Hex-NET vs HEX+CAN speed test
DV52
C?ID=194404
OK: I'll readily admit that my spanking-new HEX-NET was a thing of wonder and glory to behold when I carefully unpacked it from its box this afternoon! After removing my drool from the dongle, I immediately gave it my first challenge: a speed test against my faithful old HEX+CAN for a straight-out autoscan.
Three test were performed:
  1. HEX+CAN (cable mode - of course)
  2. HEX NET connected in the traditional cable mode
  3. HEX NET in WIFI Mode (Access Point Mode)
The Laptop is a Surface Pro 3 x64, Core i7, 8 GB RAM, Windows 10 (no nannyware)
RESULTS:
HEX+CAN
Friday,06,May,2016,20:37:11:03521
VCDS Version: 16.3.1.1 (x64)
Data version: 20160325
VIN:    License Plate: HEX+CAN SPEED-TEST
Mileage: 22679km-14092mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN:   Mileage: 22679km-14092miles
Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H08 7862
   Revision: WAH08---
   Coding: 01250032242405082000
   Shop #: WSC 04363 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016G 002011
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 26431A2059EACC0CEE-8072
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5240
   Revision: 00043014    Serial number: CU501212296246
   Shop #: WSC 00028 028 00025
   ROD: EV_TCMDQ200021.rod
   VCID: 76E30A60C9CAFC8C9E-8022
25472 - No Communication with Gear Selector Module
          U0103 00 [072] - -
                    Mileage: 22310 km
                    Date: 2016.04.17
                    Time: 12:26:17
                    Engine speed: 18.75 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 61 km/h
                    Control Module temperature: 11 °C
                    CURRENT pressure: -10.0 bar
                    Clutch; primary stat: Fahren
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 7168
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
   VCID: 7DF1154CECFCAFD4DF-8028
   Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
   Revision: 00001K06
   Coding: 00120004200100011005004012101800
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 3561CD6C944CB79457-8060
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011234701612
   Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 4385A3B4CA981924E9-8016
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    121120  042 0551
   Serial number:         121206042218
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y13M01D03H20M05S37S1
   Coding: 00A8DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231233000504
   Coding: 0031151011
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3A7BDE50BD5258ECBA-806E
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Serial number: 003F5R01UHNZ
   Coding: 98CCC000000000005C00000000C800000065
   Shop #: WSC 00028 028 00061
   VCID: 408FACB8DB8E023CF4-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 357670000007612C7C0W
   Subsystem 2 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 358670000006332C7C0V
   Subsystem 3 - Part No SW: -----------    HW: 480 400 301 13
   Serial number: 3516502AF0CD5EC471C+
   Subsystem 4 - Part No SW: -----------    HW: 480 400 201 13
   Serial number: 3526502B30CD5EC2136J
   Subsystem 5 - Part No SW: -----------    HW: 480 401 112 12
   Serial number: 3556502B30CD5EC4008M
   Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 08011304220489
   Coding: 0500
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 79F9015CF8D493F4F3-802C
   Part No SW: 5G0 920 860     HW: 5G0 920 860
   Component: KOMBI         235 0555
   Coding: 27A501082380800801087E00040000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 65C15D2C646C071427-8030
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000188941
   Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear.rod
   VCID: 3365F3749A38A9A479-8066
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H13 0035
   Serial number: 02120005290300060291
   Coding: 280000
   Serial number: 3451678601
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Serial number: 0000046453458
   Coding: 003A02208001020000001000
   VCID: 020B66B09502D02CA2-8056
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000000502227
