- May 16, 2014
- 5,469
- 5,936
- Melbourne, Australia
- C?ID=194404
OK: I'll readily admit that my spanking-new HEX-NET was a thing of wonder and glory to behold when I carefully unpacked it from its box this afternoon! After removing my drool from the dongle, I immediately gave it my first challenge: a speed test against my faithful old HEX+CAN for a straight-out autoscan.
Three test were performed:
The Laptop is a Surface Pro 3 x64, Core i7, 8 GB RAM, Windows 10 (no nannyware)
RESULTS:
HEX+CAN
NEX-NET (Cable)
HEX-NET WIFI
So, I'm delighted that the NEX-NET cable speed (1:28 min) has halved the time for an autoscan compared to the HEX+CAN (3:08 Min), but I'm a little disappointed at the performance of the HEX-NET's WIFI speed (20:49 Min). What can be done about the latter. I assume internet speed (which is atrocious here) is not an issue in Access Point Mode?
- HEX+CAN (cable mode - of course)
- HEX NET connected in the traditional cable mode
- HEX NET in WIFI Mode (Access Point Mode)
RESULTS:
HEX+CAN
Friday,06,May,2016,20:37:11:03521
VCDS Version: 16.3.1.1 (x64)
Data version: 20160325
VIN: License Plate: HEX+CAN SPEED-TEST
Mileage: 22679km-14092mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: Mileage: 22679km-14092miles
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1,4l R4 TSI H08 7862
Revision: WAH08---
Coding: 01250032242405082000
Shop #: WSC 04363 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906016G 002011
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 26431A2059EACC0CEE-8072
Part No SW: 0CW 300 045 HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5240
Revision: 00043014 Serial number: CU501212296246
Shop #: WSC 00028 028 00025
ROD: EV_TCMDQ200021.rod
VCID: 76E30A60C9CAFC8C9E-8022
25472 - No Communication with Gear Selector Module
U0103 00 [072] - -
Mileage: 22310 km
Date: 2016.04.17
Time: 12:26:17
Engine speed: 18.75 /min
Engine torque: -100 Nm
Vehicle speed: 61 km/h
Control Module temperature: 11 °C
CURRENT pressure: -10.0 bar
Clutch; primary stat: Fahren
selected gear: GANG_5
Driving position: N
Accelerator position: 0.4 %
DTC memory status: 7168
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
VCID: 7DF1154CECFCAFD4DF-8028
Part No SW: 5G0 907 044 Q HW: 5G0 907 044 Q
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00120004200100011005004012101800
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 3561CD6C944CB79457-8060
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011234701612
Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
VCID: 4385A3B4CA981924E9-8016
Component: WWS 121120 042 0551
Serial number: 121206042218
Coding: 0E4DD5
Component: RLFS 024 0042
Serial number: Y13M01D03H20M05S37S1
Coding: 00A8DD
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231233000504
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3A7BDE50BD5258ECBA-806E
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Serial number: 003F5R01UHNZ
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00061
VCID: 408FACB8DB8E023CF4-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 357670000007612C7C0W
Subsystem 2 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 358670000006332C7C0V
Subsystem 3 - Part No SW: ----------- HW: 480 400 301 13
Serial number: 3516502AF0CD5EC471C+
Subsystem 4 - Part No SW: ----------- HW: 480 400 201 13
Serial number: 3526502B30CD5EC2136J
Subsystem 5 - Part No SW: ----------- HW: 480 401 112 12
Serial number: 3556502B30CD5EC4008M
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Revision: -------- Serial number: 08011304220489
Coding: 0500
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 79F9015CF8D493F4F3-802C
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 235 0555
