Passat B5 - login - ABS/ESP 5.7
blokers77
Poland
C?ID=206192
Hi, I need help with verification or login is OK.
Car: Passat B5 1.9 tdi (AWF) ABS/ESP BOSCH 5.7
Login: 04255 (?)
When I write this login communication with the module is broken, I must turn off/on the ignition. Pin is wrong or module ABS/ESP is crash?
I need login because module don't have coding (00000).
Can anybody help me with this situation?
FULL SCAN
Tuesday,15,December,2015,16:58:52:26855
VCDS Version: 15.7.2.0
Data version: 20151124
VIN: WVWZZZ3BZ4E018761   License Plate:
Mileage: 310210km-192755mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWZZZ3BZ4E018761   Mileage: 310210km-192755miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 KE
   Component: 1,9l R4 EDC 0000SG  4898
   Coding: 00002
   Shop #: WSC 05314
   VCID: 64C7AB51F433581EEF-4B02
   WVWZZZ3BZ4E018761     VWZ7Z0C7747003
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 00000
   VCID: 2541F655BF89E11638-515E
            35-00 -  -
            66-10 - Not Matched - Intermittent
   Part No: 1C0 909 605 C
   Component: 08 AIRBAG VW61 04   0003
   Coding: 12344
   Shop #: WSC 05311
   VCID: 2447EB51B4B3181E2F-5140
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 809 C
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 05115
   VCID: 2447EB51B4B3181E2F-5124
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05311
   VCID: 70EFD70130CBF4BE9B-5140
   Part No: 1C0 959 799 B
   Component: 85 Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 05311
   VCID: 36632119122F9A8E81-4B1C
   Subsystem 1 - Part No: 1C1959801
   Component: 85 Tőrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 85 Tőrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 85 Tőrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 85 Tőrsteuer.HR KLO 0202
   Part No: 1J0 035 186 E
   Component:  Radio BNO         0006
   Coding: 05401
   Shop #: WSC 05311
   VCID: 275DFC5DC585F3060A-4B02
00852 - Loudspeaker(s); Front
            36-10 - Open Circuit - Intermittent
End-------------------------(Elapsed Time: 05:07)--------------------------
Thanks guys,
1ZC Disc brakes, front (Geomet D)
T9J 4-cylinder diesel engine 1.9 L unit 038.K
G0C 5-speed manual transmission
This line can be tricky blokers77
0xx?x: Engine
5 = (PR-T5X/T4N/T9J*/T6T/T1K/T1E/T7F*) (* with Brakes: PR-1LB/1LE/1ZC)​
Jef
HQ
Remember kids, you have to do the Steering Angle Sensor (G85) Calibration right after you code it!!