   Coding: 0D0000
   Coding: 01
   ROD: EV_SteerAssisMQB_VW37.rod
   VCID: 3D71D54CAC7C6FD49F-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Serial number: 0000048027940
   Coding: 003A00208E01020000801000
   VCID: 010969BC9004CB34BB-8054
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000000502825
   Coding: 050000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846
   Component: MU-S-N-ER     039 0450
   Serial number: V1F00501130081
   Coding: 02730008FF00000011510001000900001F0104960100010047
   Shop #: WSC 12345 123 61029
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 275D17245EE0D504D5-8072
   Component: ABT_Std_Nav  H44 0022
   Serial number: VWZ8Z9M3400KZM
   Subsystem 2 - Part No SW: 5G0 919 866 A    HW: -----------
   Component:  ROW 2013  --- 0022
End-------------------------(Elapsed Time: 03:10)--------------------------
NEX-NET (Cable)
 Friday,06,May,2016,20:40:46:16808
VIN:    License Plate: HEX-NET CABLE SPEED-TEST
VIN: WVWZZZAUZDP034070   Mileage: 22679km-14092miles
   Revision: WAH08---
   VCID: 260033F059A6A50CEE-8072
   VCID: 76A023B0C986958C9E-8022
          U0103 00 [072] - -
                    Mileage: 22310 km
                    Date: 2016.04.17
                    Time: 12:26:17
                    Driving position: N
   VCID: 7DB23C9CECB0C6D4DF-8028
   Revision: 00001K06
   VCID: 3522E4BC9400DE9457-8060
   Air quality sensor:
   VCID: 43C68A64CAD47024E9-8016
   Coding: 0E4DD5
   Coding: 00A8DD
   Coding: 0031151011
   VCID: 3A38F780BD1E31ECBA-806E
   VCID: 40CC8568DBC26B3CF4-8014
   Coding: 0500
   VCID: 79BA288CF898FAF4F3-802C
   VCID: 658274FC64206E1427-8030
   VCID: 3326DAA49A74C0A479-8066
H13 0035
   Coding: 280000
   VCID: 02484F60954EB92CA2-8056
   Coding: 0D0000
   Coding: 01
   VCID: 3D32FC9CAC3006D49F-8068
   VCID: 014A406C9048A234BB-8054
   Coding: 050000
   VCID: 271E3EF45EACBC04D5-8072
End----------(Elapsed Time: 01:28, VBatt start/end: 11.6V/11.6V)-----------
HEX-NET WIFI
Friday,06,May,2016,19:46:29:16808
VIN:    License Plate: 1ST HEX-NET WIFI SPEED-TEST
   Revision: WAH08---
   VCID: A600B3F0D9A6250C6E-80F2
   VCID: F6A0A3B04986158C1E-80A2
          U0103 00 [072] - -
                    Mileage: 22310 km
                    Date: 2016.04.17
                    Time: 12:26:17
                    Driving position: N
   VCID: FDB2BC9C6CB046D45F-80A8
   Revision: 00001K06
   VCID: B52264BC14005E94D7-80E0
   Air quality sensor:
Address 09: Cent. Elect.        Labels: 5Q0-937-08X-MV1.clb
   Component: BCM MQBAB M   H14 BCM MQBAB M   H14 01060106
   ROD: N/A
   VCID: C3C60A644AD4F02469-8096
   Subsystem 1 - Part No: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Coding: 0E4DD5
   Subsystem 2 - Part No: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS
   Coding: 00A8DD
   Coding: 0031151011
   VCID: BA3877803D1EB1EC3A-80EE
Address 15: Airbags        Labels: 5Q0-959-655.clb
   ROD: N/A
   VCID: C0CC05685BC2EB3C74-8094
   Coding: 0500
   ROD: N/A
   VCID: F9BAA88C78987AF473-80AC
   VCID: E582F4FCE420EE14A7-80B0
   VCID: B3265AA41A7440A4F9-80E6
H13 0035
   Coding: 280000
   VCID: 8248CF60154E392C22-80D6
   Coding: 0D0000
   Coding: 01
   VCID: BD327C9C2C3086D41F-80E8
   VCID: 814AC06C104822343B-80D4
   Coding: 050000
Address 5F: Information Electr.        Labels: 5G0-035-MIB-STD1.clb
   VCID: A71EBEF4DEAC3C0455-FFFE
End----------(Elapsed Time: 20:49, VBatt start/end: 11.7V/0.0V)------------
So, I'm delighted that the NEX-NET cable speed (1:28 min) has halved the time for an autoscan compared to the HEX+CAN (3:08 Min), but I'm a little disappointed at the performance of the HEX-NET's WIFI speed (20:49 Min). What can be done about the latter. I assume internet speed (which is atrocious here) is not an issue in Access Point Mode?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The 20+ Minutes via WiFi are NOT normal. You should see results slightly over the HN-USB but way below HUC. During that long scan, did you see where it was specifically "hanging"? You are running a slightly outdated Beta at this point, please re-test this once we have 16.5+ published - with the correlating latest version for the HN itself.
