VCDS Version: Release 14.10.2
Data version: 20150311
Saturday,25,April,2015,17:22:23:03310
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
76
VIN: WVWSR61J25W054641 Mileage: 328180km-203921miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 906 016 Q HW: 028 101 181 2
Component: R4 1,9L EDC G000SG 6110
Revision: 12345678 Serial number: VWZ7Z0D0988051
Coding: 0150031
Shop #: WSC 00000 785 00200
VCID: 22083D04FCC31F3158B-5184
19463 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
RPM: 2100 /min
Torque: 116.0 Nm
Speed: 96.0 km/h
Load: 44.7 %
Voltage: 14.44 V
Bin. Bits: 00101000
Idle Stabilization: 0.0°KW
(no units): 48.0
P1570 - 000 - - Intermittent
Torque: 68.0 Nm
Voltage: 11.40 V
Bin. Bits: 00101100
Bin. Bits: 00000000
(no units): 0.0
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 01266 785 00200
VCID: 3424CB5C56378181BA7-5184
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 17 AIRBAG VW61 0108 0003
Coding: 12599
Shop #: WSC 01266
VCID: 271E2C10C7E1FA190F5-5160
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 Q
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15232
Shop #: WSC 00050
VCID: 3B36E0602B694EF97BD-5160
WVWSR61J25W054641 VWZ7Z0D0988051
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01266
VCID: 70AC074C32AFFDA19EF-5160
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8A Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 01266
VCID: 373EFC5017416A999F5-4B3C
Component: 8A Tõrsteuer.FS KLO 0202
Component: 8A Tõrsteuer.BF KLO 0202
Component: 8A Tõrsteuer.HL KLO 0202
Component: 8A Tõrsteuer.HR KLO 0202
01141 - Luggage Compartment Unlocking Switch (E165)
27-00 - Implausible Signal
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio PM6 0016
Coding: 00031
Shop #: WSC 01266
VCID: 24043B1CB6D711012A7-5160
End-------------------------(Elapsed Time: 07:53)--------------------------
I am trying to program a new key from Volkswagen to my 05 Jetta, but when I try to login to the 25-Immobilizer with my SKC, I am told login code not accepted, but I am able to login to 17-Instruments with the same SKC.
Can I program the key in 17-Instruments?
Or what am I doing wrong?
