Audi SQ5 8R 2015 Towbar coding Problem
RussJ
C?ID=288662
I've installed a Westfalia towbar with the dedicated Audi wiring kit.
According to the official spec my car should have had Trailer Prep but I couldn't find the plug so I've followed the instructions for a non-prepped car.
This involves tapping into CanBus and power.
The supplied trailer module is showing a green solid LED which indicates that it is wired up correctly.
I've applied the following codes (which I found on the net):
* 01 - Engine [Coding - 07]->[Long Coding Helper]->Byte 5, Bit 4 Changed from 0 to 1 (via check box "Trailer Installed")
* 03 - ABS Brakes [Security Access - 16] (Enter code presented by program) [Coding - 07]->[Long Coding Helper]->Byte 1, Bit 7 Changed from 0 to 1 (via check box "Trailer Hitch Installed")
* 09 - Cent. Elect [Coding - 07]->[Long Coding Helper]->Byte 18, Bit 5 Changed from 0 to 1 (via check box "Trailer Hitch Installed")
* 10 - Park/Steer Assist [Coding - 07]->[Long Coding Helper]->Byte 0, Bits 0-3 Changed from 0000 to 0001 [Trailer Hitch Not Installed to Trailer Hitch Installed (Manually Removable) via pull-down list]
* 19 - CAN Gateway ->[Installation List]->Tick 69 - Trailer
* 5F - Information Elec [Coding - 07]->[Long Coding Helper]->Byte 10, Bit 5 Changed from 0 to 1
* 6C - Back-up Cam [Coding - 07]-> xx?0xxx: +1 = Trailer Hitch installed
* 69 - Trailer - No change required (unless wrongly coded before install)
These were the settings i needed to do on a Q5, i do not have any info a SQ5 is different, but if you just follow the checkboxes in VCDS nothing should go wrong (5F can also be changed in the hidden green menu instead of doing VCDS coding (check trailer hitch in Car > extdevicelist ), 6C is optional, if you don't have a backup cam you wont have this module.
However, when I scanned the car it came up with a sea of red!
The engine will start and run for a couple of seconds and then cuts out.
I disconnected the battery before doing the wiring .
I've attached a scan and would appreciate any advice.
Russ
Monday,25,May,2020,11:01:07:63302
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8R8FA079650   License Plate:
Mileage: 58010km-36045mi   Repair Order: scan2
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
          56 5C 5F 62 69 6C 6D 72 A9 C0
VIN: WAUZZZ8R8FA079650   Mileage: 58010km-36045miles
05-Acc/Start Auth. -- Status: Cannot be reached 1100
20-High Beam Assist. -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
5C-Lane Maintain. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: Malfunction 0010
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589     HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0004
   Revision: 57H25---
   Coding: 2A2A4032257603020000
   Shop #: WSC 06208 123 12345
   ASAM Dataset: EV_ECM30BTD0118K5907589 001007
   ROD: EV_ECM30BTD011_AU48.rod
   VCID: 7EF275E8E100337679-802A
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Coolant temperature: 15 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 11.320 V
                    ACC target acceleration: 0.007 m/s²
                    ACC control module received status-Bits 0-7: 7
                    Active brake system error status-Bits 0-7: 48
                    Status of ACC/CCS acceleration interface-Bits 0-7: 3
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:44:39
                    Coolant temperature: 16 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 10.320 V
                    ACC control module received status-Bits 0-7: 4
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
          U0428 00 [039] - -
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    CAN TimeOut meter - battery manager-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 244
                    CAN TimeOut meter - gateway-Bits 0-7: 0
                    CAN TimeOut meter - steering angle-Bits 0-7: 0
                    CAN TimeOut meter - parking brake-Bits 0-7: 0
                    CAN TimeOut meter - transmission-Bits 0-7: 0
4720 - Body Control Module (Central Electric 2)
          U0141 00 [039] - No Communications
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:53
                    selected gear-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [038] - -
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Immobilizer snapshot A-Sia Error Snap A: 39 00 1D
                    Immobilizer snapshot B-Sia Error Snap B: 0A 00 00
   Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1007
   Revision: --H19---
   Coding: 000001
   VCID: 000E0B109BF445860B-8054
2543 - Transmission Control Unit
          P1701 00 [167] - Locked
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Voltage terminal 30: 11.458 V
                    Immobilizer Snapshot 1-Param 0: 2F
                    Immobilizer Snapshot 1-Param 1: 00
                    Immobilizer Snapshot 1-Param 2: 1C
                    Immobilizer Snapshot 1-Param 3: 0A
                    Immobilizer Snapshot 1-Param 4: 00
                    Immobilizer Snapshot 1-Param 5: 00
                    Status data bus communication diagnostic interface-State Deashboard received: not received
                    Status data bus communication diagnostic interface-State ECM received: not received
                    Status data bus communication diagnostic interface-State ESP received: not received
                    Status data bus communication diagnostic interface-State Gateway received: not received
                    Status data bus communication diagnostic interface-State Parking Brake received: not received
