;SW:5C6-920-955-A HW:5C6-920-955-A --- Instruments
;Component:KOMBI H04 1007, Coding:270A01
;EV_Kombi_UDS_VDD_RM09,A05730,EV_Kombi_UDS_VDD_RM09_SK35.rod
;Wednesday,28,October,2015,08:04:09:59779
;VCDS Version: Release 15.7.1 Data version: 20150904
;VCID: 2D511D6F7CF8BD56C6-8078
(1)-Acoustics for timeout signaling-All-wheel electronics,Not available
(2)-Acoustics for timeout signaling-Lock Electronics,Not available
Activating and deactivating all development messages,not active
(1)-Additional coding-Speed source,via CAN
(2)-Additional coding-Coolant temperature source,via CAN
(3)-Additional coding-Tank characteristic curve,1
(4)-Additional coding-Number of fuel level sensors,1
(5)-Additional coding-Locking bit,locked
Automatic door locking,Yes
(1)-Component protection mode-Radio,not requested
(2)-Component protection mode-Navigation,requested
(3)-Component protection mode-Stopping distance reduction,not requested
(4)-Component protection mode-Vorhalt,not requested
Component protection showroom mode,not activated
Display correction of consumptions and operating range,100 %
Display correction of fuel gauge,-2.0
Display depiction,Not available
Distance,130 km
(1)-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SID on
(2)-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI)
(3)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation
(4)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure
(5)-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver
(6)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,poor oil quality
(7)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster
ESI: distance driven from inspection,100 km
ESI: oil quality,poor oil quality
ESI: Resetting ESI,Reset
ESI: soot entry,0 km
ESI: thermal load,100 km
ESI: time from inspection,0 d
FIX: Distance covered since last mileage-dependent inspection,100 km
FIX: Max. distance until next mileage-related inspection,32200 km
FIX: Maximum time until next time-dependent inspection,730 d
FIX: Reset value for next mileage-dependent inspection,32200 km
FIX: Reset value for next mileage-dependent inspections,730 d
FIX: Time since last time-dependent inspection,25 d
Hour,8 H
Ignition active message; actuator,Driver door
Language version,US English
Light warning buzzer; condition,Open
Minute,4 min
Pause recommendation,Yes
Seat belt warning,Version 2
Service notification,30 d
Service notification in days,30 d
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,On
(6)-Service-key settings-p_main_switch_basis,On
SIA: maximum value of distance to service,16100 km
SIA: maximum value of time to service,372 d
Speed threshold of dynamic oil pressure warning,kein Offset
Steering Assistance,Version 2
(1)-Units adjusted-Temperature,°C
(2)-Units adjusted-Distance,miles
(3)-Units adjusted-Speed,Miles per hour
(4)-Units adjusted-Pressure,psi
(5)-Units adjusted-Volume,gallons (US)
(6)-Units adjusted-Time,24h
(7)-Units adjusted-Date,mm_dd_yy
(8)-Units adjusted-Consumption,Miles per gallon (US)
Volume to be replenished,No
(1)-additional_adaption-Logic address,0
(2)-additional_adaption-Function status,No
indicator_celebration,not active
Service_Key_Clear_All_Counters,Yes
(1)-velocity_detection-Speed source,Distance impulses
(2)-velocity_detection-Distance impulses,4
