Output test stays on running for over 5 minutes no movement
Should be more-or-less instant.How long is it if you are going to receive something
Thursday,18,June,2020,10:49:05:23500
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 36 42 46 47 52 53 55 56
5F 62 6C 6D 72
VIN: WVGZZZ7PZDD030381 Mileage: 41515km-25796miles
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H40 0003
Revision: 53H40---
Coding: 292A401A232601020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401F 001004
ROD: EV_ECM30TDI_VW52.rod
VCID: 323E127844AADD5B95F-8066
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 BK HW: 0C8 927 750 BK
Component: AL1000 AISIN 002 2268
Coding: 001568
Shop #: WSC 45173 001 1048576
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 76B6EE68E842817B797-8022
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 404130010EC815
Coding: 5B6B13C309272553DAF7C89B90D3A450F700
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4ACE6A98CC3AB59BCDF-801E
Part No SW: 4H0 907 064 CH HW: 4H0 907 064 CH
Component: BCM2 2.0 H33 0433
Coding: 05B60016000000000000
VCID: 71BCDD7481ACA643AC5-8024
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 2312000285039002
03286 - Sensor for Contact with Door Handle; Front Right
Fault Status: 00100111
Reset counter: 172
Mileage: 41515 km
Date: 2020.06.18
Time: 10:19:26
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BM HW: 7P6 907 040 BM
Component: Klima 2 Zonen H20 1305
Coding: 36B6000A10
VCID: 005A88B0BA86BFCB53B-8054
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001513620
Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
VCID: 6C82CC00A68E4BAB9F3-8038
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 130203 031 0021
Serial number: 90243401130207202738
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20060772
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 D HW: 7P6 941 431 D
Component: E1 - LDS H04 0031
Serial number: 00000000000802130203
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28261302600340
Coding: 508501
ASAM Dataset: EV_VW526ParkiAssis2 001012
ROD: EV_VW526ParkiAssis2.rod
VCID: 43D047BCEB1064D30E9-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag00K H05 0025
Revision: -------- Serial number: 003L0006JTWO
Coding: 00000000000000000000000000000000304B
VCID: 41DC4DB4F10C76C31C5-8014
Serial number: 3575LRB405F1RIRO18QK
Serial number: 3585LRB405F1RIROG1BE
Serial number: 3515RRB400A4UP60O21D
Serial number: 3525RRB40084UP60A96A
Serial number: 3555NRB401C4UOFA9I3.
Serial number: 3565NRB401C4UOFANHRW
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815MBD00036
Coding: 000C35
VCID: 382A2050A256370BABB-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0237862
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 981 M HW: 7P6 920 981 M
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658110213592043
Coding: 333733002A00260001000C
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526.rod
VCID: 47C853ACDF2848F3D21-8012
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 7P0 963 272 D HW: 7P0 963 272 D
Component: Standheizung H23 0243
Revision: 56005006 Serial number: 20130130234340
Coding: 594200
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H11 6028
Revision: -------- Serial number: 00000000825918
Coding: 000D07AD00
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3B203F5C93E01C13469-806E
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000004191031599
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Component: J532_DCDCStab H17 0042
Serial number: 13043002405021200181
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000050459484
Coding: 00781B0000004001000001010101202020202121202020
VCID: 34321460BE3ED36B873-8060
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000051100085
Coding: 011D1620DE01451005080002
VCID: 44D244A0EE9E63EB373-8010
Revision: 00002001 Serial number: 0300965079
Coding: 011B1E2228B9109583200624010000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO2014138-
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO2012672.
Coding: 191100
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002176507
VCID: 75B4E964F5C48A6370D-8020
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000050710024
Coding: 011D1620DE01451005080000
VCID: 3B203F5C93601C13469-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1320500318
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 36362E68A8C2C17BB97-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 018E00000F000200
VCID: 7CA2FC40D66EDB2B0F3-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Part No SW: 4G0 035 061 J HW: 4G0 035 061
Component: Radio U DAB H60 0123
Revision: AB001007 Serial number: 109BT0D7611670
Coding: 010105010000000003
VCID: 2412E4200EDE43EB173-8070
Part No SW: 7P6 035 670 E HW: 7P6 035 670
Component: H-BNT-EU H47 0593
Revision: -------- Serial number: 478B60D7595365
Coding: 020101050040C3EF41000B0E00000003F00401030000000000
VCID: 3728236CAF483873A21-8062
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9M78021P8
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000051808798
Coding: 011C14200001251005080000
VCID: 3A2E3A589C5A251B5DF-806E
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 E HW: 7P6 907 441 D
Component: TopView H05 0100
Revision: 11001001 Serial number: 82330JF0073940
Coding: 0100000001000000000102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 029300012
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
VCID: 3FD84B4C87F800336A1-806A
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000050716773
End----------(Elapsed Time: 02:01, VBatt start/end: 14.7V/14.7V)-----------
