Ami activation audi q3 2013
vw754
C?ID=52227
I've connected a cable to the port which is in the armrest and connected a usb mp3 player...... On the screen still says ami not supported, i have vcds and can access the hidden green menu, but don't know from there on how to activate it
Do we have an Auto-Scan from this vehicle somewhere?
If not, please post one for context.
PS: Please do not open multiple threads with the same question about the same car in different sections of the forum.
vw754
C?ID=52227
Saturday,01,August,2020,20:40:19:22644
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8U6ER044674   License Plate: Q3 TDI
Mileage: 80656   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62 72
   Part No SW: 03L 906 018 CM    HW: 03L 906 018 ES
   Component: R4 2.0l TDI   H28 9977
   Revision: 41H28---    Serial number:
   Coding: 00190012043701080000
   Shop #: WSC 00780 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018CM 003005
   ROD: EV_ECM20TDI01103L906018CM.rod
   VCID: 77ABE927EF48C3F3621-8022
   Part No SW: 5N0 614 109 AT    HW: 5N0 614 109 AT
   Component: J104   C6 450M VDB2 0150
   Revision: --H07---    Serial number: 00000007490197
   Coding: 0056711
   Shop #: WSC 00049 770 00156
   VCID: 7DA7FB0FC1F4E9A338D-8028
   Part No SW: 8U0 820 043 D    HW: 8U0 820 043 D
   Component: E87  Klimavoll      0100
   Revision: 00H04000    Serial number: 8U0820043D
   VCID: 323D1833482AE6DB95F-8066
   Part No SW: 8X0 907 063 N    HW: 8X0 907 063 N
   Component: BCM PQ35  M   112 0771
   Revision: AG112771
   Coding: 0E000A2CA807F1C0201841C021000D4C53FF84AA216F912BE408878400C5
   Shop #: WSC 00049 770 00008
   VCID: 47CB59E7DFA87373D21-8012
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 131001  H36 0085
   Serial number:         131003114119
   Coding: 0047F7
   Serial number: 21840414
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 176
                    Mileage: 129793 km
                    Date: 2020.07.29
                    Time: 18:24:32
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 N    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0050
   Revision: 11001001    Serial number: 61061328401175
   Coding: 08C205
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_EPHVA18AU21X0000 003006
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 51FF77BF216CBDC38C5-8004
   Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
   Component: AirbagVW-AU10 H08 0520
   Serial number: 003LRR06LFWN
   Coding: 30393132313030303030554A305238553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 46D554E3D8226A7B297-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME55753F29ZZZ4
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME31172629ZZZJ
   Serial number: 3516KSME2F561D29ZZZ%
   Serial number: 3526KSME592D2629ZZZ
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME52703226ZZZT
   Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
   Revision: FF010018    Serial number: 20131106301207
   Coding: 1084204000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D273B0F8DF429A378D-8068
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
Address 17: Instruments
   Part No SW: 8U0 907 468 Q    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0063
   Revision: 1P120037    Serial number: 3741P13A110B80
   Coding: FBCF1A5A000100610353
   VCID: 50F972BB2AE6B4CB83B-8004
   Component: J367-BDM  H07 0180
   Serial number: 30289J04341491273416
   Serial number: 13290001793021200181
   Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
   Component: Haldex4Motion H52 7521
   Serial number: HA1-00025.09.13
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 4EC56CC33052A23B917-801A
   Part No SW: 8U0 920 980 E    HW: 8U0 920 980 E
   Component: IMMO          H01 0330
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   VCID: 3E253C0380F232BB617-806A
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Coding: 011E06200001000000
   VCID: 52FD78B324EAC6DBB5F-8006
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 296    3501
   Revision: 00H22000
   VCID: 40D942FBF686444B13B-8014
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51FF77BF21ECBDC38C5-8004
   Revision:   H19       Serial number: 00000001533812
   Coding: 0025166
   VCID: 36352423A442FAFBB97-8062
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 131023-0002-107
   Coding: 1157A41010002500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DD48F3F40A565B05F-8016
   Part No SW: 8U0 035 193 C    HW: 8U0 035 193 A
   Component: RMC Cnct Nav  H54 0801
   Coding: 0101060002C153070823020103010000000000
   VCID: 3537232FB544F1E3B0D-8060
   Subsystem 1 - Part No: 8X0 919 884 F
   Component: P23-50-13.06  0001
   Subsystem 2 - Part No SW: 8U0 919 603     HW: 8U0 919 603
   Component: DUBasic AU316  H41 0018
   Serial number: AUZ8ZDD0604MJ7U
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H07 0415
   Coding: 010E06200001000000
   VCID: 4FFB71C737D8AB339A1-801A
   Component: TSG HR        H07 0415
End----------(Elapsed Time: 01:19, VBatt start/end: 12.6V/12.1V)-----------
