Project Q7
FandaTDI
Czech Republic
C?ID=204559
I´ve got "an opportunity" to finish project of Audi Q7 2007(6 - one of the first), where the engine is after a bigger service (and it´s BUG, not ASB like labels said - little shame, that these engines/units aren´t documented better, but most needed things/values is "known" even if sometimes not by vcds...), mmi was upgraded from 2G to 3GP, BEM to GW, etc. ...
My questions/what I would like is to better understand and discover consequnces/possibilities/functionalities of this "combination"...
Let´s start with BEM... How much it affects the units with BEM fault their behavior and is it possible to tell them that there is i GW BEM? The Aux.heater is functional (for sure I set higher voltage threshold), it has only a timer (not remote), central unit is behaving also ok (no bigger discharging), but I would like to know e.g. what is the reason that even on a good/quality/clever charger (that can cover a consumption while ingon/engoff...) mmi goes to sleep after some time... (and therefore for sure I rather updated with engon even if the charger can cover it...)
Some thoughts/advices? Btw. to be more precise, now (after update and some changes in green menu) I have in 5F just 3 faults (antenna not fitted ... ) nad what about the fault 00166, there was a 433Mhz and now it is 868MHz... Do someone knows what exactly means the metadata? (aalso about 03175/03157 where the fault status is the same...)
Tuesday,26,May,2020,19:53:37:12188
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4L87D037657   License Plate:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 36 42 46 47 4F 52 55 56
          5F 62 6F 72
VIN: WAUZZZ4L87D037657   Mileage: 306610km-190518miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4L0 910 401 K    HW: 4L0 907 401
   Component: 3.0L V6TDI  G001AG  0030
   Revision: --H03---    Serial number:
   Coding: 0011775
   Shop #: WSC 80093 222 69422
   VCID: 2A18EEA785D0B5D675-807E
   Part No SW: 09D 927 750 FK    HW: 09D 927 750 FK
   Component: AL 750 6A           0940
   Revision: 00H52000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 7CB418FF3FC4FB6657-8028
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0038033
   VCID: 281C14AF9BDC87C663-807C
   Part No: 4F0 910 852
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601000505991
   Coding: 0000131
   Shop #: WSC 06402 785 00200
   VCID: 63864383A27A249E76-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H44 0070
   Component: FBSAUDIC6 IDG   H01 0040
00166 - Access/Start Authorization Switch (E415)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 121
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000030392252
   Coding: 00000816
   Shop #: WSC 34440 002 1048576
   VCID: 25021D9B2CCE9AAE58-8070
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 121
                    Mileage: 306610 km
                    Date: 2020.05.25
                    Time: 16:30:55
                    Temperature: 16.0°C
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Coding: 0002122
   VCID: 312AF9CBA806C60EB4-8064
   Component: Wischer AU716   H18 0110
   Coding: 00022806
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 655 B    HW: 4L0 959 655
   Component: 31 AIRBAG AUDI8RH38 0120
   Revision: 05H38000    Serial number: 0037GD06GDVJ
   Coding: 0013105
   VCID: 2C14E8BF8F24ABE687-8078
   Subsystem 1 - Serial number: 6332QSME1562157DF
   Subsystem 2 - Serial number: 6342QSME15614011
   Subsystem 3 - Serial number: 6352QSME127077359
   Subsystem 4 - Serial number: 6362QSME14374859J
   Subsystem 5 - Serial number: 63734SME11720F47
   Subsystem 6 - Serial number: 63834SME1163481F+
   Revision: 00H08000    Serial number: 90026062010273
   Coding: 0002042
   VCID: 66805A97514851B691-8032
   Component: Lenkradmodul    H03 0040
   Part No SW: 4L0 920 932 S    HW: 4L0 920 932 S
   Component: KOMBIINSTR.   H22 0411
   Revision: 00000000    Serial number: JX623XY6C
   Coding: 035D630400010008810105
   VCID: 3C34D8FFBF443B6617-8068
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 C
   Component: Heizgeraet      H07 0060
   Revision: 0000000E    Serial number: 00000009011043
   VCID: 608C4C8FB36C3F866B-8034
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MA702019    Serial number: 1900M0852980DD
   Coding: 00CF07
   VCID: 3A38DEE7B570055605-806E
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140671002
02001 - Data-Bus Automatic Distance Regulation
                    Reset counter: 121
                    Mileage: 306610 km
                    Date: 2020.05.25
                    Time: 16:30:51
                    Bin. Bits:    10111
                    Voltage: 14.00 V
                    Count: 7
                    Bin. Bits:    10011
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 B    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7550
   Revision: --H03001    Serial number: 15.1528-0095.2
   Coding: 0015510
   VCID: 291A11AB80D6BECE7C-807C
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00001010158519
   Coding: 00581300000011110000
   VCID: 3228F6C76D00FD16CD-8066
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 C    HW: 4L0 959 793 C
   Component: TSG FA          H21 0050
   Coding: 0000523
   VCID: 302CFCCFA30CCF06BB-8064
   Part No SW: 4L0 910 289 C    HW: 4L0 907 289