NEtech
C?ID=56995
I don't know if it would affect communication for either car controllers or HEX-NET, but your battery voltage is very low (0.0 V et the end :cool:).
I would recommend a charger or if not possible, let it idle.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I still do not have HEX-NET so I would like to know is it connected over router or directly to the laptop?
Please do not hijack other peoples threads/topics, use the pre-sales support instead for these kind of questions - assuming you haven't found the answer on the website.
EDIT: Uwe moved his question to a new thread
Eric
HC800000
I see issues with wifi in 09, 15, 16 and 5F. That it even completed the autoscan after 20 minutes of retrying shows... well, something :) How far was your laptop from the hexnet? Any obstacles (like a big heavy metal door or dashboard) inbetween? What's the model of your wifi adapter?
Santos
Any window tint? Can you run a network analyzer via cell phone app?
DV52
C?ID=194404
Eric, Sebastian: I've tried the wifi set-up with ver 15.7.4 and pretty much the same behaviour. Doesn't hang at any module in particular - seems to be very slow at random points in the scan process (then it will race through some screens). Haven't tried infrastructure mode as my internal LAN reception in the workshop is hopeless. Access Point mode autoscan works much better on my testbench with just 2 modules (09 & 19) - but it won't do a installation list for some reason - says "function not supported".
As for the distance between dongle and laptop - it was on the driver's seat (about 12 inches away in your American measurements!). I checked the wifi signal strength during the autoscan (had the same concerns as you) and the laptop said "excellent". If I'm the only person with the problem, it must be my laptop set-up. Perhaps the firewall settings need changing?
According to the device manager - the network adaptor is a Marvell AVASTAR Wireless- AC Network Controller. It has the original driver that came with the laptop (version 15.68.9037.59 - dated 30/11/2015). Device manager says that it's working OK
Eric
HC800000
OK, good info. Any chance you can try another wifi-equipped PC?
DV52
C?ID=194404
^^^^ Yep... got my (t)rusty old Asus in the electronics workshop that I could try. Have to first evict the mice that have taken-up residency on the keyboard. Will report as soon as I can
Thanks to everyone that is taking an interest in my problem
DV52
C?ID=194404
Eric: Looks like the problem is in my Surface Pro 3 - I'm surprised, given that it's bog standard - no changes and relatively new . The Asus autoscan results below:
Saturday,07,May,2016,00:11:21:16808
VCDS Version: 15.7.4.1
Data version: 20160216
VIN:    License Plate: ASUS - NEX NET SPEED TEST
   Revision: WAH08---
   VCID: A600B3F0D9A6250EA4-80F2
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: F6A0A3B04986158ED4-80A2
          U0103 00 [072] - -
                    Mileage: 22310 km
                    Date: 2016.04.17
                    Time: 12:26:17
   VCID: FDB2BC9C6CB046D695-80A8
   Revision: 00001K06
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: B52264BC14005E961D-80E0
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: C3C60A644AD4F026A3-8096
   Slave 1:
   Coding: 0E4DD5
   Slave 2:
   Coding: 00A8DD
   Coding: 0031151011
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: BA3877803D1EB1EEF0-80EE
   VCID: C0CC05685BC2EB3EBE-8094
   Coding: 0500
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: F9BAA88C78987AF6B9-80AC
   VCID: E582F4FCE420EE166D-80B0
   VCID: B3265AA41A7440A633-80E6
   Coding: 280000
   VCID: 8248CF60154E392EE8-80D6
   Coding: 0D0000
   Coding: 01
   ROD: EV_SteerAssisMQB.rod
   VCID: BD327C9C2C3086D6D5-80E8
   VCID: 814AC06C10482236F1-80D4
   Coding: 050000
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: A71EBEF4DEAC3C069F-80F2
   Media Player Position 1:
   Engine Control Module 2:
End-------------------------(Elapsed Time: 01:47)--------------------------
I know this is my problem and not an issue with the NEX NET, but can you suggest some areas of investigation - please
PS: Still a good result with HEX NET - twice the speed of HEX+CAN - Woopiee............!!!
