Powerfold Mirror Programming on Seat Alhambra
Ronnie.Vincent
C?ID=389395
I want to reprogramme my powerfold mirrors to fold in when locking & out when unlocking the vehicle.Found a couple of videos on YouTube on a Golf and Audi, one of which was by entering the security code and the other by long coding? Not too sure on attempting long coding at the moment but the security code used in the video was not accepted in my VCDS for the vehicle. Does anybody know the Security Access Code for Seat Alhambra 2019 for 09 Central Electrics, then 42,Door Electrics Driver & 52, Door Electrics Passenger. I think the code I use is 99, Lock in, Unlock out while 95 is Lock in, Engine Start out? Thanks
Sunday,10,May,2020,14:40:31:08428
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: VSSZZZ7NZLV502802 License Plate: K80EXC
Mileage: 30580km-19001mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 18 19 25 36 3C 42 44 46 4C 52 53
5F 61 62 69 6C 6D 72 A5 BE BF
VIN: VSSZZZ7NZLV502802 Mileage: 30580km-19001miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
That's a nice Gateway Installation List, but you'll need to post the full scan for people to see the details of the module(s) in question.
Ronnie.Vincent
C?ID=389395
Uwe:
Sunday,10,May,2020,14:38:31:08428
Address 01: Engine (J623-DLTA)       Labels: None
   Part No SW: 04L 906 016 PR    HW: 04L 907 309 AB
   Component: R4 2.0l TDI   H20 7034
   Revision: 8EH20---
   Coding: 0119001A043511082000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01104L906016PR 004001
   ROD: EV_ECM20TDI01104L906016PA_VW36.rod
   VCID: 08499FE5B2B1358B1B2-805C
   Part No SW: 5N0 614 109 CT    HW: 5N0 614 109 CT
   Component: ESC-EBC460iV1 H16 0050
   Serial number: A020S78
   Coding: 11F0449A8920C26E287F880022C59143143117F0F0014094
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 7F5B0439E77F72332A8-802A
0852 - Indicator Lamp in Auto-Hold Switch
          C1156 14 [008] - Open or Short to Ground
                    Reset counter: 21
                    Mileage: 28901 km
                    Date: 2020.03.04
                    Time: 08:15:21
                    Additional_Codes: 00 00 00 0E C0 7F 40 48 00
                    DTC: 00 03 54
                    Additional2: 04 02 01 0D 1B 00 66 00 66 00
   Part No SW: 7N0 907 044 BE    HW: 7N0 907 044 BE
   Component: Clima-Sharan  H04 0707
   Revision: 00001K06
   Coding: 021000C549
   ASAM Dataset: EV_ClimatronicSharan A01724
   VCID: 74B1DB15DE39216B47A-8020
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20190822000000216536
   Part No SW: 5K0 937 086 AC    HW: 5K0 937 086 AC
   Component: BCM PQ35 M    122 0193
   Revision: BC122001
   Coding: 40590A3F8925E1C0508800C8B400817403D10008636D2D226480C72000C1
   Shop #: WSC 00020 790 00000
   VCID: 75B7E611D5C33863704-8020
   Subsystem 1 - Part No SW: 7N2 955 119 C    HW: 7N2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS428 190708  024 0646
   Serial number: 19070303044961
   Coding: 004DBD
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: SAY19M08D30H14M46S12
   Coding: 0228BB
   Subsystem 3 - Part No: 7N0 951 172
   Component: Sensor, DWA 0  005 0502
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0009
03789 - Terminal 75 Limp Mode Active
                    Reset counter: 13
                    Mileage: 29964 km
                    Date: 2020.03.13
                    Time: 16:07:00
                    Voltage: 10.40 V
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331925901539
   Coding: 0071155201
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   VCID: 372B2C198FCF8A73A28-8062
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 2808190438AEC2
   Coding: 00000900FE0739
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 3635211D88C5737BB9E-8062
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag11B H16 0016
   Serial number: 003PWPE237AZ
   Coding: 003142
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40D947C5DA01CDCB132-8014
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS609104491E9DV
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS609405491EDDV
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS60EFA1481EDDA
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60EEA3481EDDC
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS60ABB94A1E9D0
   Part No SW: 5K0 953 521 FP    HW: 5K0 953 569 BD
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20181219200573
   Coding: 3082240000
   ROD: EV_SMLSNGVOLWSR8C.rod
   Subsystem 1 - Part No SW: 6JA 919 719 D    HW: 6JA 919 719 D
   Serial number: 000000000G1663130719
   Coding: 001000
   Part No SW: 7N5 920 980 G    HW: 7N5 920 980 G
   Component: KOMBI         H03 3030
   Coding: 410F010800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3D273E31ADF3A023784-8068
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   VCID: 38292F258E51850BAB2-806C
   Part No SW: 7N0 907 530 BR    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1708
   Revision:   H56       Serial number: 130919F1001396
   Coding: 468233
   VCID: 015F82C1910B04C35CC-8054
   Component: IMMO          H03 3030
   Coding: 000002
   VCID: 6A8DC56D8CFDE79BED6-803E
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H06 3101
