2013 RS5 Steering
realdeal12
New Member
So I have a 2013 Audi RS5 with dynamic steering and have the infamous red steering fault error. I ran scan and saw that there is a checksum error in the 44 module. I ordered a new rack and module and replaced it and I’m still getting the error. I was wondering if anyone had any ideas of what is going on or how to fix this issue. I have attached the scan. Thanks.
Edit. See the scan in post #4
That scan is not from a 2014 RS5. That scan appears to be an S6. :confused:
Morski
Cheshire UK
C?ID=90186
is the car in bits or have you scanned a random car in the scrap yard? Soo may fault codes
realdeal12
New Member
I'm sorry I attached the wrong file.
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
          52 53 56 5F 6C
VIN: WUAC6AFR5DA900094   Mileage: 129360km-80380miles
1B-Active Steering -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 B    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0002
   Revision: NAH04---
   Coding: 1A25003225C6080D3000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560B 001003
   ROD: EV_ECM42FSI0118T2907560B.rod
   VCID: 3B75F2F1B252475E1E-806E
Readiness: N/A
   Part No SW: 8T0 927 156 D    HW: 0B5 927 156 F
   Component: 0B5 42 FSINAR H10 0003
   Revision: --H10---    Serial number: 0000000993
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 3E73FBE5A140527639-806A
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Coding: 2C2D1A
   Shop #: WSC 06324 000 00000
   VCID: 45819409CC9601AE78-8010
03110 - Active Steering Control Module (J792)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 9
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 01:15:18
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0011
                    Hex Value: 0x1695
                    Hex Value: 0x0000
                    Fault Frequency: 9
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 01:15:18
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0011
                    Hex Value: 0x1695
                    Hex Value: 0x0000
                    Fault Status: 00101101
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:05
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x000F
                    Hex Value: 0x5091
                    Hex Value: 0x0000
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:06
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x000C
                    Hex Value: 0x4691
                    Hex Value: 0x0000
                    Fault Frequency: 9
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 01:15:18
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0011
                    Hex Value: 0x1695
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 FM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H10 0602
   Coding: 0D800000000000000000
   VCID: 000F451D9334E4860B-8054
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0514000038363010
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 2312000071679011
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000028344451
   Coding: 00037025002C00000000
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Component: KLIMA 3 ZONEN H04 0036
   Revision: C1000000    Serial number: 01260420120031
   Coding: 4802200000
   VCID: 3365DAD192028F1EC6-8066
                    Reset counter: 94
                    Mileage: 126042 km
                    Date: 2019.10.02
                    Time: 00:14:24
                    Reset counter: 81
                    Mileage: 128989 km
                    Date: 2020.01.03
                    Time: 03:03:39
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 24
                    Mileage: 128016 km
                    Date: 2019.12.01
                    Time: 22:57:06
                    Temperature: 2.0°C
                    Temperature: 0.0°C
                    Absolute Pres.: 0.8 bar
                    RPM: 2600 /min
                    Current: 0.000 A
                    Temperature: 2.0°C
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:15:30
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 AJ
   Component: BCM1 1.0      H14 0103
   Revision: 09014001    Serial number: 00000029187601
   Coding: 06000091043C9FF235004883000039090F9CD388A2090221000008000000010200020034000000
   Shop #: WSC 07115 444 11072
   VCID: 7AFB37F5F5E8BE5645-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 230412  H15 0070
   Serial number: SWF12040230316
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000404121649
   Subsystem 3 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Serial number: 79580126000000000001
13 Faults Found:
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:15:25
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 03:41:06
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:15:25
                    Fault Status: 00101110
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 01:16:05
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:06
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.10
                    Time: 21:30:08
02233 - Left Headlight Power Output Stage (J667)
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.10
                    Time: 21:30:10
03188 - Bulb for Side Marker Light; Front Left
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.10
                    Time: 21:30:11
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.10
                    Time: 21:30:11
03205 - Control Circuit / Actuator for Left Low-Beam Shutter
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.10
                    Time: 21:30:32
02258 - Door Opener Transmitter
                    Reset counter: 54
                    Mileage: 129364 km
                    Date: 2020.06.11
                    Time: 00:56:02
00926 - Terminal 30
                    Fault Status: 00101011
                    Reset counter: 94
                    Mileage: 129364 km
                    Date: 2020.06.26
                    Time: 07:06:37
00927 - Terminal 30 (Right)
                    Reset counter: 94
                    Mileage: 129364 km
                    Date: 2020.06.26
                    Time: 07:06:41
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H09 0100
   Coding: 00333E
   VCID: 326BDFD56D188616CD-8066
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:26:00
                    Temperature: 34.0°C
                    Voltage: 11.65 V
                    Hex Value: 0x00BE
                    Lateral Accel.: 0.00 m/s^2
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:25:59
                    Temperature: 34.0°C
                    Voltage: 11.65 V
                    Hex Value: 0x00C0
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:24:34
                    Temperature: 33.0°C
                    Voltage: 11.65 V
                    Hex Value: 0x00CE
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD905H99
   Coding: 303343334830303030304A55304C38543053
   VCID: 4A9BA735ED88EED695-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R1200008KQ8
   Serial number: 6334MSME6D222E7FY
   Serial number: 6344MSME6E21654BN
   Serial number: 6352QSME7B123B54L
   Serial number: 6362QSME34110F68G
   Serial number: 63732SME6713404E
   Serial number: 63832SME21132F76.
