2011 Audi A4 2.0 TFSI; #3 Cylinder Misfire Issues
JohnyB1978
C?ID=413974
Hello all...this is my first post and need help to get my sons audi back on the road.
I was recently driving his A4 when I noticed loss of power and extreme vibration. The CEL came on and was blinking. I also noticed the EPC light come on. I quickly returned home and used my cheap code reader to find a fault. It showed P0303 (cylinder 3 misfire). Here is what I did:
- Swapped plugs 3 and 1 to see if problem would move...did nothing. Still had #3 cylinder misfire.
- Replaced with new plugs and ignition coils...zero improvement.
- Replaced all 4 fuel injectors...zero improvement.
- Thoroughly cleaned carbon of all valves...even tried a sea-foam treatment...zero improvement.
- Replaced intake manifold with upgraded manifold...zero improvement.
So I finally broke down and bought a VCDS cable. I ran the autoscan and then cleared all codes hoping one of the repairs I made would correct itself after codes were erased. I started car and almost immediately the CEL came on blinking and car still idled with an extreme stutter.
I don't know where to go from here besides taking it to the dreaded dealership. Hopefully someone can help! Thank you!
Monday,10,August,2020,20:37:47:48309
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WAUFFAFL9BN051886   License Plate:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
          77
VIN: WAUFFAFL9BN051886   Mileage: 150130km-93286miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0002
   Revision: E1H19---
   Coding: 0104010A290F0160
   Shop #: WSC 47993 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74B1D8EE0E30E4FB46B-8020
4060 - Cylinder 3
          P0303 00 [101] - Misfire Detected
                    Mileage: 150138 km
                    Date: 2020.08.09
                    Time: 07:34:00
                    Engine speed: 1160.00 /min
                    Normed load value: 24.7 %
                    Coolant temperature: 22 °C
                    Intake air temperature: 26 °C
                    Ambient air pressure: 810 mbar
                    Voltage terminal 30: 12.863 V
                    Unlearning counter according OBD: 80
7960 - Cylinder Disabling
          P130A 00 [036] - -
                    Mileage: 150138 km
                    Date: 2020.08.09
                    Time: 07:34:40
                    Engine speed: 1155.50 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 33 °C
                    Voltage terminal 30: 13.428 V
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [101] - -
                    Mileage: 150138 km
                    Date: 2020.08.09
                    Time: 07:33:55
                    Engine speed: 1195.00 /min
                    Normed load value: 26.3 %
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.415 V
Readiness: 1110 0101
   Part No SW: 8K0 927 158 S    HW: 0BK 927 156 R
   Component: 0BK 20TFSIUSA H08 1003
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 46D55226282C266B28F-8012
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 1D0D18
   Shop #: WSC 02391 823 56573
   VCID: 025D8E364404DA4B447-8056
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H05 0435
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 76B5E2E618CCF6EB78F-8022
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000016320009
   Serial number: 2311000054431003
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01270320110632
   Coding: 64002000
   VCID: 0059843E4A08C85B523-8054
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000001006250
   Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
   VCID: 3C2130CE66606CBB4EB-8068
   Component: WWS 010411  H07 0070
   Serial number: SWF11040010084
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11358333
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001903111169
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0NCDHW
   Coding: 303837354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 45D7552A152A2D73215-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1100002W60
   Serial number: 6334MSME5D550165D
   Serial number: 6344MSME5D550E3EX
   Serial number: 6352QSME150A2B58J
   Serial number: 6362QSME6B044956N
   Serial number: 63732SME4E042E600
   Serial number: 63832SME34014376S
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KCO000WP
   Coding: 000016
   VCID: 3D273DCA7D7A65B3795-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 950 H    HW: 8K0 920 950 H
   Component: KOMBIINSTR.   H20 0258
   Revision: 00200000    Serial number: EIL20NP3C
   Coding: 8B1609000300D705020000
   VCID: 343118EE4E30A4FB86B-8060
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G1132481A0
   Coding: 00C303
