VW Transporter 7H remote central locking
claitero
C?ID=240949
Hi,
As a newbie I played with different options and this way managed to delete both out of two remote keys for the above vehicle... Central locking with any of the two keys works perfectly but only using the key...
As far as I remember the option was somewhere in Adaptation channel for Centr Elec; tried different methods but with no luck.
How do we program a new remote in this situation?
Thanx!
Thursday,07,May,2015,17:02:58:55185
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WV2ZZZ7HZCH0XXXXX   License Plate:
Mileage: 162460km-100947mi   Repair Order: autoscan 2015-05-07
Chassis Type: 7H (6N0)
Scan: 01 02 03 08 09 10 15 17 18 19 25 56 0B
VIN: WV2ZZZ7HZCH0XXXXX   Mileage: 162460km-100947miles
Address 01: Engine (J623-CCHA)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9133
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 0125401A230400080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 74E7E1CADF6CBE817A7-8021
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BT 300 045 R    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H08 2255
   Revision: 00H08V01
   ROD: EV_TCMDQ500021_VN75.rod
   VCID: 4487710ACF4C4E010A7-8011
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 208724AD09AC049E24A49072AA5E10
   Shop #: WSC 02756 790 49152
   VCID: 397910FEB08E03E9691-806C
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 BA    HW: 7E5 907 047 BA
   Component: Climatic-T5   H19 0404
   Revision: 00001009
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 6FEDEEA6B64A9D59875-803A
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0254
   Revision: BO047001    Serial number: 0429 354110930
   Coding: B9B079BA0E612413922048102C2B8DD40000410F60040000300000000000
   Shop #: WSC 02756 790 12345
   Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  003 3311
   Coding: 050000
   Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 040000
   Subsystem 3 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 7E1 951 171
03302 - Response Closing Status of Passenger's Door
                    Reset counter: 219
                    Mileage: 162457 km
                    Date: 2015.05.05
                    Time: 17:32:48
03303 - Response Closing Status of Rear Left Door
                    Fault Frequency: 9
                    Reset counter: 220
                    Mileage: 162457 km
                    Date: 2015.05.05
                    Time: 17:32:37
03304 - Response Closing Status of Rear Right Door
                    Fault Frequency: 8
                    Reset counter: 220
                    Mileage: 162457 km
                    Date: 2015.05.05
                    Time: 17:32:37
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47401130700655
   Coding: 108101
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_VN75.rod
   VCID: 346721CA9FECFE81BA7-8061
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL009PS3K
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750_SK12.rod
   VCID: 35611CCE9496E7898D9-8060
   Part No SW: 7E0 920 970 E    HW: 7E0 920 970 E
   Component: KOMBI         H04 0305
   Coding: 460C00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 2C5739AA47DCA641E27-8079
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2447D18AE70C6E012A7-8071
02245 - Connection; RF Remote Control
                    Mileage: 162445 km
                    Date: 2015.05.05
                    Time: 02:45:12
                    Temperature: 62.0°C
                    Voltage: 13.46 V
                    Temperature: 16.5°C
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0254
   Revision: BO047001
   Coding: 042300
   VCID: 70EFEDDAA37482A19EF-8025
   Component: IMMO          H04 0305
   Coding: 000002
   VCID: 6ADBFFB28DA87871D0B-803F
   Part No SW: 7E0 035 156 B    HW: 7E0 035 156 B
   Component: Radio         H42 0105
   Revision: R0000000    Serial number: VWZAZ1L2284342
   Coding: 0700020002
   Shop #: WSC 02754 790 12345
   VCID: 224BD7923D18603158B-8077
00857 - CD Changer Unit (R41)
                    Reset counter: 178
                    Mileage: 162445 km
                    Date: 2015.05.05
                    Time: 02:22:51
03138 - Input AUX IN
                    Reset counter: 178
                    Mileage: 162445 km
                    Date: 2015.05.05
                    Time: 02:22:51
End-------------------------(Elapsed Time: 02:27)--------------------------
Adaptation Channel 000 clears them.
Adaptation Channel 001 is where they're learned.
However, I don't have an exact procedure handy.
claitero
C?ID=240949
That's what I was trying to do, putting 1,2,01,02,001,0002 and so on as read somewhere that the number of zeros could make a difference. The best I get is the test button active, after which the final value goes back to 0. At no time did I get the save button active.
I only just purchased the vehicle, one of the remotes is brand new and both of them worked fine just a few moments before I deleted them from the memory....
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Enter/Save 0, then PRESS remote #1. Repeat procedure with all available remotes.
claitero
C?ID=240949
Wow, that worked!
Thanks Sebastian, both remotes work now as they used to!
Now I don't know if I should start a new thread, the reason I started playing with remotes was that I wanted to enable remotely closing/rotating mirrors... I've seen a t5 2012 with such a function so believe it's do-able...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I did not get my 2014 California to do it, but maybe I didn't find the right setting just yet? :) If it is possible, it's in the door control module coding (slave 1&2 of your #09).
JS3
C?ID=240511
claitero - did you manage to work out the coding for remote closing mirrors? Thanks.