12660736 - Steering Effort Control Module
          U0130 00 [008] - No Communications
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:05
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120426000940
   Coding: 00003E
   VCID: 51A9B05908DEDD0ED4-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8T0 920 982 Q    HW: 8T0 920 982 Q
   Component: KOMBIINSTR.   H11 0540
   Revision: 00000000    Serial number: NT936VY3D
   Coding: 8B3F0100AF03D705020000
   VCID: 4B95A231EAF2F7DEAE-801E
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 03:41:02
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:06
   Part No SW: 8R0 907 468 D    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H10 0025
   Revision: 1Z070014    Serial number: 1441Z12403016D
   Coding: 00E303FF00
   VCID: 408F851DD3B424864B-8014
   Serial number: 5523987301
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 03:41:02
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:06
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
   Part No SW: 8K0 907 144 H    HW: 8K0 907 144 H
   Component: DYNAMIKLENK.  H06 0680
   Coding: 030000
   VCID: 3467D9CD970C8826DF-8060
                    Fault Status: 11101101
                    Reset counter: 54
                    Mileage: 129364 km
                    Date: 2020.06.12
                    Time: 22:03:06
                    Count: 158
                    Count: 1
                    Hex Value: 0x0235
                    Hex Value: 0x7212
                    Hex Value: 0x005A
                    Hex Value: 0xD002
                    Reset counter: 94
                    Mileage: 129364 km
                    Date: 2020.06.27
                    Time: 03:38:37
                    Count: 147
                    Count: 1
                    Hex Value: 0x0235
                    Hex Value: 0x7102
                    Hex Value: 0x0000
                    Hex Value: 0xF000
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 002604120001020
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
   VCID: 2F6DD6A1762AABFEA2-807A
0226 - Steering Effort Control Module
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:05
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [008] - -
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:05
0121 - Please Check Fault Codes in Steering Assist Control Module
          U1020 00 [008] - -
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:25:59
0122 - Please Check Fault Codes in Steering Assist Control Module
          U1020 00 [008] - -
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:25:59
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000028309692
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H16 0040
   Serial number: 0173693297
   Coding: 010211
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H16 0040
   Serial number: 0173176119
   Coding: 010211
262148 - Databus
                    Reset counter: 54
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:15:28
   Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
   Component: TSG FA        H09 0302
   Coding: 011C13224E00120102
   VCID: 4D91AC2914E6F9EEB0-8018
   Revision: 00001000    Serial number: 0019816460
   Coding: 010001010000
   Shop #: WSC 02145 785 00200
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3467D9CD9F0C8826DF-8060
0770 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
                    Mileage: 95789 km
                    Date: 2019.12.13
                    Time: 07:29:14
                    Write only channel
                    Reset counter: 55
                    Mileage: 69684 km
                    Date: 2020.05.20
                    Time: 19:15:11
                    Write only channel
   Revision: 00002001    Serial number: 0175635655
   Coding: 0106029A00FAC00580B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000513441
   Component: J245EE20SKB13  H03 0220
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA102904000001175636
03394 - Play protection for rear spoiler adjustment active
                    Reset counter: 79
                    Mileage: 126412 km
                    Date: 2019.11.09
                    Time: 03:23:44
   Component: DSP Prem      H04 0030
   Revision: 00004001    Serial number: 94814002885701
   VCID: 2D51CCA97426D9EE90-8078
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   VCID: 4C97A12DEFFCF0E6A7-8018
                    Fault Status: 00101100
                    Reset counter: 50
                    Mileage: 126156 km
                    Date: 2019.11.02
                    Time: 04:55:56
   Part No SW: 8K0 907 801 K    HW: 8K0 907 801 J
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 00000000036238
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 377DEEC18E7A633EFA-8062
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:06
                    Voltage terminal 30: 11.8 V
                    Internal Fault ID: 188
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Auto Adjust: not active
   Part No SW: 4G0 035 082 C    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 236DZ0C7536191
   Coding: 020007010000000001
   VCID: 204F259D33F404862B-8074
   Part No SW: 8R1 035 746 A    HW: 8R1 035 746 A
   Component: H-BNT-NA      H42 0422
   Revision: --------    Serial number: 096E.0C7508009
   Coding: 150200020306A9EF75028B4E00000403140000000000000000
   VCID: 3561E4C99C76912EE8-8060
   Component: NAR 2011  0505
   Component: DU7 High  H41 0104
   Serial number: A130D30CS152815
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001141695
   Component: CD-Database  3371
   Revision: --H07---    Serial number: 525PA8-J249083
   Coding: 1021008
   VCID: 387FEDFD4B646C46F3-806C
                    Reset counter: 94
                    Mileage: 129365 km
                    Date: 2020.06.08
                    Time: 04:18:05
                        Reverse OFF
                    Count: 3
Is that scan with the original rack in the car, or the new one?
realdeal12
New Member
I have posted the current scan in my second post. I have attempted to follow those steps twice in the link that was posted and didn’t have any luck.
Dana
Western PA, USA
OK, we were under the impression that the scan in post #4 contained info from the original steering rack. If this fault is stored in the replacement rack:
.. I suspect the (used?) rack is also faulty. Please verify that the scan prior to repairs (in the original condition) had the exact part number and fault codes though.
If this is a crash repair you might also want to make sure there aren't any wiring or power supply issues which may explain any number of the faults in the car.
In the meanwhile I'll remove the 2008 (4F) chassis S6 scan from post #1.
