VW Golf 7 Instrument cluster retrofit to Premium 1 fault
DV52
C?ID=194404
barstanders: I know that the tweak for fixing the situation in some later models of NAR mk7s where the dash lights don't illuminate when the rotary light switch is on the "parker" position is changing (1)-Illumination_algorithm-Scale_switching_algorithm from parking light to lds.
I'm aware of quite a few drivers in the US that have successfully implemented this tweak (using 25327). So at least this channel is accessable in these cars
   #22
barstanders
C?ID=277262
Hello DV52,
My cars dash lights illuminate when the rotary light switch is on the "parker" position.
I cant change it with 15.7.4 maybe the beta version 16.6 will do this
Can anyone confirm that this can be changed with beta.
   #23
DV52
C?ID=194404
Hello DV52,
barstanders: OK - just checked my car which has the following instrument control module
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 235 0555
Coding: 27A501082380800801087E00040000
Shop #: WSC 00028 028 00025
VCID: 658274FC64206E16ED-8030
Using both Version 15.7.4 and Beta version 16.6.0 and with my HEXT NET dongle I was unable to access both these adapatation channels. I guess these two channels aren't in the firmware for my control module- which was confirmed when I generated an admap using 15.7.4 (they don't appear in my latest admap either - I was wrong in my earlier reply, sorry )!!
However, it's real strange that these two channels suddenly appeared in the admap for your new cluster (see your post #8), but you can't access the channels in the adaptation screen. What version SW were you using to get the admap table in your post #8?
barstanders
C?ID=277262
Englisch 15.7.4 latest
German DVI 15.7.4 latest
   #25
barstanders
C?ID=277262
I have olso cheked this setting, i see this settings.
I have changed some of this setting because i have a retrofitted led tail lights a couple months ago.
I thinks this was to light up both sides when you hit the brake.
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
(8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
Deactivate production mode,0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
(3)-Driving light and parking light-Standlicht aus,active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
(5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active
(6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
(10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
(1)-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W auch H15
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht Positionslicht Begrenzungslicht)
(5)-Leuchte23SL HLC10-Lichtfunktion B 23,not active
(6)-Leuchte23SL HLC10-Dimmwert AB 23,28
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
(8)-Leuchte23SL HLC10-Lichtfunktion C 23,Brake light
(9)-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(10)-Leuchte23SL HLC10-Dimmwert CD 23,100
(11)-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23,not active
(13)-Leuchte23SL HLC10-Lichtfunktion F 23,not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23,0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23,not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23,not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23,0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
(1)-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W auch H15
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht Positionslicht Begrenzungslicht)
(5)-Leuchte24SL HRA65-Lichtfunktion B 24,not active
(6)-Leuchte24SL HRA65-Dimmwert AB 24,28
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
(8)-Leuchte24SL HRA65-Lichtfunktion C 24,Brake light
(9)-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right
(10)-Leuchte24SL HRA65-Dimmwert CD 24,100
(11)-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24,not active
(13)-Leuchte24SL HRA65-Lichtfunktion F 24,not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24,0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24,not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24,not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24,0
(19)-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
   #26
DV52
C?ID=194404
Barstanders: The version 15.7.4 that I used was the English version (same as the Beta version that I tried)! I apologise for disagreeing, but I suspect that you are mixing the BCM modification in your latest post above (^^^) -for the LED tails and the two adaptation channels in the instrument control module. The two are very different, and they are not connected (IMO). Unusually for VW, in this case the name of the two adaptation channels clearly indicates their purpose - I beleive
Question for Ross Tech - how is it possible for the admap process to identify a set of two adaptation channels (and their settings), but these channels are not accessible from the adaptation screen?
   #27
barstanders
C?ID=277262
Hello DV52,
This was just a sugestion because the adaptation channel on the cluster says about parking light, and the BCM 09 shows adaptations parklicht.
So that channels have a nother purpose and not connected with the cluster.
   #28
barstanders
C?ID=277262
I think it is not the Fuel Tank Variant what caused the error.
I code every option from 1 to 8.
So when i code one of the options and disconnect the battery for half an hour then reconnect
The error comes after four and a half day!!!
And when i erase the code with the same Tank variant the error comes with 15 hours
Suspect that this is another cause and not the tank.
Why after four and a half day!!
Maybe it has to do with the infotainment.
So what i dont understand the old cluster coded to 02 Feul Tank Variant 3 and Model variant 0
Do i need to recode the new cluster to Fuel Tank variant 3.
So Model variant 0 old cluster was for a 5 doors
And when i use variant 0 then this shows 3 doors.
   #29
   #30
barstanders
C?ID=277262
I have try everthing but the fehler coms wit 4 days and couple hours again.
