hi
My friend he bought this used car three months ago...
Some question:
1) this error of airbag means the car was crashed ???
2) the Gateway is not listed -----> now i see that 19 missing in the scan list
3) the odometer show 152240km while with the EDC 15-16 application result 152242km , after 10 years the difference was only 2KM , i suspect
that both KM was roller-back ,could be??
4) for the bluethoot there must be installed the module 77-telephone??
Regards
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUZZZ8E15A503133 License Plate:
Mileage: 152240km-94597mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8E15A503133 Mileage: 152240km-94597miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC 0000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 82617 264 89204
VCID: 75EAF0D81CD55B9652-8020
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 2648E79491F3600E2B-8072
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2731
Coding: 00000
VCID: 6BDED6A019919D66B4-50AC
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul NDL 0304
Coding: 10012
Shop #: WSC 00792
VCID: 3B7E26E02971CDE664-4A82
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M002SN64
Coding: 0033622
VCID: 3B7E26E07A71CDE664-806E
Subsystem 1 - Serial number: 6332DRB4017C13A8P
Subsystem 2 - Serial number: 6342DRB4017C5219L
Subsystem 3 - Serial number: 6352ARB4004F9E4E%
Subsystem 4 - Serial number: 6362ARB400508C3BM
Subsystem 5 - Serial number: 63729RB4004FFC58%
Subsystem 6 - Serial number: 63829RB4004FDAFFD
01794 - Control Module - Incorrect Chassis (VIN) Number
Fault Status: 00110000
Fault Frequency: 15
Reset counter: 99
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
Fault Status: 00101011
Reset counter: 99
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Reset counter: 99
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 00012
Shop #: WSC 06325
VCID: 438E5E005181B5262C-4A82
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006141
Shop #: WSC 71680 001 00834
VCID: 2952ECA883ED4F7606-50C8
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006141
VCID: 2952ECA883ED4F7606-50AC
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H54 0650
Revision: 08S Serial number: AUZBZ7E0403297
Coding: 0301113
Shop #: WSC 00792 264 02069
VCID: 244CFD9CE4CF921E35-50E6
00532 - Supply Voltage B+
Fault Frequency: 9
Reset counter: 213
Date: 2009.06.10
Time: 17:23:39
Voltage: 12.20 V
Fault Frequency: 9
Reset counter: 213
Date: 2009.06.10
Time: 17:23:38
Voltage: 12.20 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BQ
Component: Komfortgerát T01 3232
Coding: 07024
Shop #: WSC 06325
VCID: 010294080B1D67367E-4A82
Subsystem 1 - Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 0305
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
00935 - Electric Window Motor; Rear Right (V27)
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301113
Fault Frequency: 9
Reset counter: 213
Date: 2009.06.10
Time: 17:23:39
Voltage: 12.20 V
Fault Frequency: 9
Reset counter: 213
Date: 2009.06.10
Time: 17:23:38
Voltage: 12.20 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
End-------------------------(Elapsed Time: 06:43)--------------------------
Some question:
Regards
