Audi a4 b7 8e cruise control retrofit Problems
San_holo
Norway
C?ID=400273
Hey, i have tried to code in cruisecontrol on my car after mounting the parts. cluch switch is ok. have activated cruise in the engine module, (showin a G) and in steering wheel module. But when i go to measuring blocs on steering wheel, (group 4, ist says on the right, "not installed". Anyone got a clue why my cruise isnt working?
A full scan:
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.4.1(x64) Data version: 20200331 DS317.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,13,July,2020,17:39:07:58297
VIN: WAUZZZ8E46A137248 License Plate: SU24512
Mileage: 137710km-85569mi Repair Order:
 67 69 75 76 77
VIN: WAUZZZ8E46A137248 Mileage: 137710km-85569miles
Address 01: Engine Labels: 06B-906-018-AVJ.lbl
 Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B
 Component: 1.8L R4/5VT G 0010
 Coding: 0011711
 Shop #: WSC 33278 133 00032
 VCID: 7F5B052F6BE347632A1-5184
Address 03: ABS Brakes Labels: 8E0-910-517.clb
 Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
 Component: ESP8 quattro H05 0120
 Coding: 0004871
 Shop #: WSC 06325 000 00000
 VCID: 290FFB77C5F719D3245-807C
 Part No: 8E0 820 043 BK
 Component: A4 Klimaautomat 2832
 Coding: 00000
 VCID: 6B83C17F0A9BCBC3969-5184
Self-Diagnosis Log
Page 2
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
 Part No: 8E0 907 279 L
 Component: int. Lastmodul ECE 0504
 Coding: 11041
 Shop #: WSC 65536
 VCID: 3B23313F3A7B9B43469-4B00
Address 15: Airbags Labels: 8E0-959-655-94.lbl
 Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
 Component: Airbag 9.41 H11 3530
 Revision: 91H1135 Serial number: 0036M008C5Y4
 Coding: 0033622
 VCID: 3B23313F3F6B9B43469-806E
 Subsystem 1 - Serial number: 6332DRB4025093A5H
 Subsystem 2 - Serial number: 6342DRB401FE5110L
 Subsystem 3 - Serial number: 6352ARB400B7560DO
 Subsystem 4 - Serial number: 6362ARB400B77A8D$
 Subsystem 5 - Serial number: 63729RB400C44274G
 Subsystem 6 - Serial number: 63829RB400C44275I
Address 16: Steering wheel Labels: 8E0-953-549.lbl
 Part No: 8E0 953 549 Q
 Component: Lenksáulenmodul 0701
 Coding: 02042
 Shop #: WSC 06325
 VCID: 41DF43D75897F1931C5-4B00
 35-00 - -
 49-00 - No Communications
01304 - Radio
Self-Diagnosis Log
Page 3
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
 Part No SW: 8E0 920 901 C HW: 8E0 920 901 C
 Component: KOMBI+WFS 3 H12 0110
 Revision: 0110 Serial number: AUX6Z0E0127046
 Coding: 0007141
 Shop #: WSC 00768 152 144297
 VCID: 2517F747A9FF3DB300D-5184
01304 - Radio
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
 Coding: 0007141
01304 - Radio
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
 Part No: 8E0 959 433 BR
 Component: Komfortgerát T23 3332
 Coding: 07024
 Shop #: WSC 06325
 VCID: 025D8CDB1D112A8B45F-4B00
 Subsystem 1 - Part No: 8E1959801H
 Component: Tõrsteuer.FS BRM 0506
 Subsystem 2 - Part No: 8E1959802B
 Component: Tõrsteuer.BF BRM 0205
 Component: Tõrsteuer.HL BRM 0606
 Component: Tõrsteuer.HR BRM 0606
Self-Diagnosis Log
Page 4
 Part No: 8P0 907 357 F
 Coding: 0000005
 VCID: 3D273F27217F957378D-8068
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
 Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
 Component: Parkhilfe 4-Kan H06 0010
 Revision: 00H06000 Serial number: 00067802020529
 Coding: 0000014
 VCID: 313F1317ED076113EC5-5184
End----------(Elapsed Time: 05:18, VBatt start/end: 12.4V/12.3V)-----------
Admin Note: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, not a forum. Instead, please use the native text that VCDS gives you, either using the [Copy] or [Save] function. If you've explicitly saved data, it will be in the Logs sub-folder. VCDS also automatically saves all Auto-Scans to the Scans sub-folder. Any of these saved files can be opened with Notepad and the contents copied here.
Now on to your cruise control problem: Have you been here?
http://wiki.ross-tech.com/wiki/index.php/Cruise_Control_Retrofitting_(8E)
Have you run the new wire required?
San_holo
Norway
C?ID=400273
This wire? " T16a/5 " I have not found where or what this wire is anywhere, could you please enlighten me? I get button outputs from both engine module aswell as the steering wheel module, and yes thats what i was following :D
Edit: found other sites sayin that the b7 did not need an extra wire, might be something from the b6. Also still have not solved this:/
PetrolDave
Westbury, UK
C?ID=1423
I've done a couple of cruise retrofits on B7 cars - here's the problems I found along the way:
1) is the SCSM cruise compatible, not all are?
2) coding didn't take when the cruise control switch was not in the off position, I had to revert the SCSM coding (and engine login) then put the cruise switch to off and redo the coding and login.
iichel
Netherlands, eastern part
C?ID=284912
I would suggest to run a wire from T16/5 to the engine T121/38 as per ESLA wiring diagram. Or check to see if it's arready in place.
San_holo
Norway
C?ID=400273
could you please link me this diagram? google wouldnt help me :/
San_holo
Norway
C?ID=400273
can try with the switch off, might be that, also i am getting a multifuncion steering wheel in the mail, the dude was kind enough to ship his stalks and backplate aswell so if that doesnt work ill try that, but thanks for the tip :D
San_holo
Norway
C?ID=400273
also i have no cruise control light that lights up in the dash, is this something i can test for?
PetrolDave
Westbury, UK
C?ID=1423
On the B7 that won't light up until the cruise control is correctly programmed and in use.
San_holo
Norway
C?ID=400273
I assume from viewing the schematics that this is the connector, pin 5 is occupied as its supposed to :/
San_holo
Norway
C?ID=400273
mounted and coded in a new baclplate and a multifunction steerinwheel. the wheel works as it should after coding. have checked that brake and clutch switches are okay. coded in the cruise as instructed with the lever in the off position, and yet it still didnt work. tried to code it off and back on again multiple times. with the switch both off and on. (last time with it off) and yet doesnt work. in the image above there is mentioned a hardware cruise on. this doesnt work for me. is it supposed to? ( can works but none of the other buttons do anything in here but all indicate in the blocks 004 in steeringwheel module) any answers would be greatly appreachiated.
San_holo
Norway
C?ID=400273
