Hi mates,
I'm new to VCDS. We have a VW CADDY 2009 in stock, the engine starts with no problem, but the message: "immobilizer end of line" appears for a few seconds and the yellow Immobilizer alarm blinks permanently on the Dash panel.
Any tip is much appreciated.
The Auto Scan Shows no Fault:
Tuesday,31,May,2016,12:11:35:37122
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WV2ZZZ2KZ9X086586 License Plate: HAYAT
Mileage: 200km-124mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WV2ZZZ2KZ9X086586 Mileage: 200km-124miles
Address 01: Engine ( ) Labels: Redir Fail!
Part No SW: 06G 906 022 E HW: 06G 906 022 A
Component: 4220 CNG 26A5V0 2809
Revision: 1RH03--- Serial number: VWX7Z0HN3NL0EL
Coding: 0030071
Shop #: WSC 35110 377 00158
VCID: 2578770EEC7004162D-8070
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0020801
VCID: 76DA604201563F8E54-8022
Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 6FD455267E0C0E4697-803A
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 01000009164623
Coding: 018C4F030004100057000000000000000009FF075C000120000000000000
Shop #: WSC 35110 377 08192
VCID: 335C995652A46AA6B3-8066
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 131108 021 0501
Coding: 00038805
Shop #: WSC 35110
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AJ HW: 6Q0 909 605 AJ
Component: Z7 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037UR0155PH
Coding: 0023095
VCID: 7F3485662E6C7EC607-802A
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 853 0111
Coding: 0000004
VCID: 033C099642841A2663-8056
Part No: 1T0 920 863 F
Component: KOMBIINSTRUMENT VDD 0622
Coding: 0016101
Shop #: WSC 00099 757 173712
VCID: 3744AD4646DC86868F-8062
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 281108F1001967
Coding: E9801F06000202007400
Component: IMMO VDD 0622
Part No SW: 1T0 959 701 M HW: 1T0 959 701 M
Component: Tuer-SG 008 2005
Coding: 0000048
VCID: 41B0C39E1818C83631-8014
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 140 2301
Revision: 00H15000
VCID: 2A628432856E2B6E00-807E
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 808B0C087F2D8405484A036010C0
VCID: 0036069A5392013E7E-8054
Part No SW: 1T0 959 702 M HW: 1T0 959 702 M
Coding: 0000048
VCID: 42B2CC921D1ED32E28-8016
Part No: 1K0 035 186 AF
Component: Radio GR0 036 0034
Revision: 0003606S Serial number: VWZ2Z2H1236336
Coding: 0020200
VCID: 6AE2443245EEEB6EC0-803E
End-------------------------(Elapsed Time: 00:59)--------------------------
Tuesday,31,May,2016,12:35:08:37122
Coding: 0030071
Revision: 00H32001
Coding: 0020801
Coding: 00038805
Shop #: WSC 35110
Coding: 0023095
Coding: 0000004
Coding: 0016101
Coding: 0000048
Revision: 00H15000
Component: KSG 0401
Coding: 0000048
Coding: 0020200
