2006 VW GOLF STEERING ANGLE CALIBRATION FAULT, SETTING
Tony@beltonmotors
C?ID=362723
Hi again everyone, ok so i have mk5 golf on a 2006 plate, the customer changed his own battery and now has a steering angle/calibration fault.
I have attempteed to follow instruction on how to re calibrate the sensor yet it doent seem to want to do it.
i went into chanel 44
read the codes(listed below)
i then went into coding and entered 40168, which was accepted to login
i then went into basic settings to chanel 060 for the angle sensor
from what i have reserched, i turned the steering all the way to the left, held for 5 seconds
all the way to the right and held for 5 seconds
drove the vehicle turning the steering 10degrees
then left to right again
ive done this over 10 times now and the ight will not go out
i have read the live data and the angle sensor justs reads zero
So, am i performing the calibration wrong or is it a duff angle sensor
Also there is no assistance to the steering
many thanks again
tony
belton motors
doncaster
uk
Tuesday,14,July,2020,13:16:46:10625
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ5B059601   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ5B059601   Mileage: 169520km-105334miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 H    HW: Hardware No
   Component: MED 9.5.10       00 5634
   Revision: 00000000    Serial number: VWZ7Z0D0623148
   Coding: 0000071
   Shop #: WSC 00046 412 00000
   VCID: 281CF0589BDA9AC663-807C
Readiness: 1010 0001
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0019073
   VCID: 3A383A107576185605-806E
   Part No: 1K0 820 047 CR
   Component: Climatic PQ35   081 0404
   VCID: 76A0EE2001EEBC3621-8022
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000001003463
   Coding: 008D0F0600041800001400001400000000
   Shop #: WSC 00046 412 811008
   VCID: 3FCE4B046E543D7E32-806A
   Component: Wischer 260707 021  0501
   Coding: 00038805
   Shop #: WSC 00046
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 02 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0LHATK
   Coding: 0012338
   VCID: 312A1D3CA800DB0EB4-8064
   Subsystem 1 - Serial number: 6332MSME62421A07
   Subsystem 2 - Serial number: 6342MSME4A1B1907
   Subsystem 3 - Serial number: 6351HSME455A0D04
   Subsystem 4 - Serial number: 6361HSME7E423C04
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Shop #: WSC 00046 412 1695744
   VCID: 6FAEDB447EB48DFEE2-803A
   Part No: 1K0 920 951 E
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0003403
   Shop #: WSC 12345 067 57207
   VCID: 2B160F548A2CB1DE8E-807E
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 270010491607E4
   Coding: 3D0F0340070001
   Shop #: WSC 00046 412 778240
   VCID: 291AF55C80D0A3CE7C-807C
   Component: IMMO            VDD 0716
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0156
   Coding: 0000052
   Shop #: WSC 00046 000 32768
   VCID: 302C1838A30AD206BB-8064
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.0       1301
02546 - Steering Limit Stop
                    Mileage: 9520 km
                    Temperature: 32.0°C
                    Voltage: 14.20 V
                    Voltage: 13.90 V
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BK
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404085A018010
   Shop #: WSC 00999 444 64523
   VCID: 7AB8FA1035F6D85645-802E
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   Part No: 1K0 035 186 L
   Component: Radio GR0       012 0018
   Revision: 0001201S    Serial number: VWZ2Z2D1183229
   Coding: 0020200
   VCID: 2F2E1B44BE34CDFEA2-807A
End----------(Elapsed Time: 00:48, VBatt start/end: 14.1V/14.1V)-----------
motor-magic
England
C?ID=179880
Hi Tony
We have a similar issue on a mk5 Golf Plus.
Ours was jump started and now showing error codes for (G85) steering angle sensor and 02546 steering stop limits no basic setting.
We have replaced numerous parts and still not able to carry out the basic settings.
But for your information
Basic settings for steering angle sensor (G85) in ESP front Mk60 are carried out in (03) Brake electronics. Only MK70 are carried in in (44) steering assist.
Try the basic settings but this time logging into (03) brake electronics and see if it will adapt.
Good luck
Warren
Tony@beltonmotors
C?ID=362723
hi ewe thank you for the link, i followed the instruction and it still wont calibrate, when i select 060 it simply says error....and te degrees dont change when reading measuring block. However it does also have an abs fault, with a wheel speed sensor. would calibration be stopped due to this fault needing to be rectified 1st. or is it looking more likely to be a duff sensor...apparently this all happened when he changed the battery, but ya know how unreliable customers can be
thanks
heikeedwin
Maputo, Mozambique
C?ID=389069
Did you manage to identify the issue?
thanks