                    Status data bus communication diagnostic interface-State Steering Angle received: not received
                    Status data bus communication diagnostic interface-State Steering Assist received: not received
12560 - Body Control Module (Central Electric 2)
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Voltage terminal 30: 11.460 V
                    Engine speed: 0 /min
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
   Component: ESP8 quattro  H09 0020
   Coding: 24DDCC01
   Shop #: WSC 06335 123 12345
   VCID: 0E122528D9A023F689-805A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:44:39
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x001A
                    Hex Value: 0x0282
                    Hex Value: 0x0000
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:44:44
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0022
                    Hex Value: 0x1B8A
                    Hex Value: 0x0000
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:44:46
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0045
                    Hex Value: 0x138B
                    Hex Value: 0x0000
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:44:46
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x002F
                    Hex Value: 0x238B
                    Hex Value: 0x0000
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:44:46
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x002F
                    Hex Value: 0x238B
                    Hex Value: 0x0000
Address 05: Acc/Start Auth.
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01211120141279
   Coding: 3625028000
   Shop #: WSC 06335 000 00000
   VCID: 78FE63F0CB240D4633-802C
   Revision: 08016001    Serial number: 00000951648401
   Coding: 260000108074AFE00581404300001D0D0F9D670827090201000008004400030100000034000000
   Shop #: WSC 50664 002 104857
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140825  H12 0050
   Serial number: 90243015140820021300
   Coding: 01DD13
   Serial number: 23488562
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001511146557
   Serial number: 37488D57000000000001
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:45:32
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 007D8A
   VCID: 377CA0CC86BAC23EFA-8062
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:53
                    Temperature: 31.0°C
                    Voltage: 11.39 V
                    Hex Value: 0x008A
                    Lateral Accel.: 0.00 m/s^2
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Temperature: 31.0°C
                    Voltage: 11.39 V
                    Hex Value: 0x00C9
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
                    Temperature: 31.0°C
                    Voltage: 11.39 V
                    Hex Value: 0x005D
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
                    Temperature: 31.0°C
                    Voltage: 11.39 V
                    Hex Value: 0x00BE
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
                    Temperature: 31.0°C
                    Voltage: 11.39 V
                    Hex Value: 0x00C0
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003JPDC21U3M
   Coding: 30473431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 489ED330F344BDC683-801C
   Serial number: 6334MSME4A6B2B05M
   Serial number: 6344MSME4A596417K
   Serial number: 6352QSME5C484164L
   Serial number: 6362QSME5C4B216CV
   Serial number: 63732SME3449245C%
   Serial number: 63832SME714B487A9
   Revision: --------    Serial number: 90372NKI000FS
   Coding: 0000FF
   VCID: 4486C700C76C99A66F-8010
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
                    Fault Status: 01100101
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
                    (no units): 62.0
                    Text: 3E820000FFFFFFFFFF
                    Current: 0.000 A
                    Raw, Index/Key Err.: 255 255 255
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 951     HW: 8R0 920 951
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 03I32JJCF
   Coding: 33E7220047012600010000
   VCID: 74E657C0D74C69261F-8020
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z14B190417
   Coding: 80CD07FF00
   VCID: 4C96EF20EF3C51E6A7-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 4899974903
   Serial number: 14311000484011200410
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:54
                    Bin. Bits:    10001
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:54
                    Bin. Bits:    10001
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
   Revision: AA001002
   Coding: 02022064747464545425363E00
   VCID: 7CF67FE0FF1C216657-8028
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.23
                    Time: 16:33:55
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000124832453
   Coding: 01781B00000000000000
   VCID: 428AC118DD7897965D-8016
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0334371538
   Coding: 010312
   Shop #: WSC 06334 123 12345
   VCID: 3F8CC8ECA68AFA7E32-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0334316078
   Coding: 010312
340484 - Databus
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0009187955
   Coding: 100001010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
4205828 - Steering angle sensor
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Write only channel
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Write only channel
3161616 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Write only channel
Address 46: Central Conv.
