ACC & Brake Guard unavailable
VTRS7
New Member
SoCal, USA
Hi I keep getting ACC & Brake guard unavailable. I ran vag com and this is all the findings. I did have my windshield replaced with oem window and they said they recalibrated as well. This was done about 4 months ago. Done by safe lite
The backup camera error I’ve had for a while. Never gave a issue
I don’t have warranty on the car. Is it possible safe lite is at fault ?
Monday,03,August,2020,21:14:13:23279
VCDS Version: 20.4.2.0 (x64)
VIN: WUAW2AFC2FN900506   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 65 6C 6D 72 82 85 8B 8E 8F 90 BA
VIN: WUAW2AFC2FN900506   Mileage: 39946km-24821miles
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0008
   Revision: NCH62---
   Coding: 1A2A003265460A0E1000
   Shop #: WSC 40766 001 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906560B 001008
   ROD: EV_ECM40TFS0114G0906560B.rod
   VCID: 2757ED4D5EB7FBBE72-8072
   Part No SW: 4G0 927 158 BE    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIUSA H19 1007
   Revision: --H19---
   Coding: 000001
   VCID: 72E1CC19A5F5CE1615-8026
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 61B75B0386EDDAC04B00
   ASAM Dataset: EV_ESPPremiAU57X 004036
   VCID: 3E792829A12D5A7621-806A
   Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0551
   Coding: 0D8A2046000000000000
   VCID: 7EF9E829E9AD9A7661-802A
   Serial number: 0214000163123011
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0096
   Serial number: 12091400041439
   Coding: 688320B85D
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6AD1D4798D2506D6AD-803E
   Revision: 11012002    Serial number: 00000001802661
   Coding: 0D072091073E9FE2A90008C7A0003820CF9CD308A2090221800308457B00
   VCID: 6FE7C56DBEC7E3FEFA-803A
   Component: WWS57X 140824  H37 0080
   Serial number:         140903195844
   Coding: 0045F7
   Serial number: 23154886
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
   Component: E1 - LDS  H07 0044
   Serial number: 12 09 2014  00001325
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z009AC618
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Serial number: 00000000001408191255
   Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Serial number: 00000000001408191507
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA108940000008919961
   Coding: 020300
   Serial number: 4F684747000000000001
   Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Serial number: 00000000001408132689
   Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
   Serial number: 00000000001408132820
   Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0091
   Revision: 11001001    Serial number: 61061424002234
   Coding: A8E90D
   VCID: 73EFC91DDAEFC71E1E-8026
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 2855EE7153A9F4C67B-807C
145408 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 46
                    Reset counter: 132
                    Mileage: 39839 km
                    Date: 2020.07.31
                    Time: 16:30:10
                    Control Module temperature: 48 °C
                    Voltage terminal 15: 14.096 V
                    Velocity_vehicle_reference: -0.01 m/s
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0001CUBU
   Coding: 303331333130303036314A55304C34473853
   VCID: 346D0A019F618026C7-8060
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y1400017VZV0Y
   Serial number: 3575HRB404V2QJK698NC
   Serial number: 3585HRB405L2NVE868F+
   Serial number: 3515JRB40552SLK87GR%
   Serial number: 3525JRB40632US8G3HBS
   Serial number: 3554VRB401452P4KFP8R
   Serial number: 3564VRB401252P4KF1B5
   Revision: --------    Serial number: 90372NI7000GF
   Coding: 0004FC
   VCID: 38753E318B096446EB-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 18 07 2014  C0054749
   Part No SW: 4G8 920 984 C    HW: 4G8 920 984 C
   Component: TBenUsaAccNv  H58 0622
   Revision: 29460237    Serial number: 658110914596006
   Coding: 03CF010C9F53D705020500
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 36693009891D9236F9-8062
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001541341
   Coding: 00E1034800
   Serial number: 3287094303
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 001009140001023
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
   Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
   Component: KLIMA FOND    H08 0096
   Serial number: 09091400040940
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 3A712439BD0576561D-806E
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E591869714DAAF6B1-807A
   Revision: AA000000    Serial number: 00000115705741
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77F7FD0DC697AB3E22-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E01641R