   VCID: 015F813A4102C1535DD-8054
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H07 0170
   Serial number: 11013A7E240311
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392F29DA6952599355D-806C
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C03204000410001
   VCID: 53F37B72EBFE83C3BF1-8006
   Revision: 00002001    Serial number: 0146751372
   Coding: 0106023A00FA440480B0013200000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000379413
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS045  H07 0041
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2300000
   Coding: 0203010102
   VCID: 74B1D8EE0EB0E4FB46B-8020
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52FD7E76D4E48ACBB47-8006
   Revision: 00000003    Serial number: 00000000904372
   Part No: 8K5 907 357 B
   Coding: 0000004
   Shop #: WSC 02145 785 00200
   VCID: 392F29DA6552599355D-806C
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000009    Serial number: AUZ5Z6K1567420
   Coding: 04020002010185004359070800
   VCID: 46D5522628AC266B28F-8012
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
                    Reset counter: 222
                    Mileage: 150138 km
                    Date: 2020.08.09
                    Time: 07:29:44
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1501
   Coding: 010C03204000210001
   VCID: 56F58266F80C96EB58F-8002
   Component: TSG HR        H06 1501
   Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
   Component: FSE_256x BT     H42 0650
   Revision: 00000000    Serial number: 00000005114295
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3D273DCA717A65B3795-8068
End----(Elapsed Time: 01:42, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
HMC
C?ID=28246
Hi Johnyb1978,
Your next step is a compression test or better still a cylinder leakage test.
Regards HMC
TBH, I would have gotten that done that before replacing some of the more expensive components.
TFSI
Maryland, USA
C?ID=66650
Johny,
Did you check if cylinder 3 coil is receiving the activation signal from ECM?
Jef
HQ
Revision: E1H19---
4060 - Cylinder 3
P130A 00 [036] - -
P0300 00 [101] - -
Cold engine misfires, this can be a sign of carbon build up on the valves. A bit of a primer on this topic: https://youtu.be/RnhUJsZXzmg
JohnyB1978
C?ID=413974
Johny,
Can you please explain how to do that? Thank you!
JohnyB1978
C?ID=413974
Hi Johnyb1978,
Regards HMC
HMC, thanks for your reply. Just completed a compression test and this is what I found:
#1 Cyl- 130
#2 Cyl- 130
#3 Cyl- 25
#4 Cly- 130
So I suspect an exhaust valve...any other ideas?
JohnyB1978
C?ID=413974
You are correct kind Sir! My dumbass totally skipped the compression test by throwing parts at it hoping for a quick fix.
PetrolDave
Westbury, UK
C?ID=1423
#1 Cyl- 130
#2 Cyl- 130
#3 Cyl- 25
#4 Cly- 130
Low compression can also be caused by an inlet valve not closing fully - possibly because of carbon build-up?
Well, that compression test certainly does explain why cylinder #3 has a misfire!
Time for a bore-scope camera to have a look at the valves?
Alternative: There should be an adapter available that screws in place of the spark plug that allows you to introduce air from a compressor into the cylinder. This should then give you some idea where the air is escaping. Make sure you have a pressure regulator in the air line and start with low pressure. Too high a pressure produce unwanted rotation of the engine internals.
Fred's Imports
Vermont, USA
C?ID=16454
Burnt valve, I see this occasionally always with VAG TSFI oil burners. Once the oil ash gets on the valve face the heat can no longer be transferred to the valve seat, thus your burnt valve face. I teardown and replace pistons and usually a reman head from VAG because the valve guides are not serviceable on these engines any longer.
New piston part numbers have slightly better oil control. If you're serious about fixing I can post part numbers, the newest number requires a new style connecting rod with larger wristpin diameter that gets expensive.
Also there is updated ECM programming for oil consumption. I have had many of these engines apart and will tell you from experience most cold misfires on VAG vehicles are due to injector issues not carbon buildup on the valves. Obviously we replace injectors and valve cleaning at the same time.
Anytime I see cold misfires in the freeze frame I throw a can of Liqui-Moly LM 2007 in the gas tank then follow up with a second can, the stuff is amazing.
JohnyB1978
C?ID=413974
Turned out to be a burnt valve.
You were correct kind Sir! It was a burnt valve. I didn't have the $$$ to replace the piston/connecting rod...but I got it back on the road running great! Thanks to all who responded.!