   Revision: 00005001    Serial number: 94813037454706
   VCID: 2D5082A474E678EE90-8078
Address 52: Door Elect, Pass.
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000545768
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7AB9F8BDA8DF5605-806E
333824 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Voltage terminal 30: 11.5 V
                    Internal Fault ID: 50
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Auto Adjust: not active
330240 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Internal Fault ID: 96
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
330496 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Internal Fault ID: 97
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
335360 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Internal Fault ID: 209
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109K60E7992209
   Coding: 010103010000000001
03278 - Functionality Limited due to Missing Messages
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:42:10
                    Bin. Bits: 00000000 00000001
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600214B2000165
   Coding: 0002204
   VCID: 377CA0CC46BAC23EFA-8062
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
                    Fault Status: 00101101
                    Reset counter: 75
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 H
   Component: H-BN-EU       H48 1036
   Revision: --------    Serial number: 515K10E7503269
   Coding: 1A0101060205A9EF7D80CB5E00000403E40000020000000000
   Shop #: WSC 50664 002 1048576
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Component: DU7 High  H42 0104
   Serial number: A130KZ0E3196812
   Serial number: 00000002055351
   Component: CD-Database  5950
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:56
                    Text: DUA130,Front,M,0,0,6
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:58
                    Bin. Bits: 00100000 00000000
                    Bin. Bits: 00000000 00000000
03623 - Invalid Security/Release Code
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:55
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
Address 62: Door, Rear Left
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: ConWys Trailer H09 0100
   Revision: 1G001001    Serial number: 00000173782896
   Coding: 0100000000000000
   Shop #: WSC 00375 223 87350
   VCID: 3560AAC49CB6302EE8-8060
Address 6C: Back-up Cam.
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D70B2E4A486E86E20-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:51
Address 72: Door, Rear Right
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 141021202723
   VCID: 79F866F4F82E144E4C-802C
0005 - Incorrect Vehicle Type
          U10D9 00 [009] - -
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 141021200750
   VCID: 71E85ED4A05E5C0EF4-8024
          U10D9 00 [009] - -
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 10:41:52
End-------------------------(Elapsed Time: 04:28)--------------------------
m87a
Bosnia and Herzegovina
C?ID=156900
Did you check that all modules are plugged in? Also check fuses, since you connected wires there are some modules not communicating especially Address 05: Acc/Start Auth.
Cannot be reached, hence the car won't run...
RussJ
C?ID=288662
Thanks for your quick response.
Fuses all OK, modules all plugged in but....
Both the canbus wires from the connector had broken downstream of my soldered splices. The splices were fine but I must have been a bit rough squeezing the wires back into the connector cover.
I repaired the breaks and at least the car runs!
I cleared all the DTCs and then re-scanned see below.
I also went through my coding again to make sure it had all been entered correctly:
10 Park/steer assist - can't connect with the module.
5F - Byte 10 does not show bit 5 (stops at 4)
There's still bits disconnected so I expected some errors to remain but not sure what is the problem with 10 and 5F?
Any ideas?
Russ
Monday,25,May,2020,15:42:09:63302
Mileage: 58010km-36045mi   Repair Order: scan3
5C-Lane Maintain. -- Status: OK 0000
   Revision: 57H25---
          U1113 00 [039] - -
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:24
                    Coolant temperature: 26 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 11.480 V
                    Status of ACC/CCS acceleration interface-Bits 0-7: 4
   Revision: --H19---
   Coding: 000001
   Coding: 24DDCC01
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05B54040000000000000
   VCID: 000E0B1093F445860B-8054
   Serial number: 3214000163027010
   Coding: 3625028000
   Coding: 01DD13
   Coding: 02005C
   Coding: 007D8A
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:25
                    Temperature: 33.0°C
                    Voltage: 11.52 V
                    Hex Value: 0x005D
   Coding: 0000FF
   Coding: 80CD07FF00
   Revision: AA001002
   Coding: 010312
   Coding: 010312
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000126845640
   Coding: 011D12215E01440004
   VCID: 4FACF82C1E2A6AFEC2-801A
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:24
                    Write only channel
   Revision: 00002001    Serial number: 0352486413
   Coding: 013B0E22A0B930958720053680040047
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
03073 - Rear Lid Closed Sensor 1
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:25
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:25
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:25
   Revision:             Serial number: 0000126704127
   VCID: 4E92E528192063F6C9-801A
   Coding: 0002204
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:30
                    Reset counter: 35
                    Mileage: 58016 km
                    Date: 2020.05.25
                    Time: 15:18:28
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000126688328
   Coding: 010C12204001240004
   VCID: 4682DD08F150ABB671-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J49A6JS
   Coding: 1030010
   VCID: 346697C057CC2926DF-8060
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000126699217
End-------------------------(Elapsed Time: 04:45)--------------------------
m87a
C?ID=156900
Check coding in 13, drive a car a little, learn steering limits, move the steering wheel all the way to the left, hold it there then to the right hold it there, for 5F coding go to coding2 and manually enter bit that you want after coding reboot 5F hold and press power button for 10sec, as for 10 Park/steer assist it's not in your gateway list and also it doesn't appear to be present on your car so no coding 10 :).