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 37773D0D8E176B3EE2-8062
   Part No SW: 4G0 907 566 L    HW: 4G0 907 566
   Component: J769  SWA MasterH05 0010
   Revision: 00H05000    Serial number: 6PZ 010 287-10
   Coding: 0000006
   VCID: 38753E314B096446EB-806C
   Subsystem 1 - Part No: 4G0 907 568 L
   Component: J770  SWA Slave H05 0010
   Subsystem 2 - Serial number: 6PZ 010 287-30
   Subsystem 3 - Serial number: 5F13.06.1400H05000AMS16229ÿ
   Subsystem 4 - Serial number: S16229ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F57025E00628002000413
   VCID: 458B47C5CCFB09AE60-8010
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0007957556
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 336F091D9A6F871EDE-8066
   Revision: 00002001    Serial number: 0346874006
   Coding: 0126063A20FAF08580B00A80020314000000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000241187
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO32266500
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00009284703
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA108942000008921364
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93311557
   Revision: CJ007001    Serial number: 00000000142555
   Coding: 030000
   VCID: 1D3BCFA504EB216E18-8048
   Coding: 011F57025E00628002000402
   VCID: 468940C9F1FD02B669-8012
   Revision: --------    Serial number: 00000001199746
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5B1F657C4BD1EE88-8078
   Serial number: 140909-0002-161
   Coding: 12236F601002A400
   ROD: EV_HeadlRegulBasic.rod
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156I-0E8063323
   Coding: 020007010000000001
   VCID: 244DFA41278110A657-8070
   Part No SW: 4G0 035 746 G    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0810
   Revision: --------    Serial number: 194I%0E7615082
   Coding: 0B0200040303FDEF7D12CB1E00000003100001000000000000
   VCID: 2B5F117D4A5FDFDE96-807E
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED005E4EN
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Serial number: 90349NIF000IV
   Component: CD-Database  5950
00862 - Antenna for GPS Navigation (R50/R52)
                    Fault Status: 00101011
                    Reset counter: 132
                    Mileage: 39927 km
                    Date: 2020.08.03
                    Time: 15:12:43
                    Voltage: 14.00 V
01524 - Antenna for Telephone
                    Reset counter: 132
                    Mileage: 38446 km
                    Date: 2020.06.16
                    Time: 15:15:21
                    Voltage: 12.60 V
   Coding: 010F17024000628002000002
   VCID: 49934BF5E0E3EDCE84-801C
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000011088
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A5114794DA5C6D66D-807E
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0175990
   Coding: 0206000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI.rod
9617993 - Proximity Camera
          B145C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 12
                    Mileage: 20211 km
                    Date: 2019.03.05
                    Time: 21:46:36
                    Voltage terminal 30: 11.5 V
   Part No SW: 4G8 959 107 T    HW: 4G8 959 107 J
   Component: HDSG-Modul    H14 0049
   Revision: 12014001    Serial number: 240400574
   Coding: 0A3305C122
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 468940C9F9FD02B669-8012
   Part No SW: 4G8 919 604 K    HW: 4G8 919 604 K
   Component: HeadUpDisplay 006 0203
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   VCID: 3B7F213DB23F4F5E06-806E
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0038
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2649E04959BDE2B649-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X_002.rod
          U1113 00 [008] - -
                    Fault Frequency: 47
                    Reset counter: 132
                    Mileage: 39839 km
                    Date: 2020.07.31
                    Time: 16:30:10
                    Control Module temperature: 49 °C
                    Voltage terminal 15: 14.095 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120309147
   Coding: 03C19A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 316303156073B50EAC-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 32610C1965758E16D5-8066
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H09 0008
   Revision: 00001001    Serial number: 97811004174301
   ASAM Dataset: EV_AEMLearAU64X 002016
   ROD: EV_AEMLearAU64X.rod
End-------------------------(Elapsed Time: 07:16)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
Thats a well-known fault of the A6 C7. And you don't have to paint the new sharkfin to your vehicle's color - the painted cap from the old sharkfin can be transferred to the new.
