA454787C888A64-80AC
Revision: 00021000 Serial number: 0379039921
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_VW37.rod
VCID: BA387B583DFA43922D-80EE
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120014200100011005000000101002
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: EA988B180DDA33129D-80BE
Air quality sensor:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [008] - -
Reset counter: 51
Mileage: 38 km
Date: 2016.06.28
Time: 14:31:19
Voltage terminal 30: 13.8 V
Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061525100281
Coding: 03111A46C24122FB0BA44080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
VCID: 895AD494289C980A74-80DC
Component: WWS 150801 042 0551
Serial number: 150827162947
Component: RLHS 037 0059
Serial number: S2Y15M09D16H06M33S11
Coding: 90A8DD
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY152081L16
Serial number: 00000000000033137926
Sun Roof:
Component: J245 PS73.403 H03 0004
Serial number: 0000FST000I2LOT00000
Coding: 181801
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Revision: -------- Serial number: 39331525303762
Coding: 0031051011
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: C3C606BC4A30025A7E-8096
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R128HVO
VCID: C1CA0CB4502C104A6C-8094
Subsystem 1 - Part No SW: ----------- HW: 480 000 209 15
Serial number: 35767000000B7CEC2617
Subsystem 2 - Part No SW: ----------- HW: 480 002 408 15
Serial number: 35867000000F302C161Q
Subsystem 3 - Part No SW: ----------- HW: 480 402 907 15
Serial number: 3516502B51C2F0333382
Subsystem 4 - Part No SW: ----------- HW: 480 403 007 15
Serial number: 3526502991C1EFA0A30L
Subsystem 5 - Part No SW: ----------- HW: 480 400 309 15
Serial number: 3556502B31CB0C01A146
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 03091508490061
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 875ED2AC3E88EE7A62-80D2
Part No SW: 5G1 920 640 A HW: 5G1 920 640 A
Component: KOMBI 207 7640
Coding: 27A419182B80000E02082A001400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_VW37.rod
VCID: A306A63CAA70225A1E-80F6
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Fault Frequency: 86
Reset counter: 53
Mileage: 29 km
Date: 2016.06.15
Time: 13:30:43
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003912460
Coding: 030100043F085700FB00024A1C0F00010001050000000000000000000000
ROD: EV_GatewLear.rod
VCID: F5A2A8645464ECEA00-80A0
Subsystem 2 - Part No SW: 5G0 959 442 H HW: 5G0 959 442 H
Component: E221__MFL-DC1 H17 0103
Serial number: 29150001695070065345
Coding: 25FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7689297603
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000192753003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_VW37.rod
VCID: B42455601F9EB5E2F7-80E0
Component: TSG FS 020 0041
Serial number: 310815BHT16103
Coding: 003B1220D001040000001000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000007269069
Coding: 0D0000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 8103
ROD: EV_SteerAssisMQB_VW37.rod
VCID: C4C405A04F3E056247-8090
Component: TSG BFS 020 0041
Serial number: 020915BI213158
Coding: 003B1020DE01040000801000
VCID: C2C803B8552A0B5275-8096
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000007207335
Coding: 150000
Component: AFS-ECU H07 0090
Coding: 029E00000B000200
VCID: C0CC09B05B26194263-8094
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 877 A HW: 3Q0 035 877 A
Component: MU-S--ROA H24 0245
Serial number: VWZAZ2R0459613
Coding: 02730000FF00000051110001000108001F0100860100010001
Shop #: WSC 28195 001 1048576
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: B326567C1A90B2DAEE-80E6
Subsystem 1 - Part No SW: 3G0 919 605 L HW: 3G0 919 605 L
Component: ABT_Std-2 H43 4060
Serial number: VWZ6Z9R2530619
End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.0V)-----------
