- Joined
- May 8, 2014
- Messages
- 132
- Reaction score
- 84
- Location
- Rossendale, Lancashire, UK
- VCDS Serial number
- C?ID=159389
Hi
I'm considering getting a short (1m?) OBD2 extension cable for use with the HEX-NET in Infrastructure mode. I am finding that the location of the OBD2 port on the Octavia 3 means the HEX-NET gets a variable at best wi-fi signal, probably not helped much by the SmartGate wifi module under the drivers seat about 2 feet away!
Plus, you can't see any of the LEDs without a mirror!
My thoughts are to extend so that the HEX-NET can end up sat on top of the dashboard where it should get a better wi-fi signal without all that tin in the way, plus it is further away from the SmartGate module (and yes, the infrastructure AP and the SmartGate are on different channels over 5 channels apart).
So, I have seen some cables advertised as all 16 pins connected, and some as 9 pins connected - do I need all 16 pins to be connected on an extension cable as there are some that utilise a low profile right angled OBD2 male connector and a flat cable which look good, but only have 9 pins connected.