VCDS Version: Release 15.7.4 Running on Windows 10 x86
Data version: 20160216
Thursday,07,July,2016,15:15:24:42750
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP010048   Mileage: 47339km-29415miles
Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 E    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 7695
   Revision: WAH08---
   Coding: 01110032232415082000
   Shop #: WSC 51969 000 1048576
   ASAM Dataset: EV_ECM12TFS01104E906016E 001011
   ROD: EV_ECM12TFS01104E906016H.rod
   VCID: 2468B6F82F7D011E3A-8070
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
   Shop #: WSC 12345 123 123465
   VCID: 7DDEA39CEC5790D615-8028
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020004200100011005000000101000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 364C7CB089E1838E94-8062
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011227800350
   Coding: 00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 77D2B1B4CE6BBA864F-8022
   Slave 1:
   Component: WWS    120910  042 0551
   Serial number:         120924160900
   Coding: 0E4DD5
   Slave 2:
   Component: RLFS  024 0042
   Serial number: Y12M09D26H11M47S40S4
   Coding: 06A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1306406H5
   Serial number: 00000000000056969920
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131204002703
   Coding: 0031161041
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 3D5E639CACD750D655-8068
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Serial number: 003F5R00E6ZJ
   Shop #: WSC 00028 028 00057
   VCID: 40A01A68DB253D3E3E-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 310 12
   Serial number: 35767000000E2845EB00
   Subsystem 2 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35867000000ED2CC6D0F
   Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3516502A90D19C31C0EK
   Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3526502AD0CD5EB313CY
   Subsystem 5 - Part No SW: -----------    HW: 480 400 210 12
   Serial number: 3556502B30CD5EB4531M
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Revision: --------    Serial number: 1510120003004H
   Coding: 8400
   Shop #: WSC 51454 001 104857
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 75CEBBBCD467C8965D-8020
   Part No SW: 5G0 920 871     HW: 5G0 920 871
   Component: KOMBI         353 2200
   Coding: 07AD1900239000080D086E00040000
   VCID: 67F2E1F49ECB2A06DF-8032
13639427 - Databus
                    Reset counter: 117
                    Mileage: 47335 km
                    Date: 2016.07.07
                    Time: 14:52:53
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1144
   Revision: --------    Serial number: 0000104516
   Coding: 030100042B086400EF000648080F00010001000000000000000000000000
   Shop #: WSC 51454 001 1048576
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear.rod
   VCID: 3A546880BDF967EE70-806E
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H14 0035
   Serial number: 23130000529820100291
   Coding: 280000
   Serial number: 5430458201
1537 - Data Set Implausible
          B2012 00 [009] -  -
                    Reset counter: 77
                    Mileage: 47049 km
                    Date: 2016.06.26
                    Time: 10:52:06
   Serial number: 29051301100188
   Coding: 001F0220D000020000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000000243883
   Coding: 03
   ROD: EV_SteerAssisMQB.rod
   Component: TSG BFS       020 0023
   Serial number: 06031302090088
   Coding: 001F0020DE00020000801000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 3FA21994A6DB42C647-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000000247280
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846
   Component: MU-S-N-ER     038 0421
   Serial number: V1F01510120522
   Coding: 02730001FF00000011110001000800001F0100940100010045
   Shop #: WSC 12345 666 54321
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 2772A1F45E4BEA061F-8072
   Media Player Position 1:
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9NJ902C5F
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 AD    HW: -----------
   Component:  ECE 2016/17  --- 0059
End-------------------------(Elapsed Time: 02:43)--------------------------
barstanders
C?ID=277262
Yesterday late the error comes again!
I have reset the instrument cluster service, enabled the refeul option on the cluster.
I have change every option what is possible but the error comes after 4 days disconnecting the baterie ore 1 day without disconnecting the batery.
I have olso install yesterday the beta to see if ther any other option that can activated on the cluster but its the same with 15.7.4.
After disconnecting the baterie and resseting the fehler here is the scan.