Eric
HC800000
We're working on reproducing this locally, possibly today. In the meantime, have you tried switching the computer to performance mode, and turning off power savings for the wifi card? Beta should be a little bit faster on that Asus too, but that's already a nice time :)
Santos
I think i reproduced the problem on a surface 4. It appears the network card disconnects and reconnects while in use. VCDS will try to restore the session if possible. I think thats whats happening with your 20+ min autoscan.
Do you have other network issues?
Friday,06,May,2016,14:05:23:35435
VIN: WVWED71K58W330910   License Plate:
Mileage: 162540km-100997mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65 77
VIN: WVWED71K58W330910   Mileage: 162540km-100997miles
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AD    HW: 1K0 907 115 AD
   Component: 2.0l R4/4V TFSI     0060
   Revision: E3H12---    Serial number: **** *** ****!
   Coding: 0403010818070160
   Shop #: WSC 03738 444 38140
   VCID: E89CF9EFDBF9307C9C-80BC
Readiness: 0010 1000
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 01269 785 00200
   VCID: F3A69E83923FC3A439-80A6
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   Component: Climatic PQ35   142 1111
   VCID: FCB4B5BFBF618CDC68-FFFE
Unable to communicate with address 09. Are you sure the doors are unlocked?
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0303069
   Coding: 0000000
   VCID: B3265E83D2BF83A4F9-80E6
            000 -  -
                    Fault Frequency: 24
                    Reset counter: 220
                    Mileage: 161756 km
                    Time: 13:03:25
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0B39V1
   Coding: 0013899
   VCID: EC9485FFCF011C5CF8-80B8
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME3B6110351
   Subsystem 3 - Serial number: 6342MSME28144F7ER
   Subsystem 4 - Serial number: 6352QSME5D777927Y
   Subsystem 5 - Serial number: 6362QSME6033445DG
   Subsystem 6 - Serial number: 63727SME15590326Y
   Subsystem 7 - Serial number: 63827SME15584D625
No Faults Found
Address 16: Steering wheel        Labels: None
   Part No HW: 1K0 953 549 BP
   VCID: D5E2C01B3C8BBD9437-8080
   Part No SW: 1K6 920 974 A    HW: 1K6 920 974 A
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H33NP7VV
   Coding: 0005403
   Shop #: WSC 06417 444 54452
   VCID: B2285B872DA58AACF2-80E6
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 180408F1008767
   Coding: E9811F070017020000
   Shop #: WSC 01279 785 00200
   VCID: B02C518F23A9B8BC84-80E4
            000 -  -  - Intermittent
                    Mileage: 149944 km
                    Time: 18:59:26
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   VCID: FDB2B8BBA47B85D45F-80A8
   Component: IMMO            VDD 2216
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: B83C69AFCBD960FCCC-80EC
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: B522609BDCCB9D94D7-80E0
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 RDK 052 0221
   Coding: 1B9006885103083F7D040D8FB0080A04889C00
   Shop #: WSC 12345 785 00200
   VCID: 8444CD5FC791F41C10-80D0
   Coding: 0001076
   VCID: B93A6CABF0D379F433-80EC
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: F4A49D9F9731C49C20-80A0
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3AD 035 190 A    HW: 3AD 035 190 A
   Component: RCD510USBRVC  003 0003
   Revision: -----001    Serial number: VWZ4Z3N8141478
   Coding: 01000424040005
   Shop #: WSC 00079 790 12345
   VCID: AB1646E3CA8FDB64B1-80FE
                    Reset counter: 20
                    Mileage: 142330 km
                    Time: 17:46:27
   Component:    RDK              0450
   Coding: 0100101
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520286508
   Coding: 412100
   VCID: A91ABCEBC073C97443-80FC
01526 - Emergency Call Button (E276)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 49
                    Mileage: 149944 km
End----------(Elapsed Time: 04:02, VBatt start/end: 13.9V/13.8V)-----------
Santos
It doesnt appear to be network card specific. I tried another USB network card and ran into the same issue. I also modded the registry to bring back high performance mode in the power settings, no change as well.