darkchina811
ITALY
C?ID=333184
I would have never bet they can sell a SQ5 without parking sensors :D
NEtech
C?ID=56995
Easy:) the car has PR-7X8 (Park distance control in front and rear plus rear view camera system).
It is managed by [09] and [6C].
@RussJ, I don't know why you think the car has Address [10], if you look at an AutoScan before retrofit, I am sure, there was also no [10].
[10] was possible up to 2012 (included), I think.
Explanation: Copy the changed coding and insert as new coding:
[Controller No.] > ”New coding”
[13] > 007D83
[3C] > 010322
[5C] > 0102204
RussJ
C?ID=288662
Apologies for the delay in updating - I had some other urgent non-car stuff to sort out.
To be honest I didn't check to see what modules were originally present , just blindly followed the code I found on the internet and assumed that since the model year was the same as mine, everything would work.
Lesson learned!
I re-coded as per NETech's suggestion which cleared most of the errors. I also had to do an "end stop learning" process to clear a warning light.
So, all is now working as it should, except an error code in "Information Electric" caused by a slightly dubious SatNav map update I did a while ago.
Many thanks to everyone who helped me out - this forum is great.
Russ
RussJ
C?ID=288662
I've just started to see an issue when towing. I get an error message on the dash showing a yellow key crossed out in red labelled "ignition lock defective" (or something similar).
The car still drives OK but I noticed that the adaptive cruise also drops out and can't be reset.
Stopping, switching ignition off and on restores everything but the warning message reappears after a few miles.
Is it likely that this has something to do with the coding for the towbar or are the two unrelated?
I'll take a scan from the car shortly to see if anything shows up.
Russ
RussJ
C?ID=288662
Here is the scan. Far too much red for my liking...
Any pointers about where to start fixing this lot would be much appreciated:
Thursday,24,September,2020,18:54:08:63302
VCDS Version: 20.4.2.0 (x64)
VIN: WAUZZZ8R8FA079650   License Plate: CJ55RDJ
Mileage: 63020km-39158mi   Repair Order:
VIN: WAUZZZ8R8FA079650   Mileage: 63020km-39158miles
69-Trailer -- Status: Sporadic communication error 1000
   Revision: 57H25---
   VCID: 7EF275E8E100337661-802A
4865 - No Communication with Towing System Control Module (J345)
          U1003 00 [032] - -
                    Fault Frequency: 9
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:49
                    Engine speed: 1437.50 /min
                    Normed load value: 80.4 %
                    Vehicle speed: 60 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 14.300 V
                    Unlearning counter according OBD: 38
                    Limitation: accelerator pedal: 128.5 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 16
                    selected gear-Bits 0-7: 6
   Revision: --H19---
   Coding: 000001
   VCID: 000E0B109BF4458613-8054
   Coding: 24DDCC01
   VCID: 0E122528D9A023F691-805A
                    Fault Frequency: 83
                    Reset counter: 124
                    Mileage: 61489 km
                    Date: 2020.08.21
                    Time: 15:25:34
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0015
                    Hex Value: 0x1095
                    Hex Value: 0x0000
02214 - Tire Pressure Warning
                    Reset counter: 149
                    Mileage: 61587 km
                    Date: 2020.08.24
                    Time: 13:09:52
                    Hex Value: 0x5100
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x1AB7
                    Hex Value: 0x0000
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 162
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:50
                    Hex Value: 0x5B00
                    Hex Value: 0x4006
                    Hex Value: 0x1F22
                    Hex Value: 0x43B5
                    Hex Value: 0x0000
                    Reset counter: 161
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:56
                    Hex Value: 0x5500
                    Hex Value: 0x4006
                    Hex Value: 0x1F03
                    Hex Value: 0x1FB5
                    Hex Value: 0x0000
   VCID: 000E0B1093F4458613-8054
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Coding: 3625028000
   VCID: 78FE63F0CB240D462B-802C
   Coding: 260000108074AFE0158140C300001D0D0F9D670827090201000008004400030100000034000000
