Audi S3 no longer talking to anything
LHSLTD
C?ID=271214
Hi got a call out to this and it has me flummoxed ATM.
Audi A3 with everything transferred out of an S3 fitted in it.
Was working fine prior to the lockdown when the chap was put on furlough and he went to go back to work on Monday and the battery was dead.
Went and got a new battery, and now when he turns the key, everything is going crazy. Dash lights up like a Christmas Tree, with all sorts of warning coming up. Ignition comes on but won't crank, Just says depress clutch pedal in the screen, but won't turn over, reason being obvious when you see the attached.
I went out and scanned it, but it won't talk to anything.
In the meantime I've told him to check the wiring to the ECU for power, etc., and get the battery tested/charged to check it, but I thought I would post the scan here and see if anyone can shed light on it.
Thank
Lennie
Wednesday,01,July,2020,18:42:58:18208
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8P37A211939   License Plate: SO05 VRC
Mileage: 148850km-92491mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 75 77
VIN: WAUZZZ8P37A211939   Mileage: 148850km-92491miles
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
22-AWD -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
75-Telematics -- Status: Cannot be reached 1100
Address 01: Engine
Address 03: ABS Brakes
   Part No SW: 8P0 820 043 AD    HW: 8P0 820 043 AD
   Component: KlimavollautomatH19 0360
   Revision: 074519      Serial number: 8P0820043AD
   VCID: 6ED3A0D379D025F6E9-803A
8 Faults Found:
                    Fault Status: 00101001
                    Reset counter: 30
                    Mileage: 148852 km
                    Temperature: 31.5°C
                    Voltage: 11.80 V
                    Load: 9.0 %
00532 - Supply Voltage B+
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 06:06:42
                    Voltage: 9.00 V
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 40
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:03:16
                    Voltage: 12.10 V
                    Temperature: 18.0°C
                    (no units): 31.0
                    (no units): 52.0
                    Temperature: 13.0°C
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 48
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:01:44
                    Temperature: -50.0°C
                    Fault Status: 00101010
                    Fault Frequency: 13
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 16:20:55
                    Fault Status: 00101110
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:12:11
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:17:31
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:41:26
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000006996793
   Coding: 118E4F07A014100000000000000000000008EE175A0500
   Shop #: WSC 06314 000 08192
   VCID: 408F2E6B13C4E3864B-8014
   Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
10 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 00:00:00
                    Voltage: 11.60 V
02071 - Local Databus
                    Reset counter: 31
                    Mileage: 148852 km
                    Voltage: 12.50 V
                    Reset counter: 31
                    Voltage: 5.00 V
                    Fault Status: 00111010
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 00:00:00
                    Voltage: 14.25 V
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 00:00:00
                    Voltage: 14.25 V
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:02:00
                    Voltage: 12.40 V
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:02:00
                    Voltage: 12.40 V
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:16:00
                    Voltage: 11.30 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 31
                    Mileage: 148852 km
                    Voltage: 12.50 V
                    Fault Frequency: 43
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 00:00:00
                    Voltage: 11.60 V
Address 15: Airbags
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Coding: 0003042
   Shop #: WSC 131071 1023 00000
   VCID: 41892B6F18CEEA8E44-8014
   Component: E0221           H06 0030
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No SW: 8P0 920 981 J    HW: 8P0 920 981 J
   Component: KOMBIINSTR. VDO H20 0570
   Revision: D0H20004    Serial number: 2243G004003518
   Coding: 0005416
   Shop #: WSC 31082 001 1048576
   VCID: 3F8D2D976E3A9C7E32-806A
                    Reset counter: 40
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 17:57:54
   Part No: 1K0 907 530 K
   Component: J533__Gateway   H12 0170
   VCID: 2F6D7DD7BE5A6CFEA2-807A
Address 22: AWD
   Revision: D0H20004    Serial number: AUX7Z0G3FNC02N
   Shop #: WSC 00137 211 56823
01176 - Key
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 192     HW: 8P0 035 192
   Component: RNS-E HIGH EU   H54 0660
   Revision:      08S    Serial number: AUZBZ7E0300914
   Coding: 0205755
   Shop #: WSC 01196 210 00002
   VCID: 6CD7AADB4FCCD7E6C7-8038
6 Faults Found:
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 18:04:10
                    Voltage: 8.90 V
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 06:06:03
                    Voltage: 12.10 V
                    Mileage: 148850 km
                    Count: 3009
                    Clock: 00:00
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.14
                    Time: 00:00:21
                    Mileage: 148850 km
                    Count: 2909
                    Clock: 21:10
                    Fault Status: 00100111
                    Reset counter: 31
                    Mileage: 117581 km
                    Date: 2018.07.06
                    Time: 02:55:03
                    Mileage: 148850 km
                    Count: 2809
                    Clock: 00:00
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 00:00:27
                    Bin. Bits:     0010
                    Mileage: 148850 km
                    Count: 3009
                    Clock: 00:03
02444 - Disk Drive Load / Eject Malfunction