Saturday,09,July,2016,23:31:13:42750
VCDS Version: 16.6.0.2
Data version: 20160602 DS251
VIN: WVWZZZAUZDP010048 License Plate:
VIN: WVWZZZAUZDP010048 Mileage: 47379km-29439miles
Revision: WAH08---
ROD: EV_ECM12TFS01104E906016.rod
VCID: 2468B6F82F7D01639D-8070
VCID: 7DDEA39CEC5790ABB2-8028
Revision: 00001K06
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 364C7CB089E183F333-8062
ROD: EV_BCMBOSCH_VW37.rod
VCID: 77D2B1B4CE6BBAFBE8-8022
Coding: 0E4DD5
Coding: 06A8DD
Coding: 0031161041
VCID: 3D5E639CACD750ABF2-8068
VCID: 40A01A68DB253D4399-8014
Coding: 8400
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 75CEBBBCD467C8EBFA-8020
Coding: 07AD0A00239000080D087E00040000
VCID: 67F2E1F49ECB2A7B78-8032
VCID: 3A546880BDF96793D7-806E
Coding: 280000
B2012 00 [009] - -
Reset counter: 77
Mileage: 47049 km
Date: 2016.06.26
Time: 10:52:06
Supply voltage; Terminal 30: 14.7 V
Terminal 15: On
Coding: 03
VCID: 3FA21994A6DB42BBE0-806A
Coding: 090000
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 2772A1F45E4BEA7BB8-8072
End-------------------------(Elapsed Time: 02:42)--------------------------
   #32
barstanders
C?ID=277262
I have gone last Monday to the vw Agent.
So the have look in to the error on the gateway, but the cant get it out ore put a new firmware.
So the have send a message to the VW.
The olso say to me that the error on the instrument cluster was known ther is a TPI for.
The ABS unit must be updated to the 0437 software, but i have that already, so the only reason why the error wont go away is that the are stored on the bad firmware.
So when the firmware csn eresad and go to normal the error on the instrument cluster will olso go away.
This is what the VW saying, so i wait for the recall.
The olso updated the Discover media system to the latest software from 421 to 486.
Monday,18,July,2016,15:37:36:42750
VIN: WVWZZZAUZDP010048   Mileage: 47704km-29641miles
   Revision: WAH08---
   Revision: 00001K06
   Coding: 0E4DD5
   Coding: 06A8DD
   Coding: 0031161041
   Coding: 8400
   Coding: 07AD0A002390000800087E00040000
13639427 - Databus
                    Reset counter: 145
                    Mileage: 47697 km
                    Date: 2016.07.18
                    Time: 15:02:06
   Coding: 280000
          B2012 00 [009] -  -
                    Reset counter: 105
                    Mileage: 47697 km
                    Date: 2016.07.18
                    Time: 06:28:08
                    Supply voltage; Terminal 30: 12.0 V
                    Terminal 15: On
   Coding: 03
   Coding: 090000
   Component: MU-S-N-ER     038 0486
   Coding: 02730001FF00000011110001000800001F0103940100010045
Polofan
C?ID=270984
Hello Barstanders
Looks good :) hopefully they Can fix your last 2 errors.
   #34
barstanders
C?ID=277262
Hello All,
I have resolved the error on the instrument cluster!!!!
And not by the VW Agent because his answer was olso not convincingly to me
Unfortunately, not even through the help of the site
So i have try everthing form that day again.
Many of you have read my post where I ask guestions about the Fuel Tank variant, Model Variant and olso about the Tire Circumference here and olso on the vcdsforum.de site.
Why, because the German vcds shows more options to select and the Englisch version not so with this on mind i have think there most be somthing on this settings.
Why on the german and not Englisch, the person who have made this change on the german vcds nows little more then de englisch version so he put this option!
The problem was the TIRE CIRCUMFERENCE, i have change this from standard to Varainte 3 YES on the German version and now after one whole week no more error.
Wednesday,27,July,2016,06:23:12:42750
VIN: WVWZZZAUZDP010048   Mileage: 47889km-29756miles
   Revision: WAH08---
   Revision: 00001K06
   Coding: 0E4DD5
   Coding: 06A8DD
   Coding: 0031161041
   Coding: 8400
   Coding: 07AD0A022390000800087E00040000
   Coding: 280000
          B2012 00 [009] -  -
                    Reset counter: 113
                    Mileage: 47736 km
                    Date: 2016.07.21
                    Time: 22:06:33
                    Supply voltage; Terminal 30: 13.9 V
                    Terminal 15: On
   Coding: 03
   Coding: 090000
barstanders
C?ID=277262
Hello All,
I dont understand it anymore now the error comes after 9 days!