   Coding: 01DD13
   Coding: 02005C
02070 - Rear Parking Aid Sensors
                    Fault Status: 00101011
                    Reset counter: 152
                    Mileage: 62290 km
                    Date: 2020.08.28
                    Time: 12:39:32
                    Fault Frequency: 9
                    Reset counter: 162
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:50
   Coding: 007D83
   VCID: 377CA0CC86BAC23EE2-8062
                    Reset counter: 162
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:50
                    Temperature: 28.0°C
                    Voltage: 14.34 V
                    Hex Value: 0x00DD
                    Speed: 90.0 km/h
                    Lateral Accel.: 0.02 m/s^2
                    Reset counter: 161
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:51
                    Temperature: 28.0°C
                    Voltage: 14.34 V
                    Hex Value: 0x0088
                    Speed: 90.0 km/h
                    Lateral Accel.: -0.38 m/s^2
   VCID: 489ED330F344BDC69B-801C
   Coding: 0000FF
   VCID: 4486C700C76C99A677-8010
   VCID: 74E657C0D74C692607-8020
   Coding: 80CD07FF00
   VCID: 4C96EF20EF3C51E6BF-8018
                    Reset counter: 156
                    Mileage: 62348 km
                    Date: 2020.09.14
                    Time: 14:33:43
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Reset counter: 162
                    Mileage: 62430 km
                    Date: 2020.09.20
                    Time: 11:24:26
                    Bin. Bits:    11111
                    Voltage: 13.70 V
                    Count: 6
                    Bin. Bits:    10000
                    Fault Frequency: 12
                    Reset counter: 162
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:50
                    Bin. Bits:    01111
                    Voltage: 14.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
   VCID: 7CF67FE0FF1C21664F-8028
   VCID: 428AC118DD78979645-8016
   Coding: 010322
   VCID: 3F8CC8ECA68AFA7E2A-806A
   Coding: 010322
388356 - Databus
                    Reset counter: 161
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:49
   VCID: 4FACF82C1E2A6AFEDA-801A
   Coding: 000001010001
                    Fault Status: 00101100
                    Reset counter: 152
                    Mileage: 62290 km
                    Date: 2020.08.28
                    Time: 12:39:31
                    Fault Frequency: 7
                    Reset counter: 162
                    Mileage: 62486 km
                    Date: 2020.09.20
                    Time: 12:12:40
   VCID: 2D5082A474E678EE88-8078
   VCID: 4E92E528192063F6D1-801A
   VCID: 3A7AB9F8BDA8DF561D-806E
                    Reset counter: 156
   Coding: 0102204
   VCID: 377CA0CC46BAC23EE2-8062
                    Reset counter: 161
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:51
   Subsystem 1 - Part No: 8R0 060 884 GS
   Component: EUR 2020  3001
                    Reset counter: 103
                    Mileage: 61489 km
                    Date: 2020.08.21
                    Time: 15:25:34
                    Reset counter: 103
                    Mileage: 61489 km
                    Date: 2020.08.21
                    Time: 15:25:33
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
03677 - Missing Security/Release Code
                    Reset counter: 116
                    Mileage: 62348 km
                    Date: 2020.09.14
                    Time: 16:07:22
                    Voltage: 11.40 V
   VCID: 4682DD08F150ABB669-8012
   VCID: 3560AAC49CB6302EF0-8060
   Coding: 1030010
   VCID: 346697C057CC2926C7-8060
                    Fault Frequency: 10
                    Reset counter: 162
                    Mileage: 62488 km
                    Date: 2020.09.20
                    Time: 12:13:50
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect. (J605)       Labels: 4L0-910-945.clb
   VCID: 3D70B2E4A486E86E38-8068
   VCID: 79F866F4F82E144E54-802C
   VCID: 71E85ED4A05E5C0EEC-8024
End-------------------------(Elapsed Time: 05:04)--------------------------
Based on those fault codes, it looks like your 69-Trailer module is dropping off-line or taking an unauthorized lunch break at times?
RussJ
C?ID=288662
Would a fault with 69 also take out my ACC and throw up the "defective key" message?
Should I be looking at my CanBus connections or do I have a faulty module?
