How to change comfort turning singal cycle for A6 C7
hkaudi
Hong Kong
C?ID=183368
Any brother know how to change comfort turning singal cycle for A6 C7? I really want to change it, please help!
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
Check if you have the same settings on your A6?
I changed the change comfort turning singal cycle on mine a long time ago.
Now its not a bad feature this I mainly use it on motorways but with 3 flashes by default someone could miss a couple if they aren't looking.
Click on 09-Cent. Elect.
Then on Cent. Elect. click the Adaptation - 10 button
Select Comfort Turn Signals (Cycle) from the combobox. That will show Channel 31 and the Stored value (default) is 3. You can change the number of blinks from 1 to 5 using the up and down buttons. Don’t bother typing numbers into the New value box as the Save button won’t be enabled, just use the up/down buttons. Click Save when done and then click Done, Go Back.
A6 C7 VCDS Tricks
hkaudi
Hong Kong
C?ID=183368
Hi, Keith, thank for your advise. I have found out information from internet web as same as yours before, but i can't found "Comfort Turn Signals (Cycle)" at 09-Cent. Elect.
Please post an Auto-Scan so we can see exactly what modules are installed in this car and how they are configured.
hkaudi
Hong Kong
C?ID=183368
Auto Scan report:
Wednesday,18,February,2015,18:15:33:19670
VCDS Version: 14.10.1.1
Data version: 20150130
Workshop Code: 123 05311 012345
VIN: WAUZZZ4G7CN134341   License Plate:
Mileage: 23210km-14422mi   Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 42 44 46 52 53 55
          5F 62 72 8F 90
VIN: WAUZZZ4G7CN134341   Mileage: 23210km-14422miles
Address 01: Engine (J623-CHVA)       Labels: None
   Part No SW: 4G0 907 552 F    HW: 4G0 907 552 D
   Component: 2.8l V6 FSIH07 0005
   Revision: --H07---
   Coding: 0A250032042701020000
   ASAM Dataset: EV_ECM28FSI0214G0907552F 001005
   ROD: EV_ECM28FSI0214G0907552F.rod
   VCID: 2D51D1777C5DE849F56-8078
Readiness: 1110 1001
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 A    HW: 0B5 927 156 F
   Component: 0B5 28 FSIRdW H10 0002
   Revision: --H10---    Serial number: 0000000247
   Coding: 000001
   ROD: EV_TCMDL501.rod
   VCID: 2B55DF6F4249E679EB2-807E
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   Coding: 02A687014065E180DB00
   ROD: EV_ESPPremiAU57X_AU57.rod
   VCID: 3663FE1B890BAB9184C-8063
   Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
   Coding: 05B82F06000000000000
   VCID: 7AFB2A2BF5938FF1204-802F
   Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
   Component: KLIMA 2 ZONEN H10 0064
   Serial number: 15021200040814
   Coding: 4621600808
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   ROD: EV_AirCondiBasisUDS.rod
   VCID: 2345374F2A992E39532-8076
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 BM    HW: 4H0 907 063 E
   Component: BCM1 2.0      H12 0111
   Revision: 19012002    Serial number: 00000001396796
   Coding: 2600201040349FE08181008080001D0C0F9DC30827090101000004602101
   Shop #: WSC 46559 123 104857
   VCID: 74E70413D7F7F9817A8-8021
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A
   Component: WWS57X 120116  H35 0080
   Coding: 0045F7
   Component: RLS  H04 0003
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Component: Humidity_Sens  H02 0002
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000008
   VCID: 2D51D177745DE849F56-8078
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901204401595
   Coding: 040305
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 3B75EF2FB22976F97B2-806E
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Revision: --------    Serial number: 003JG0070AP.