DV52
C?ID=194404
^^^^ Santos: Hi . Sorry that I haven't replied sooner - the tyranny of distance and our out-of-sync sleeping hours, alas! Many thanks for your efforts (and those of the rest of the RT crew) on my behalf.
I'm surprised that this problem hasn't become evident sooner - the Surface series laptops aren't new and they are "mainstream" - surely I can't be the first to have hooked-up a HEX-NET to one of these laptops?
Anyhow, My Surface Pro 3 has not, and does not show any symptoms of malfunction - I have set-up a home based LAN (both Ethernet and WIFI) and everything works OK. I have lousy internet speed here, but this is because of our 4th world ISP infrastructure - Australia uses carrier pigeons to deliver the data packets!!
Since last night's problems have become evident, I have downloaded Microsoft's latest Windows 10 driver pack for the Surface laptop (which has a new driver specific to the Marvell network card) - still no difference. Without wanting to disclose any RT secrets - in layman's words - what's special about the HEX-NET's protocols that doesn't happen in normal WIFI connected devices?
PS: It's OK if the Surface Pro problem can't be fixed - the increased speed of the HEX-NET is so good, I'm more than happy to use it in cable mode, or with the Asus. It's a great evolution to the HEX+CAN!
They're dang expensive for what they are, so they tend to be rare among our customers.
We're wondering that ourselves right now! We certainly hope to find out. But that won't be happening today. We'll looking into it more next week.
Eric
HC800000
I'm sure Shaun will have interesting insight when he comes in Monday; Santos and I saw a couple puzzling things on Wireshark already, but how that leads us to a fix remains to be seen. In the meantime, feel free to play with the new Beta (via USB if you don't have all day! :) ) and post some autoscans :thumbs:
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
The newer ones have hardware assisted power management trickery, Connected Standby / InstantGo among other things I forget, that I think is fairly rare.
What is it you're seeing?
I should have access to a Surface 3 (non-Pro) in a couple more weeks. It came out of a cereal box. No joke. I think they were dumping old inventory.
Jason
DV52
C?ID=194404
Wow: The speed of the HEX-NET just keeps getting faster!!
AUTOSCAN SPEED TEST
VCDS Type Elapsed Time (mins) ver: Beta 16.3.1.1 Elapsed Time (Mins) ver: Beta 16.5.0.4
HEX+CAN (Cable)03:1003:12
HEX-NET (Cable) 01:2801:15
HEX-NET (WIFI)01:4701:25
Santos
Shaun and I found a way to make it work. The issue appears to be Microsoft pinging the mothership and delaying HEX-NET packets up to 8 seconds. I was able to get it to scan by stopping the " Network location Awareness " service and leaving the surface plugged into the wall.
This is not an acceptable fix. We are still looking into it.
Update: After a reboot it looks to be broken again, disabling the service now makes no difference.
DV52
C?ID=194404
Santos: Again, appreciate your (and Shaun's) valiant endeavours, but I'm reminded of the "principal of factor scarcity" - with 20% effort, you both have probably found 80% of the likely result! If the investigations prove time-consuming (as I suspect that they wil bel), I'm more than happy to just use my old Asus laptop when I want to connect HEX NET in AP mode.
Cheers