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01017057110000
   Coding: 4194545
   Shop #: WSC 18798 211 56823
                    Reset counter: 121
                    Mileage: 302016 km
                    Date: 2016.05.20
                    Time: 12:08:50
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0160
   Revision: CH003000    Serial number: 00000000026561
   VCID: 291A11AB40D6BECE7C-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Revision:             Serial number: 00000000005665
   Coding: 0011101
   VCID: 5EF072778918097659-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 792 C    HW: 4L0 959 792 C
   Component: TSG BF          H21 0050
   Coding: 0000523
   VCID: 2F2EFFB3BE32D0FEA2-807A
   Part No: 8P0 907 357 F
   Coding: 0000008
   VCID: 3D32D5FB645E326E20-8068
   Part No SW: 4F0 035 053 B    HW: 4F0 035 053
   Component: Radio U Basic H45 0020
   Revision: AB001007    Serial number: 341JY097652903
   Coding: 020003010000000000
   Shop #: WSC 06325 123 12345
   VCID: 1C74387F1F845B66F7-8048
02982 - Connection between Radio and Impedance Converter 2
                    Reset counter: 121
                    Mileage: 306610 km
                    Date: 2020.05.25
                    Time: 16:31:00
                    Voltage: 13.70 V
   Part No SW: 4H0 035 654     HW: 4H0 035 670 C
   Component: H-BNT-EU      H41 0941
   Revision: --------    Serial number: 060KK0A7501310
   Coding: 05010006000493EC43008F156B032001000001000100000102
   Shop #: WSC 73430 031 00063
   VCID: 63864383627A249E76-8036
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H42 0098
   Serial number: 9466EF0A0003600
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002158159
   Component: CD-Database  3371
03175 - Invalid Data Set
                    Reset counter: 121
                    Mileage: 306610 km
                    Date: 2020.05.25
                    Time: 21:46:20
                    Voltage: 12.60 V
                    Reset counter: 161
                    Mileage: 306610 km
                    Date: 2020.05.25
                    Time: 21:46:25
                    Bin. Bits: 00010000 00000000
                    Bin. Bits: 00000000 00000001
                    Bin. Bits: 00000000 00000000
01524 - Antenna for Telephone
                    Reset counter: 121
                    Mileage: 306610 km
                    Date: 2020.05.25
                    Time: 21:46:30
                    Voltage: 14.10 V
03623 - Invalid Security/Release Code
                    Reset counter: 121
                    Mileage: 306610 km
                    Date: 2020.05.25
                    Time: 21:46:20
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 C    HW: 4L0 959 795 C
   Coding: 0000010
   VCID: 3228F6C7AD00FD16CD-8066
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Revision: AAH05061    Serial number: 001858799-----
   Coding: 0000005
   VCID: 65825D9BAC4E5AAE98-8030
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 C    HW: 4L0 959 794 C
   Coding: 0000010
End----------(Elapsed Time: 01:42, VBatt start/end: 14.5V/14.5V)-----------
Label files are often used for more than one engine code. They will generally be named after the first engine code they were originally written for.
FandaTDI
Czech Republic
C?ID=204559
The next reason (/reason more) why it would be great to be better documented. ;-) E.g. the values of partic.filter (here mostly in MVB 102-104) - some are documented/described, some not (like I can´t select/view km from last regeneration in adv.mvb...). Also e.g.the fuel bleeding isn´t still documented (some time ago I´ve been searching for activation of fuel pump and Niels told me that it will be added... https://forums.ross-tech.com/showth...eaeration-quot-of-the-fuel-system(label-file) ).
Any other thoughts? Like about the BEM(in GW)? Or like what exactly means (are pointing on) the fault status of 00166? (could be deleted and hoping it will not came back, for sure I´ve spare/original E415 but it has other crystal/not works with 868MHz remote...). Or 03157/03175 fault status? Could be connected with some settings/equipment like oil level (fortunately this isn´t from days when VWAG starts to trying make savings on oil dipsticks :D:D - this deserves some kind of shitty award :D but it has also sensor on the bottom of engine even when probably "not supported" for displaying the level) Which leads me to other thought - many of us knows that the battery state in mmi is a crap value, but if there will be some way to display SOC (GW MVB 19/1), it could be a little bit more useful...
FandaTDI
Czech Republic
C?ID=204559
Nobody?
And what about a PDC unit from A8(4E0919283C)? On the Q7 wasn´t PDC but the previous owner fit there both bumpers with PDC sensors and I´ve a unit from A8 with cables and one buzzer, so I installed it for now just with rear sensors (partly prepared cables, front are without cables yet...) and it looks like it might work (for a moment after clearing the faults of front sensors and H22 it also shows OPS), but only with all 8 sensors and 2 buzzers. I thought it could be recoded to just rear sensors for now, but not found in the coding... Is it possible to make it work with just rear sensors? Thanks
siLc
Tallinn, Estonia
C?ID=330192
Nobody?
8/12ch parking aids usually want to see 8/12 sensors at all times and can't be made to function otherwise.