Coding: 27A501082380800801087E00040000
ROD: EV_DashBoardVDDMQBAB_VW37.rod
VCID: 65C15D2C646C071427-8030
Part No SW: 5Q0 907 530 E HW: 5Q0 907 530 E
Component: GW MQB Mid 121 1109
Revision: -------- Serial number: 0000188941
Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear.rod
VCID: 3365F3749A38A9A479-8066
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H13 0035
Serial number: 02120005290300060291
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3451678601
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000046453458
Coding: 003A02208001020000001000
VCID: 020B66B09502D02CA2-8056
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Serial number: 00000000000000502227
Coding: 0D0000
Coding: 01
ROD: EV_SteerAssisMQB_VW37.rod
VCID: 3D71D54CAC7C6FD49F-8068
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000048027940
Coding: 003A00208E01020000801000
VCID: 010969BC9004CB34BB-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Serial number: 00000000000000502825
Coding: 050000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846
Component: MU-S-N-ER 039 0450
Serial number: V1F00501130081
Coding: 02730008FF00000011510001000900001F0104960100010047
Shop #: WSC 12345 123 61029
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 275D17245EE0D504D5-8072
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H44 0022
Serial number: VWZ8Z9M3400KZM
Subsystem 2 - Part No SW: 5G0 919 866 A HW: -----------
Component: ROW 2013 --- 0022
End-------------------------(Elapsed Time: 03:10)--------------------------
NEX-NET (Cable)
Friday,06,May,2016,20:40:46:16808
VIN: License Plate: HEX-NET CABLE SPEED-TEST
VIN: WVWZZZAUZDP034070 Mileage: 22679km-14092miles
Revision: WAH08---
VCID: 260033F059A6A50CEE-8072
VCID: 76A023B0C986958C9E-8022
U0103 00 [072] - -
Mileage: 22310 km
Date: 2016.04.17
Time: 12:26:17
Driving position: N
VCID: 7DB23C9CECB0C6D4DF-8028
Revision: 00001K06
VCID: 3522E4BC9400DE9457-8060
Air quality sensor:
VCID: 43C68A64CAD47024E9-8016
Coding: 0E4DD5
Coding: 00A8DD
Coding: 0031151011
VCID: 3A38F780BD1E31ECBA-806E
VCID: 40CC8568DBC26B3CF4-8014
Coding: 0500
VCID: 79BA288CF898FAF4F3-802C
VCID: 658274FC64206E1427-8030
VCID: 3326DAA49A74C0A479-8066
H13 0035
Coding: 280000
VCID: 02484F60954EB92CA2-8056
Coding: 0D0000
Coding: 01
VCID: 3D32FC9CAC3006D49F-8068
VCID: 014A406C9048A234BB-8054
Coding: 050000
VCID: 271E3EF45EACBC04D5-8072
End----------(Elapsed Time: 01:28, VBatt start/end: 11.6V/11.6V)-----------
HEX-NET WIFI
Friday,06,May,2016,19:46:29:16808
VIN: License Plate: 1ST HEX-NET WIFI SPEED-TEST
Revision: WAH08---
VCID: A600B3F0D9A6250C6E-80F2
VCID: F6A0A3B04986158C1E-80A2
U0103 00 [072] - -
Mileage: 22310 km
Date: 2016.04.17
Time: 12:26:17
Driving position: N
VCID: FDB2BC9C6CB046D45F-80A8
Revision: 00001K06
VCID: B52264BC14005E94D7-80E0
Air quality sensor:
Address 09: Cent. Elect. Labels: 5Q0-937-08X-MV1.clb
Component: BCM MQBAB M H14 BCM MQBAB M H14 01060106
ROD: N/A
VCID: C3C60A644AD4F02469-8096
Subsystem 1 - Part No: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Coding: 0E4DD5
Subsystem 2 - Part No: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS
Coding: 00A8DD
Coding: 0031151011
VCID: BA3877803D1EB1EC3A-80EE
Address 15: Airbags Labels: 5Q0-959-655.clb
ROD: N/A
VCID: C0CC05685BC2EB3C74-8094
Coding: 0500
ROD: N/A
VCID: F9BAA88C78987AF473-80AC
VCID: E582F4FCE420EE14A7-80B0
VCID: B3265AA41A7440A4F9-80E6
H13 0035
Coding: 280000
VCID: 8248CF60154E392C22-80D6
Coding: 0D0000
Coding: 01
VCID: BD327C9C2C3086D41F-80E8
VCID: 814AC06C104822343B-80D4
Coding: 050000
Address 5F: Information Electr. Labels: 5G0-035-MIB-STD1.clb
VCID: A71EBEF4DEAC3C0455-FFFE
End----------(Elapsed Time: 20:49, VBatt start/end: 11.7V/0.0V)------------