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 15:43:54
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0070
   Coding: 0000560
   Shop #: WSC 06314 000 00000
Address 44: Steering Assist
   Part No: 8P0 959 433 F
   Component:    KSG          H08 0070
   Coding: 9980202002186D298505489AC637
   Shop #: WSC 08224 211 56823
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
9 Faults Found:
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
00352 - Terminal 30A
00926 - Terminal 30
00625 - Vehicle Speed Signal
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Serial number: 10000001268587
   VCID: 70EFBEAB63E43306FB-8024
                    Reset counter: 31
                    Mileage: 213787 km
                    Date: 2019.08.28
                    Time: 00:30:06
                    Temperature: 19.0°C
                    Raw, Form. N/A: 000 000 000
                    Reset counter: 31
                    Mileage: 213787 km
                    Date: 2019.08.28
                    Time: 00:29:27
                    Temperature: 19.0°C
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0000560
Address 55: Headlight Range
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0205755
6 Faults Found:
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 18:04:10
                    Voltage: 8.90 V
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 06:06:03
                    Voltage: 12.10 V
                    Mileage: 148850 km
                    Count: 3009
                    Clock: 00:00
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.14
                    Time: 00:00:21
                    Mileage: 148850 km
                    Count: 2909
                    Clock: 21:10
                    Reset counter: 31
                    Mileage: 117581 km
                    Date: 2018.07.06
                    Time: 02:55:03
                    Mileage: 148850 km
                    Count: 2809
                    Clock: 00:00
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 00:00:27
                    Bin. Bits:     0010
                    Mileage: 148850 km
                    Count: 3009
                    Clock: 00:03
                    Reset counter: 31
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 15:43:54
Address 75: Telematics
   Part No SW: 8P0 862 335 S    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0550
   Revision: 00000000    Serial number: 00000005079589
   Coding: 0011202
   VCID: 4683387331E0CDB671-8012
                    Reset counter: 29
                    Reset counter: 29
01523 - Microphone for Telephone (R38)
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 00:00:09
End-------------------------(Elapsed Time: 02:35)--------------------------
Address 19,1K0 907 530 K,recoded (Installation List),from,FD0F03CE07000101,to,FD0F03CE07000101,,
Address 01: Engine
8 Faults Found:
                    Reset counter: 30
                    Mileage: 148852 km
                    Temperature: 31.5°C
                    Voltage: 11.80 V
                    Load: 9.0 %
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 06:06:42
                    Voltage: 9.00 V
                    Fault Frequency: 40
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:03:16
                    Voltage: 12.10 V
                    Temperature: 18.0°C
                    (no units): 31.0
                    (no units): 52.0
                    Temperature: 13.0°C
                    Fault Frequency: 48
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:01:44
                    Fault Frequency: 13
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.28
                    Time: 16:20:55
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:12:11
                    Reset counter: 30
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 00:17:31
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:41:26
   Coding: 00062736
   Shop #: WSC 06314
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:52:00
                    Voltage: 12.20 V
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:52:00
                    Voltage: 12.20 V
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:52:00
                    Voltage: 12.20 V
Address 15: Airbags
   Coding: 0003042
            014 - Defective
   Coding: 0005416
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Revision:   H12       Serial number: 33001074170A4E
   Coding: FD0F03CE07000101
   Shop #: WSC 02021 210 00006
01302 - Control Module for Telematic (J499)
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:52:52
Address 22: AWD
   Coding: 0205755
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:53:07
                    Bin. Bits:     0010
                    Mileage: 148850 km
                    Count: 3009
                    Clock: 20:53
   Coding: 0000560
   Coding: 0000560
   Coding: 0205755
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:53:07
                    Bin. Bits:     0010
                    Mileage: 148850 km
                    Count: 3009
                    Clock: 20:53
   Coding: 0011202
                    Reset counter: 246
                    Mileage: 148852 km
                    Date: 2019.09.30
                    Time: 20:52:46
End-------------------------(Elapsed Time: 04:21)--------------------------
PetrolDave
Westbury, UK
C?ID=1423
Some modules can be reached, but not those on the Powertrain CAN by the look of it - maybe that's the place to start investigating?
I wonder if this car has a wonky CAN Gateway? The data from it is incomplete:
I would try accessing it directly to see if it has any faults and try to check MVBs in it as well.
LHSLTD
C?ID=271214
Thanks peeps. I had already told him to take the gateway out and check it for any obvious damage. I've also asked him to take the one out if the donor chassis, which I think he still has the guts of for spares and keep it handy.
I'll keep you informed of any progress.
Thanks again.
LHSLTD
C?ID=271214
He did say he had checked them all and they were ok, hence the reason I told him to check the power pins on the ECU and the battery, and aiming towards a wiring/control module problem.
