Hello all...this is my first post and need help to get my sons audi back on the road.
I was recently driving his A4 when I noticed loss of power and extreme vibration. The CEL came on and was blinking. I also noticed the EPC light come on. I quickly returned home and used my cheap code reader to find a fault. It showed P0303 (cylinder 3 misfire). Here is what I did:
- Swapped plugs 3 and 1 to see if problem would move...did nothing. Still had #3 cylinder misfire.
- Replaced with new plugs and ignition coils...zero improvement.
- Replaced all 4 fuel injectors...zero improvement.
- Thoroughly cleaned carbon of all valves...even tried a sea-foam treatment...zero improvement.
- Replaced intake manifold with upgraded manifold...zero improvement.
So I finally broke down and bought a VCDS cable. I ran the autoscan and then cleared all codes hoping one of the repairs I made would correct itself after codes were erased. I started car and almost immediately the CEL came on blinking and car still idled with an extreme stutter.
I don't know where to go from here besides taking it to the dreaded dealership. Hopefully someone can help! Thank you!
Monday,10,August,2020,20:37:47:48309
VIN: WAUFFAFL9BN051886 License Plate:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
77
VIN: WAUFFAFL9BN051886 Mileage: 150130km-93286miles
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0002
Revision: E1H19---
Coding: 0104010A290F0160
Shop #: WSC 47993 001 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74B1D8EE0E30E4FB46B-8020
4060 - Cylinder 3
P0303 00 [101] - Misfire Detected
Mileage: 150138 km
Date: 2020.08.09
Time: 07:34:00
Engine speed: 1160.00 /min
Normed load value: 24.7 %
Coolant temperature: 22 °C
Intake air temperature: 26 °C
Ambient air pressure: 810 mbar
Voltage terminal 30: 12.863 V
Unlearning counter according OBD: 80
7960 - Cylinder Disabling
P130A 00 [036] - -
Mileage: 150138 km
Date: 2020.08.09
Time: 07:34:40
Engine speed: 1155.50 /min
Normed load value: 25.1 %
Coolant temperature: 33 °C
Voltage terminal 30: 13.428 V
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [101] - -
Mileage: 150138 km
Date: 2020.08.09
Time: 07:33:55
Engine speed: 1195.00 /min
Normed load value: 26.3 %
Intake air temperature: 27 °C
Voltage terminal 30: 12.415 V
Readiness: 1110 0101
Part No SW: 8K0 927 158 S HW: 0BK 927 156 R
Component: 0BK 20TFSIUSA H08 1003
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: 46D55226282C266B28F-8012
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 1D0D18
Shop #: WSC 02391 823 56573
VCID: 025D8E364404DA4B447-8056
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 76B5E2E618CCF6EB78F-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0511000016320009
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000054431003
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Revision: C1000000 Serial number: 01270320110632
Coding: 64002000
VCID: 0059843E4A08C85B523-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001006250
Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
VCID: 3C2130CE66606CBB4EB-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 010411 H07 0070
Serial number: SWF11040010084
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11358333
Coding: 025028
Component: E1 - LDS H03 0031
Serial number: 00000000001903111169
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H44 0610
Serial number: 003GLD0NCDHW
Coding: 303837354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 45D7552A152A2D73215-8010
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100002W60
Serial number: 6334MSME5D550165D
Serial number: 6344MSME5D550E3EX
Serial number: 6352QSME150A2B58J
Serial number: 6362QSME6B044956N
Serial number: 63732SME4E042E600
Serial number: 63832SME34014376S
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KCO000WP
Coding: 000016
VCID: 3D273DCA7D7A65B3795-8068
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 950 H HW: 8K0 920 950 H
Component: KOMBIINSTR. H20 0258
Revision: 00200000 Serial number: EIL20NP3C
Coding: 8B1609000300D705020000
VCID: 343118EE4E30A4FB86B-8060
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1132481A0
Coding: 00C303
VCID: 015F813A4102C1535DD-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 11013A7E240311
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 392F29DA6952599355D-806C
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C03204000410001
VCID: 53F37B72EBFE83C3BF1-8006
Revision: 00002001 Serial number: 0146751372
Coding: 0106023A00FA440480B0013200000000
Component: GTO BF H01 0070
Serial number: 00000000000000379413
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS045 H07 0041
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2300000
Coding: 0203010102
VCID: 74B1D8EE0EB0E4FB46B-8020
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: 52FD7E76D4E48ACBB47-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000904372
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000004
Shop #: WSC 02145 785 00200
VCID: 392F29DA6552599355D-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6K1567420
Coding: 04020002010185004359070800
VCID: 46D5522628AC266B28F-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Reset counter: 222
Mileage: 150138 km
Date: 2020.08.09
Time: 07:29:44
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1501
Coding: 010C03204000210001
VCID: 56F58266F80C96EB58F-8002
Component: TSG HR H06 1501
Part No SW: 8T0 862 336 E HW: 8T0 862 336 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005114295
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3D273DCA717A65B3795-8068
End----(Elapsed Time: 01:42, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
