Lost abs code on audi a3 8v
Shuhel
Birmingham, UK
C?ID=368132
hi guys, my customer had attempted to change the cluster himself and lost abs code in the process, can anyone suggest coding please
thanks
Wednesday,08,July,2020,12:15:31:58999
VIN: WAUZZZ8V1EA133558   License Plate:
Mileage: 139252km-86527mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WAUZZZ8V1EA133558   Mileage: 139252km-86527miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 ER    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 8361
   Revision: 81H22---
   Coding: 021D0012032701082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TDI01104L906021ER 002010
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 79AFEC7F795735B3145-802C
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 139248 km
                    Time: 00:00:00
                    Coolant temperature: 90 °C
                    Intake air temperature: 74 °C
                    Voltage terminal 30: 12.820 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 1
                    Acceleration: 0.000 m/s²
          U0428 00 [039] - -
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:41:02
                    Coolant temperature: 89 °C
                    Intake air temperature: 71 °C
                    Voltage terminal 30: 12.440 V
                    Cruise Control System (CCS): status-Bits 0-7: 7
4716 - No Communications with Parking Brake Control Module
          U0128 00 [039] - -
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:41:01
                    Limitation: accelerator pedal: 126.6 Nm
                    selected gear-Bits 0-7: 0
   Part No SW: 0D9 300 012 H    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4518
   Revision: 05852204    Serial number: TFK01401091208
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1B63D6F7932BA7A3A69-804E
          P1734 00 [002] - -
21221 - No Communications with Parking Brake Control Module
          U0128 00 [011] - -
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:41:02
   Revision: 00000000    Serial number: 60124000000936
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 7BA3F677736B07A3069-802E
11 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
0295 - Steering angle sensor
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
8278 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
8290 - Coding Not Possible
          U10BC 00 [137] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 244
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:39:53
8292 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 244
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:39:53
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 244
                    Date: 2020.07.08
                    Time: 11:39:48
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000043628
   Coding: 03100104002000001000000000000100
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 372B2A470FC3E3C3A21-8062
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011402200573
   Coding: 07141A42C241205D43844004001C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140112  041 0580
   Serial number:         140114041442
   Coding: 0A47F7
   Light switch:
   Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
   Serial number: 25 08 2013  00000873
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO26506485
   Coding: 901E00
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [009] - Electrical Failure
                    Reset counter: 243
                    Mileage: 139203 km
                    Date: 2020.07.07
                    Time: 19:30:36
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831402201553
   Coding: 0000050011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   VCID: 3829297B02DDECBBABB-806C
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 244
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:40:37
13637426 - Databus
                    Reset counter: 244
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:40:37
   Serial number: 003M2R04UA5H
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 4BC366B7634B7723F69-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 101 14
   Serial number: 35767000000F0520BE0W
   Subsystem 2 - Part No SW: -----------    HW: 480 002 101 14
   Serial number: 35867000000B0620BE0U
   Subsystem 3 - Part No SW: -----------    HW: 480 401 701 14
   Serial number: 3516502C313013E071BZ
   Subsystem 4 - Part No SW: -----------    HW: 480 401 701 14
   Serial number: 3526502C512FAE22B1BN
   Subsystem 5 - Part No SW: -----------    HW: 480 403 011 13
   Serial number: 3556502991220565328Z
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 2286502AD12FAE32C0BW
   Subsystem 7 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 2296502AD12FAE34303I
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 2306502A711FBE91926I
9682162 - Multiple collision brake
          B13BC F2 [137] - No function
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:58:28
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 19011404220692
   Coding: A418
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 094F9CBF29B72533045-805C
   Part No SW: 8V0 920 870 H    HW: 8V0 920 870 H
   Component: KOMBI         H03 2220
   Coding: 27A508082A8086080100AA00100000
   VCID: 40D9419B5A0DA47B13B-8014
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 243
                    Mileage: 139174 km
                    Date: 2020.07.07
                    Time: 00:21:47
   Revision: --------    Serial number: 0001481427
   Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
   ROD: EV_GatewLear_010.rod
   VCID: 3FDB426727F3DB836A1-806A
   Serial number: 13 01 2014  D0382236
   Serial number: 5487282303
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00007.12.13
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 46D5578378298A4B297-8012
   Serial number: 08011406070807
   Coding: 001C8E204001040000001002
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF449F5107AD731C5-8014
15873 - Steering angle sensor
                    Reset counter: 244
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:40:22
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 63.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 12.23 V
                    uAdSensI_SwitchedKl30_xdu16: 12.24 V
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 244
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:40:22
                    Motor status: 00
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 12.41 V
                    uAdSensI_SwitchedKl30_xdu16: 12.41 V
   Serial number: 30121303111078
   Coding: 001C86204C01040000001002
   Shop #: WSC 12345 123 61029
   Coding: 01AC000001000000
   VCID: 75B7E04F554F51D370D-8020
13705992 - Databus
          U1123 00 [137] - Received Error Message
          [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 244
                    Mileage: 139248 km
                    Date: 2020.07.08
                    Time: 11:40:34
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 18011406070942
   Coding: 000C86204001040000001002
   VCID: 42DD4B935401B66B05F-8016
   Component: TSG HBFS      020 0025
   Serial number: 18011401101068
End----------(Elapsed Time: 01:27, VBatt start/end: 12.5V/12.4V)-----------
DrPeter
16.4905° S, 151.7375° W
This maybe a long shot, but did your customer perform an Auto-Scan of the vehicle prior to any work being done?? (amusing they have a Ross-Tech product)(the internet has seen this VIN before, someone may have scanned this vehicle before?) If so they would have preserved the original coding of the controller in that Auto-Scan.
VCDS will store the Auto-Scans in the Logs folder and the Scans folder in ../Ross-Tech/VCDS.
If there is no Auto-Scan, the vehicle may have to go on line with Audi using ODIS to re-code the controller.
Hope this helps,
drpeter
Shuhel
Birmingham, UK
C?ID=368132
No previous auto scans.
No other suggestions anyone?
Looks like it's a trip to dealer to SVM and document the alleged clocked odometer huh? :rolleyes:
You could try to build a coding using the spreadsheet in the first post of this thread:
https://forums.ross-tech.com/showthread.php?17417
However, the path of least resistance is probably to take it to the dealer (or an independent with ODIS and FAZIT access) and have them retrieve the coding from the servers on the mothership in Germany.
