Hi again everyone, ok so i have mk5 golf on a 2006 plate, the customer changed his own battery and now has a steering angle/calibration fault.
I have attempteed to follow instruction on how to re calibrate the sensor yet it doent seem to want to do it.
i went into chanel 44
read the codes(listed below)
i then went into coding and entered 40168, which was accepted to login
i then went into basic settings to chanel 060 for the angle sensor
from what i have reserched, i turned the steering all the way to the left, held for 5 seconds
all the way to the right and held for 5 seconds
drove the vehicle turning the steering 10degrees
then left to right again
ive done this over 10 times now and the ight will not go out
i have read the live data and the angle sensor justs reads zero
So, am i performing the calibration wrong or is it a duff angle sensor
Also there is no assistance to the steering
many thanks again
tony
belton motors
doncaster
uk
many thanks again
tony
belton motors
doncaster
uk
Tuesday,14,July,2020,13:16:46:10625
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ5B059601 License Plate:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ5B059601 Mileage: 169520km-105334miles
Address 01: Engine Labels: 03C-906-056-BAG.lbl
Part No SW: 03C 906 056 H HW: Hardware No
Component: MED 9.5.10 00 5634
Revision: 00000000 Serial number: VWZ7Z0D0623148
Coding: 0000071
Shop #: WSC 00046 412 00000
VCID: 281CF0589BDA9AC663-807C
Readiness: 1010 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0019073
VCID: 3A383A107576185605-806E
Part No: 1K0 820 047 CR
Component: Climatic PQ35 081 0404
VCID: 76A0EE2001EEBC3621-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000001003463
Coding: 008D0F0600041800001400001400000000
Shop #: WSC 00046 412 811008
VCID: 3FCE4B046E543D7E32-806A
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 260707 021 0501
Coding: 00038805
Shop #: WSC 00046
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 02 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0LHATK
Coding: 0012338
VCID: 312A1D3CA800DB0EB4-8064
Subsystem 1 - Serial number: 6332MSME62421A07
Subsystem 2 - Serial number: 6342MSME4A1B1907
Subsystem 3 - Serial number: 6351HSME455A0D04
Subsystem 4 - Serial number: 6361HSME7E423C04
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
Shop #: WSC 00046 412 1695744
VCID: 6FAEDB447EB48DFEE2-803A
Part No: 1K0 920 951 E
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0003403
Shop #: WSC 12345 067 57207
VCID: 2B160F548A2CB1DE8E-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 270010491607E4
Coding: 3D0F0340070001
Shop #: WSC 00046 412 778240
VCID: 291AF55C80D0A3CE7C-807C
Component: IMMO VDD 0716
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0156
Coding: 0000052
Shop #: WSC 00046 000 32768
VCID: 302C1838A30AD206BB-8064
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.0 1301
02546 - Steering Limit Stop
Mileage: 9520 km
Temperature: 32.0°C
Voltage: 14.20 V
Voltage: 13.90 V
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BK
Component: 01 KSG 0301
Coding: 80C802087F2D8404085A018010
Shop #: WSC 00999 444 64523
VCID: 7AB8FA1035F6D85645-802E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
Part No: 1K0 035 186 L
Component: Radio GR0 012 0018
Revision: 0001201S Serial number: VWZ2Z2D1183229
Coding: 0020200
VCID: 2F2E1B44BE34CDFEA2-807A
End----------(Elapsed Time: 00:48, VBatt start/end: 14.1V/14.1V)-----------
