- Jun 13, 2019
- 42
- 20
- Birmingham, UK
- C?ID=368132
hi guys, my customer had attempted to change the cluster himself and lost abs code in the process, can anyone suggest coding please
thanks
thanks
Wednesday,08,July,2020,12:15:31:58999
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8V1EA133558 License Plate:
Mileage: 139252km-86527mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WAUZZZ8V1EA133558 Mileage: 139252km-86527miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 ER HW: 04L 907 309 A
Component: R4 2,0L EDC H22 8361
Revision: 81H22---
Coding: 021D0012032701082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021ER 002010
ROD: EV_ECM20TDI01104L906021ER.rod
VCID: 79AFEC7F795735B3145-802C
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 139248 km
Engine speed: 0.00 /min
Coolant temperature: 90 °C
Intake air temperature: 74 °C
Voltage terminal 30: 12.820 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 1
Acceleration: 0.000 m/s²
U0428 00 [039] - -
Mileage: 139248 km
Date: 2020.07.08
Time: 11:41:02
Coolant temperature: 89 °C
Intake air temperature: 71 °C
Voltage terminal 30: 12.440 V
Cruise Control System (CCS): status-Bits 0-7: 7
4716 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 139248 km
Date: 2020.07.08
Time: 11:41:01
Limitation: accelerator pedal: 126.6 Nm
selected gear-Bits 0-7: 0
Part No SW: 0D9 300 012 H HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4518
Revision: 05852204 Serial number: TFK01401091208
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1B63D6F7932BA7A3A69-804E
P1734 00 [002] - -
21221 - No Communications with Parking Brake Control Module
U0128 00 [011] - -
Mileage: 139248 km
Date: 2020.07.08
Time: 11:41:02
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 60124000000936
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 7BA3F677736B07A3069-802E
11 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
[FCAN: Mismatch between bytecoding and Lenkerposition signal]
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
8290 - Coding Not Possible
U10BC 00 [137] - -
[FCAN: Unplausible VIN number]
Reset counter: 244
Mileage: 139248 km
Date: 2020.07.08
Time: 11:39:53
8292 - Control Module Incorrectly Coded
U1014 00 [137] - -
[FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 244
Mileage: 139248 km
Date: 2020.07.08
Time: 11:39:53
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
[FCAN: Coding of ESP and TSK does not fit together]
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 244
Date: 2020.07.08
Time: 11:39:48
Address 08: Auto HVAC (E87) Labels:| 8V0-820-047.clb
Part No SW: 8V0 820 047 D HW: 8V0 820 047 D
Component: AC Manuell el H11 0052
Revision: 20021000 Serial number: 00000000043628
Coding: 03100104002000001000000000000100
ASAM Dataset: EV_AirCondiFrontManAU37X 008018
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 372B2A470FC3E3C3A21-8062
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011402200573
Coding: 07141A42C241205D43844004001C07A80000000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140112 041 0580
Serial number: 140114041442
Coding: 0A47F7
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Serial number: 25 08 2013 00000873
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO26506485
Coding: 901E00
B1263 01 [009] - Electrical Failure
Reset counter: 243
Mileage: 139203 km
Date: 2020.07.07
Time: 19:30:36
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831402201553
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 3829297B02DDECBBABB-806C
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 244
Mileage: 139248 km
Date: 2020.07.08
Time: 11:40:37
13637426 - Databus
Reset counter: 244
Mileage: 139248 km
Date: 2020.07.08
Time: 11:40:37
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R04UA5H
Coding: 98CCC0000C0000005C5400CA00C800000065
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4BC366B7634B7723F69-801E
Subsystem 1 - Part No SW: ----------- HW: 480 002 101 14
Serial number: 35767000000F0520BE0W
Subsystem 2 - Part No SW: ----------- HW: 480 002 101 14
Serial number: 35867000000B0620BE0U
Subsystem 3 - Part No SW: ----------- HW: 480 401 701 14
Serial number: 3516502C313013E071BZ
Subsystem 4 - Part No SW: ----------- HW: 480 401 701 14
Serial number: 3526502C512FAE22B1BN
Subsystem 5 - Part No SW: ----------- HW: 480 403 011 13
Serial number: 3556502991220565328Z
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 201 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502AD12FAE32C0BW
Subsystem 7 - Part No SW: ----------- HW: 480 400 201 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502AD12FAE34303I
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 201 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A711FBE91926I
B13BC F2 [137] - No function
Mileage: 139248 km
Date: 2020.07.08
Time: 11:58:28
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 19011404220692
Coding: A418
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 094F9CBF29B72533045-805C
Part No SW: 8V0 920 870 H HW: 8V0 920 870 H
Component: KOMBI H03 2220
Coding: 27A508082A8086080100AA00100000
VCID: 40D9419B5A0DA47B13B-8014
16776967 - Databus
[EPB_02 keine Kommunikation]
Reset counter: 243
Mileage: 139174 km
Date: 2020.07.07
Time: 00:21:47
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001481427
Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB426727F3DB836A1-806A
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 13 01 2014 D0382236
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 5487282303
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00007.12.13
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 46D5578378298A4B297-8012
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 08011406070807
Coding: 001C8E204001040000001002
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF449F5107AD731C5-8014
15873 - Steering angle sensor
Reset counter: 244
Mileage: 139248 km
Date: 2020.07.08
Time: 11:40:22
Motor status: 00
Supply voltage: 12.25 V
Temperature: 63.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uioUdNotFilt_xdu16: 12.23 V
uAdSensI_SwitchedKl30_xdu16: 12.24 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
[ESP_02 Botschaft - SNA_Check]
Reset counter: 244
Mileage: 139248 km
Date: 2020.07.08
Time: 11:40:22
Motor status: 00
KFC: 4B
KFA: 00 04
Environmental conditions: 7F
uioUdNotFilt_xdu16: 12.41 V
uAdSensI_SwitchedKl30_xdu16: 12.41 V
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 30121303111078
Coding: 001C86204C01040000001002
Shop #: WSC 12345 123 61029
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 01AC000001000000
VCID: 75B7E04F554F51D370D-8020
13705992 - Databus
[LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
Reset counter: 244
Mileage: 139248 km
Date: 2020.07.08
Time: 11:40:34
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 18011406070942
Coding: 000C86204001040000001002
VCID: 42DD4B935401B66B05F-8016
Component: TSG HBFS 020 0025
Serial number: 18011401101068
End----------(Elapsed Time: 01:27, VBatt start/end: 12.5V/12.4V)-----------