Friday,29,July,2016,23:08:48:42750
VCDS Version: 16.7.0.14
Data version: 20160726 DS254
VIN: WVWZZZAUZDP010048   Mileage: 48058km-29861miles
   Revision: WAH08---
   VCID: 2468B6F82F7D010B81D-8070
   VCID: 7DDEA39CEC5790C3AE3-8028
   Revision: 00001K06
   VCID: 364C7CB089E1839B2F9-8062
   VCID: 77D2B1B4CE6BBA93F4F-8022
   Coding: 0E4DD5
   Coding: 06A8DD
   Coding: 0031161041
   VCID: 3D5E639CACD750C3EE3-8068
   VCID: 40A01A68DB253D2B855-8014
   Coding: 8400
   VCID: 75CEBBBCD467C883E63-8020
   Coding: 07AD0A02239000080D087E00040000
   VCID: 67F2E1F49ECB2A1364F-8032
13639427 - Databus
                    Reset counter: 170
                    Mileage: 48051 km
                    Date: 2016.07.29
                    Time: 13:50:14
   VCID: 3A546880BDF967FBCB1-806E
H14 0035
   Coding: 280000
          B2012 00 [009] -  -
                    Reset counter: 126
                    Mileage: 47873 km
                    Date: 2016.07.25
                    Time: 17:35:06
                    Supply voltage; Terminal 30: 13.0 V
                    Terminal 15: On
   Coding: 03
   VCID: 3FA21994A6DB42D3FCF-806A
   Coding: 090000
   VCID: 2772A1F45E4BEA13A4F-8072
barstanders
C?ID=277262
Hello All,
I still waiting for a call from the VW agent, but i will try Monday with a call.
But i want to now is there a way that the message on the instrument cluster can be disconnected like by the adaptations on the gateway.
I have try ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled do disabled but this is not the adaptation channel.
Can anyone tell if this is possible?
After 9 days the error comes now every day again, so i have try everthing to change but no luck.
Maybe the answer that the mechanic says about bad firmware on the gateway will be right.
A dont now anymore, the strange is that the other High Gateway on my early post shows the same error, so this is doubt the story of the mechanic.
I have no bad firmware on this gateway only the comfort user setting dont work en resolting to 7203 error.
The mechanic says that the error is a nown error TPI somthing with 3030 code from the diagnostic tool of the vw, the ABS need to change to the latest software, but i have this olso 437!
So dos somone else nows about this TPI abs sensor.
Dutchie
C?ID=125479
Did you also upgrade the gateway to the highline variant. Ive seen some retrofits where had to replace the gateway.
   #38
barstanders
C?ID=277262
Hello Dutchie,
I have done that olso but this error have nothing to do with the gateway because on the high its shows the same error.
I want to share somthing about the error couple days ago.
On Thursday I want to open the tailgate of the car with the remote control after pushing the open button the car alarm go off.
So i connect the vcds and I see this message.
527116 - Local data bus 2
U1076 00 [008] - Electrical malfunction
Reset counter: 197
Mileage: 1048574 km
Time: 00:00:00
Strange is the milage date and time?
After this error and cleanig of it I have till now no error on the instrument cluster!!!
barstanders
C?ID=277262
Thursday,11,August,2016,17:01:18:42750
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: WVWZZZAUZDP010048   Mileage: 48286km-30003miles
   Revision: WAH08---
   VCID: 2468B6F82F7D0162E4-8070
Readiness: 0000 0001
   VCID: 7DDEA39CEC5790AACB-8028
   Revision: 00001K06
   VCID: 364C7CB089E183F24A-8062
   VCID: 77D2B1B4CE6BBAFA91-8022
   Coding: 0E4DD5
   Coding: 06A8DD
                    Reset counter: 197
                    Mileage: 1048574 km
                    Time: 00:00:00
   Coding: 0031161041
   VCID: 3D5E639CACD750AA8B-8068
   VCID: 40A01A68DB253D42E0-8014
   Coding: 8400
   VCID: 75CEBBBCD467C8EA83-8020
   Coding: 07AD09002390000800087E00040000
   VCID: 67F2E1F49ECB2A7A01-8032
   VCID: 3A546880BDF96792AE-806E
H14 0035
   Coding: 280000
          B2012 00 [009] -  -
                    Reset counter: 156
                    Mileage: 48180 km
                    Date: 2016.08.03
                    Time: 13:07:28
                    Supply voltage: Terminal 30: 14.6 V
                    Terminal 15: On
   Coding: 03
   VCID: 3FA21994A6DB42BA99-806A
   Coding: 090000
   VCID: 2772A1F45E4BEA7AC1-8072
End-------------------------(Elapsed Time: 02:44)--------------------------
barstanders
C?ID=277262
Scan today 12.00 uhr no faults.
Monday,15,August,2016,12:03:37:42750
VIN: WVWZZZAUZDP010048   Mileage: 48720km-30273miles
   Revision: WAH08---
   Revision: 00001K06
   Coding: 0E4DD5
   Coding: 06A8DD
   Coding: 0031161041
   Coding: 8400
   Coding: 280000
          B2012 00 [009] -  -
                    Reset counter: 165
                    Mileage: 48180 km
                    Date: 2016.08.03
                    Time: 13:07:28
                    Terminal 15: On
   Coding: 03
   Coding: 090000