   Revision: 00H06000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 372B2C198F4F8A73A28-8062
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0149
   Serial number: 00000525665645
   Coding: A29544A0
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F2A21B9DB9C0354C-806C
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000388592878
   Coding: 01112E209E01411001
   VCID: 49CF5AE1E9BB0C83C4C-801C
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 275    3501
   Revision: 00H21000
   VCID: 42DD4DCDD88DDFDB056-8016
Address 4C: Tire Pressure II
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000388596756
   Coding: 01112C209E01411001
   VCID: 48C95FE5F2B1F58BDB2-801C
Address 53: Parking Brake
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 7N5 035 680 E    HW: 7N5 035 680 E
   Component: MU-S-ND-ER    H41 0475
   Serial number: SEZAZ2W0415635
   Coding: 04240801FF0000000111110100880A001F0103C60020010086
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 3537261195C37863B04-8060
   Subsystem 1 - Part No SW: 5F0 060 884 BT    HW: -----------
   Component: ECE AS 2020  --- 1310
   Component: Batt.regelung H56 1708
   Coding: 330F7873
   VCID: 71BFD201A1AB1443ACC-8024
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 56249C04165831253126
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H03 0561
   Revision:             Serial number: 0000388580574
   Coding: 01006C200001411001
   VCID: 4CC163F5E6C919ABFFA-8018
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383 A    HW: 7N0 907 383
   Component: Anhaenger     H12 0130
   Revision: 3I001001    Serial number: 00000527515598
   Coding: 410C040003000000
   VCID: 34311B159E39616B87A-8060
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408010301000700
   Shop #: WSC 00020 999 39850
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 303917056AA15D4BE32-8064
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H12 0250
   Revision: 41012002    Serial number: 245900872
   Coding: 0733334003
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B233029B3E7AE13460-806E
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H03 0561
   Revision:             Serial number: 0000388572988
   Part No SW: 3Q0 980 654 Q    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0881
   Serial number: 26081912K13983
   Coding: 0304020800000401000613078080400090000E00002000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 45D756D1C523E8E3204-8010
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 19351211
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 38292F2582D1850BAB2-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 19351233
   ROD: EV_AST.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 12.1V/12.1V)-----------
Ronnie.Vincent
C?ID=389395
siLc, thanks for the link. Had a look at it and the Security Code quoted there is the same one I picked up off the You Tube video but did not allow access to the Seat. The settings of 90, 95 & 99 are also the same but of course could not access without the correct security code?
Ronnie.Vincent
C?ID=389395
UPDATE ** UPDATE
Thought I would update the forum on how I have got on. Still not able to gain the Security Access through VCDS but a little bit further search on the internet turned up a piece of relevant information.
This may only be applicable to later models but will put a bit of a further update on when I get a chance to try it on my 2017 VW Sharan.
This does not give you any options on how it operates but initializes the 'Comfort Mirror Folding' action.
So,
Once into VCDS;
Select Module 42 Driver Door Electrics / Module 52 Passenger Door Electrics >> Coding 07 >> Long Coding Helper >> Byte 4 >> Bit 6 Comfort Mirror Folding Active, Tick box >> Accept new code >> Close VCDS
Lock vehicle, then, hold down lock button on remote and mirrors close.
Open doors, then, when you start the car the mirrors fold out.
I would prefer them to fold out when unlocking the doors so may keep looking for the Security Access Code to see if I can reset it to that at sometime.
Dukedesmo
C?ID=288946
I think that's how they all work? My S4 has folding mirrors (can be activated from the car - no need for VCDS) that fold when the doors are locked (no need to hold down lock button) but they don't open again until the engine is started.
PetrolDave
Westbury, UK
C?ID=1423
On my MQB Skoda Octavia the mirrors fold out when I unlock the doors and fold in when the doors are locked - as OP wants, but there's nothing I can see in the coding or adaptation to change that behavior (not that I want to I like it that way).
Dukedesmo
C?ID=288946
Interesting, maybe it can be changed somewhere? but (as you are with yours) I'm happy enough as it is, as long as they open before I drive away.
The Wife's Q2 (MQB?) doesn't (I think?) have folding mirrors so can't be activated anyway, it does have the windows close/open by holding down the lock/unlock but I assume that is a standard feature? as my S4, my Son's Golf do and even my old A3 did - the old Polo doesn't though as it has old-school wind-up windows... :D
ch1z64
C?ID=316572
My 2010 8P S3 does the fold in once lock button on fob is held and open out once i insert key into ignition and turn once before starting engine . This was done using Vcp
truckerfyren
New Member