   Coding: 30323436313330303534554A305234473053
   Serial number: 3575HRB405114TPICHK$
   Serial number: 3585HRB406313AMO5G75
   Serial number: 3515JRB40530O32KM9A1
   Serial number: 3525JRB400C4UHL8NH70
   Serial number: 3554VRB405L14KDMLOQW
   Serial number: 3564VRB405L14KDMAOLH
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: 00000000    Serial number: 20120213000750
   Coding: 000014
   VCID: 306FC803636F85A1DE0-8065
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 900 G    HW: 4G8 920 900 G
   Component: MBenRdw       H34 0209
   Revision: 26450208    Serial number: 658110212592042
   Coding: 33A608000B010008010000
   ASAM Dataset: EV_RBC7KMID 004045
   ROD: EV_RBC7KMID.rod
   VCID: 2E53D67B715B9351CCC-807B
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000399639
   Coding: 00CD073000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3467C4139F77B981BA8-8061
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790768210
   Voltage stabilizer:
   Revision: AA000000    Serial number: 00000023890382
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77FD331FC68192995FA-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA4203T4F80
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA.rod
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16205E01628002080002
   VCID: 428B92CBDDC30731384-8017
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0026334656
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   VCID: 326BC20B6563B7B1A84-8067
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0170762769
   Coding: 011A0E2000B9048580300804020303000000000000000000000000000000
   Shop #: WSC 46559 000 1048576
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Coding: 901F00
   Subsystem 4 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 41899DC7D8C51C2921E-8014
   Revision: --------    Serial number: 00000000256633
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2A5BDA6B4DB3FF71104-807F
Address 55: Headlight Range (J431)       Labels: None
   Serial number: 120214-0002-007
   Coding: 1121A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C57DC734747E141E28-8079
   Part No SW: 4G0 035 182 K    HW: 4G0 035 182 J
   Component: RMC Cnct Plus H52 0775
   Coding: 010100000140DB47402B060303010000010000
   VCID: 2959256740B5F46919E-807C
   Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Subsystem 2 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 011C14204001628002080002
   VCID: 448794D3C7D709010A8-8011
   Component: TSG HR        H04 0212
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3169CD0760658CA9D1E-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 04:57)--------------------------
Keithuk
C?ID=122432
Please post a full AutoScan in between CODE tags [CODE] Full AutoScan [/CODE] as it takes up less room?
I don't see Comfort Blinking documented for that J519, but I'm on the road, and the data I have access to at the moment is not current.
hkaudi
Hong Kong
C?ID=183368
Can you help me to check the updated data? Thanks!
I'm not seeing anything documented even in our current data.
NEtech
C?ID=56995
Have you checked, if there are any settings in MMI ?
hkaudi
Hong Kong
C?ID=183368
Yes, I have checked, but can't found in MMI.:banghead:
hkaudi
Hong Kong
C?ID=183368
Any updated information? Please...
Dana
Western PA, USA
I agree with Uwe here. The B8 Chassis Audi models didn't support modifications to the number of flashes (like a Mk6 Golf based car) and the latest A6/A7/A8 BCM1 and BCM2 controllers are built off of that platform. I don't think it is supported but the MMI was worth a shot.
hkaudi
Hong Kong
C?ID=183368
Hi Dana, I have checked in MMI by general setting, but there are nothing for Turning Signal. Do you thing maybe setting by Hidden Menu?
[/IMG]
[/IMG]
DGMVW
C?ID=110787
I was wondering if this was the final call on this or was anything ever uncovered? I'd like to change this on my 2016 B8.5 A4. Would like to change from 3 to 4 signals.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Based on the resources available and the testing being done by us (and others) no new information has come up.
DGMVW
C?ID=110787
I appreciate the reply Sebastian. I am sure you guys have done your due diligence on researching this, but one final question... I found this on another forum to add:
46 -Central Convenience, 10-Adaptation
Channels 1 to 4: Personalization, keys 1 to 4
add 4096 - Motorway flash active
Does this mean anything? I have not tried it because I never found any other documentation referencing it.
Best regards,
Dave
Dana
Western PA, USA
Hi Dave,
I believe +32768 = Highway/Comfort Turn Signals will turn the comfort flashers on -or- off entirely (based on the key that's in use) but +04096 should be Anti-Theft-System Confirmation (Horn/Siren) in your vehicle based on the modules in this scan.
AIB Wolfgang
Don't beat me:) Just only an idea.
I would try BCM1 in adaption channel 16 , change to 4 or 5?
DGMVW
C?ID=110787
I tried this and it didn't work. If I remember correctly, it wouldn't let me change the value above 3 and changing it to 2 didn't change anything (still blinked 3 times). Any other ideas?
