Audi A4 2005 avant fault Airbag
Ciamardo
Italy
C?ID=105004
hi
My friend he bought this used car three months ago...
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUZZZ8E15A503133   License Plate:
Mileage: 152240km-94597mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E15A503133   Mileage: 152240km-94597miles
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 GN    HW: 028 101 211 3
   Component: R4 2,0L EDC 0000SG  9618
   Revision: 12345678    Serial number:
   Coding: 0000072
   Shop #: WSC 82617 264 89204
   VCID: 75EAF0D81CD55B9652-8020
   Part No SW: 8E0 910 517 B    HW: 8E0 614 517 AT
   Component: ESP8 front      H04 0180
   Coding: 0004401
   Shop #: WSC 06325 000 00000
   VCID: 2648E79491F3600E2B-8072
   Part No: 8E0 820 043 AL
   Component:   A4 Klimaautomat   2731
   Coding: 00000
   VCID: 6BDED6A019919D66B4-50AC
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  NDL 0304
   Coding: 10012
   Shop #: WSC 00792
   VCID: 3B7E26E02971CDE664-4A82
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036M002SN64
   Coding: 0033622
   VCID: 3B7E26E07A71CDE664-806E
   Subsystem 1 - Serial number: 6332DRB4017C13A8P
   Subsystem 2 - Serial number: 6342DRB4017C5219L
   Subsystem 3 - Serial number: 6352ARB4004F9E4E%
   Subsystem 4 - Serial number: 6362ARB400508C3BM
   Subsystem 5 - Serial number: 63729RB4004FFC58%
   Subsystem 6 - Serial number: 63829RB4004FDAFFD
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 -  -  - Intermittent
                    Fault Status: 00110000
                    Fault Frequency: 15
                    Reset counter: 99
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
                    Fault Status: 00101011
                    Reset counter: 99
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
                    Reset counter: 99
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 00012
   Shop #: WSC 06325
   VCID: 438E5E005181B5262C-4A82
   Part No SW: 8E0 920 931 D    HW: 8E0 920 931 D
   Component: KOMBI+WFS 4     H12 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0006141
   Shop #: WSC 71680 001 00834
   VCID: 2952ECA883ED4F7606-50C8
   Coding: 0006141
   VCID: 2952ECA883ED4F7606-50AC
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 8E0 035 192 C    HW: 8E0 035 192 C
   Component: RNS-E HIGH EU   H54 0650
   Revision:      08S    Serial number: AUZBZ7E0403297
   Coding: 0301113
   Shop #: WSC 00792 264 02069
   VCID: 244CFD9CE4CF921E35-50E6
00532 - Supply Voltage B+
                    Fault Frequency: 9
                    Reset counter: 213
                    Date: 2009.06.10
                    Time: 17:23:39
                    Voltage: 12.20 V
                    Fault Frequency: 9
                    Reset counter: 213
                    Date: 2009.06.10
                    Time: 17:23:38
                    Voltage: 12.20 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BQ
   Component: Komfortgerát T01    3232
   Coding: 07024
   Shop #: WSC 06325
   VCID: 010294080B1D67367E-4A82
   Subsystem 1 - Part No: 8E1959801F
   Component: Tõrsteuer.FS BRM 0305
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0205
00935 - Electric Window Motor; Rear Right (V27)
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0301113
                    Fault Frequency: 9
                    Reset counter: 213
                    Date: 2009.06.10
                    Time: 17:23:39
                    Voltage: 12.20 V
                    Fault Frequency: 9
                    Reset counter: 213
                    Date: 2009.06.10
                    Time: 17:23:38
                    Voltage: 12.20 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
End-------------------------(Elapsed Time: 06:43)--------------------------
Some question:
1) this error of airbag means the car was crashed ???
2) the Gateway is not listed -----> now i see that 19 missing in the scan list :eek:
3) the odometer show 152240km while with the EDC 15-16 application result 152242km , after 10 years the difference was only 2KM :confused: , i suspect
that both KM was roller-back ,could be??
4) for the bluethoot there must be installed the module 77-telephone??
Regards
Welder75
Canada
C?ID=261654
1) this error of airbag means the car was crashed ??? no, all codes are intermittent . clear codes, drive around the block a few times see if anything returns. if return as intermittent-- check fuses,grounds,connections. looks like he had a dead or disconnected battery at one time.
2) the Gateway is not listed -----> now i see that 19 missing in the scan list --- looked at other 8E chassis autoscans---they don't have it either.
3) the odometer show 152240km while with the EDC 15-16 application result 152242km , after 10 years the difference was only 2KM , i suspect
that both KM was roller-back ,could be?? really????? your bent out of shape on a 2km difference , and if you suspect both....1 was roll back....2 was .....?
4) for the bluethoot there must be installed the module 77-telephone?? i am not sure, someone else can answer.
Ahhhhhhhhh........ the 2KM discrepancy is considered normal.
What are 081 block values for VIN in cluster/immo verse engine and airbag?
I doubt it. See Welder's comment about "Intermittent"
There's no 19 in a B6 A4.
Cannot rule it out. It wasn't that long after we put the EDC-15/16 mileage readout in VCDS that the odometer fraud people figured out how to tweak the mileage in those ECUs as well.
Correct. No 77, no Bluetooth.
