As a newbie I played with different options and this way managed to delete both out of two remote keys for the above vehicle... Central locking with any of the two keys works perfectly but only using the key...
As far as I remember the option was somewhere in Adaptation channel for Centr Elec; tried different methods but with no luck.
How do we program a new remote in this situation?
Thanx!
Thanx!
Thursday,07,May,2015,17:02:58:55185
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WV2ZZZ7HZCH0XXXXX License Plate:
Mileage: 162460km-100947mi Repair Order: autoscan 2015-05-07
Chassis Type: 7H (6N0)
Scan: 01 02 03 08 09 10 15 17 18 19 25 56 0B
VIN: WV2ZZZ7HZCH0XXXXX Mileage: 162460km-100947miles
Address 01: Engine (J623-CCHA) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 019 DH HW: 03L 907 309 K
Component: R4 2,0L EDC H43 9133
Revision: 26H43--- Serial number: 00000000000000
Coding: 0125401A230400080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
ROD: EV_ECM20TDI01103L906019DG.rod
VCID: 74E7E1CADF6CBE817A7-8021
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BT 300 045 R HW: 0BH 927 711 C
Component: DSG DQ500-7F H08 2255
Revision: 00H08V01
ROD: EV_TCMDQ500021_VN75.rod
VCID: 4487710ACF4C4E010A7-8011
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 208724AD09AC049E24A49072AA5E10
Shop #: WSC 02756 790 49152
VCID: 397910FEB08E03E9691-806C
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E5 907 047 BA HW: 7E5 907 047 BA
Component: Climatic-T5 H19 0404
Revision: 00001009
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 6FEDEEA6B64A9D59875-803A
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0254
Revision: BO047001 Serial number: 0429 354110930
Coding: B9B079BA0E612413922048102C2B8DD40000410F60040000300000000000
Shop #: WSC 02756 790 12345
Subsystem 1 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 003 3311
Coding: 050000
Subsystem 2 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 003 3311
Coding: 040000
Subsystem 3 - Part No: 7E1 951 171
Subsystem 5 - Part No: 7E1 951 171
03302 - Response Closing Status of Passenger's Door
Reset counter: 219
Mileage: 162457 km
Date: 2015.05.05
Time: 17:32:48
03303 - Response Closing Status of Rear Left Door
Fault Frequency: 9
Reset counter: 220
Mileage: 162457 km
Date: 2015.05.05
Time: 17:32:37
03304 - Response Closing Status of Rear Right Door
Fault Frequency: 8
Reset counter: 220
Mileage: 162457 km
Date: 2015.05.05
Time: 17:32:37
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 E HW: 7E0 919 475 A
Component: PARKHILFE 8K H11 0013
Revision: -------- Serial number: 47401130700655
Coding: 108101
ASAM Dataset: EV_VW75XParkAssis8K A01005
ROD: EV_VW75XParkAssis8K_VN75.rod
VCID: 346721CA9FECFE81BA7-8061
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL009PS3K
Coding: 000000000000000000000000000000003039
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750_SK12.rod
VCID: 35611CCE9496E7898D9-8060
Part No SW: 7E0 920 970 E HW: 7E0 920 970 E
Component: KOMBI H04 0305
Coding: 460C00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2C5739AA47DCA641E27-8079
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2447D18AE70C6E012A7-8071
02245 - Connection; RF Remote Control
Mileage: 162445 km
Date: 2015.05.05
Time: 02:45:12
Temperature: 62.0°C
Voltage: 13.46 V
Temperature: 16.5°C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0254
Revision: BO047001
Coding: 042300
VCID: 70EFEDDAA37482A19EF-8025
Component: IMMO H04 0305
Coding: 000002
Shop #: WSC 12345 123 12345
VCID: 6ADBFFB28DA87871D0B-803F
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 7E0 035 156 B HW: 7E0 035 156 B
Component: Radio H42 0105
Revision: R0000000 Serial number: VWZAZ1L2284342
Coding: 0700020002
Shop #: WSC 02754 790 12345
VCID: 224BD7923D18603158B-8077
00857 - CD Changer Unit (R41)
Reset counter: 178
Mileage: 162445 km
Date: 2015.05.05
Time: 02:22:51
03138 - Input AUX IN
Fault Status: 01101011
Reset counter: 178
Mileage: 162445 km
Date: 2015.05.05
Time: 02:22:51
End-------------------------(Elapsed Time: 02:27)--------------------------
