Hi, I need help with verification or login is OK.
Car: Passat B5 1.9 tdi (AWF) ABS/ESP BOSCH 5.7
Login: 04255 (?)
When I write this login communication with the module is broken, I must turn off/on the ignition. Pin is wrong or module ABS/ESP is crash?
I need login because module don't have coding (00000).
Can anybody help me with this situation?
FULL SCAN
Login: 04255 (?)
FULL SCAN
Tuesday,15,December,2015,16:58:52:26855
VCDS Version: 15.7.2.0
Data version: 20151124
VIN: WVWZZZ3BZ4E018761 License Plate:
Mileage: 310210km-192755mi Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ4E018761 Mileage: 310210km-192755miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 KE
Component: 1,9l R4 EDC 0000SG 4898
Coding: 00002
Shop #: WSC 05314
VCID: 64C7AB51F433581EEF-4B02
WVWZZZ3BZ4E018761 VWZ7Z0C7747003
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 00000
VCID: 2541F655BF89E11638-515E
35-00 - -
66-10 - Not Matched - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 08 AIRBAG VW61 04 0003
Coding: 12344
Shop #: WSC 05311
VCID: 2447EB51B4B3181E2F-5140
00532 - Supply Voltage B+
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 809 C
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05115
VCID: 2447EB51B4B3181E2F-5124
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: 70EFD70130CBF4BE9B-5140
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 85 Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 05311
VCID: 36632119122F9A8E81-4B1C
Subsystem 1 - Part No: 1C1959801
Component: 85 Tőrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 85 Tőrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 85 Tőrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 85 Tőrsteuer.HR KLO 0202
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 05401
Shop #: WSC 05311
VCID: 275DFC5DC585F3060A-4B02
00852 - Loudspeaker(s); Front
End-------------------------(Elapsed Time: 05:07)--------------------------
