I've connected a cable to the port which is in the armrest and connected a usb mp3 player...... On the screen still says ami not supported, i have vcds and can access the hidden green menu, but don't know from there on how to activate it
Do we have an Auto-Scan from this vehicle somewhere?
If not, please post one for context.
PS: Please do not open multiple threads with the same question about the same car in different sections of the forum.
Saturday,01,August,2020,20:40:19:22644
VIN: WAUZZZ8U6ER044674 License Plate: Q3 TDI
Mileage: 80656 Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62 72
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CM HW: 03L 906 018 ES
Component: R4 2.0l TDI H28 9977
Revision: 41H28--- Serial number:
Coding: 00190012043701080000
Shop #: WSC 00780 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018CM 003005
ROD: EV_ECM20TDI01103L906018CM.rod
VCID: 77ABE927EF48C3F3621-8022
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AT HW: 5N0 614 109 AT
Component: J104 C6 450M VDB2 0150
Revision: --H07--- Serial number: 00000007490197
Coding: 0056711
Shop #: WSC 00049 770 00156
VCID: 7DA7FB0FC1F4E9A338D-8028
Part No SW: 8U0 820 043 D HW: 8U0 820 043 D
Component: E87 Klimavoll 0100
Revision: 00H04000 Serial number: 8U0820043D
VCID: 323D1833482AE6DB95F-8066
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 N HW: 8X0 907 063 N
Component: BCM PQ35 M 112 0771
Revision: AG112771
Coding: 0E000A2CA807F1C0201841C021000D4C53FF84AA216F912BE408878400C5
Shop #: WSC 00049 770 00008
VCID: 47CB59E7DFA87373D21-8012
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 131001 H36 0085
Serial number: 131003114119
Coding: 0047F7
Component: G397_RLFS H06 0002
Serial number: 21840414
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
007 - Short to Ground
Fault Status: 01100111
Reset counter: 176
Mileage: 129793 km
Date: 2020.07.29
Time: 18:24:32
Term 15 Off
Voltage: 12.40 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 N HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0050
Revision: 11001001 Serial number: 61061328401175
Coding: 08C205
Shop #: WSC 00049 770 00119
ASAM Dataset: EV_EPHVA18AU21X0000 003006
ROD: EV_EPHVA18AU21X0000_003.rod
VCID: 51FF77BF216CBDC38C5-8004
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
Component: AirbagVW-AU10 H08 0520
Serial number: 003LRR06LFWN
Coding: 30393132313030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 46D554E3D8226A7B297-8012
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME55753F29ZZZ4
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME31172629ZZZJ
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME2F561D29ZZZ%
Serial number: 3526KSME592D2629ZZZ
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME52703226ZZZT
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 D HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010018 Serial number: 20131106301207
Coding: 1084204000
ROD: EV_SMLSNGVOLWS.rod
VCID: 3D273B0F8DF429A378D-8068
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Address 17: Instruments
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 Q HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0063
Revision: 1P120037 Serial number: 3741P13A110B80
Coding: FBCF1A5A000100610353
VCID: 50F972BB2AE6B4CB83B-8004
Component: J367-BDM H07 0180
Serial number: 30289J04341491273416
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13290001793021200181
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 F HW: 0AY 907 554 F
Component: Haldex4Motion H52 7521
Serial number: HA1-00025.09.13
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 4EC56CC33052A23B917-801A
Part No SW: 8U0 920 980 E HW: 8U0 920 980 E
Component: IMMO H01 0330
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
VCID: 3E253C0380F232BB617-806A
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011E06200001000000
VCID: 52FD78B324EAC6DBB5F-8006
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501
Revision: 00H22000
VCID: 40D942FBF686444B13B-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
VCID: 51FF77BF21ECBDC38C5-8004
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000001533812
Coding: 0025166
VCID: 36352423A442FAFBB97-8062
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 131023-0002-107
Coding: 1157A41010002500
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD48F3F40A565B05F-8016
Part No SW: 8U0 035 193 C HW: 8U0 035 193 A
Component: RMC Cnct Nav H54 0801
Coding: 0101060002C153070823020103010000000000
VCID: 3537232FB544F1E3B0D-8060
Subsystem 1 - Part No: 8X0 919 884 F
Component: P23-50-13.06 0001
Subsystem 2 - Part No SW: 8U0 919 603 HW: 8U0 919 603
Component: DUBasic AU316 H41 0018
Serial number: AUZ8ZDD0604MJ7U
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H07 0415
Coding: 010E06200001000000
VCID: 4FFB71C737D8AB339A1-801A
Component: TSG HR H07 0415
End----------(Elapsed Time: 01:19, VBatt start/end: 12.6V/12.1V)-----------
