I've installed a Westfalia towbar with the dedicated Audi wiring kit.
According to the official spec my car should have had Trailer Prep but I couldn't find the plug so I've followed the instructions for a non-prepped car.
This involves tapping into CanBus and power.
The supplied trailer module is showing a green solid LED which indicates that it is wired up correctly.
I've applied the following codes (which I found on the net):
* 01 - Engine [Coding - 07]->[Long Coding Helper]->Byte 5, Bit 4 Changed from 0 to 1 (via check box "Trailer Installed")
* 03 - ABS Brakes [Security Access - 16] (Enter code presented by program) [Coding - 07]->[Long Coding Helper]->Byte 1, Bit 7 Changed from 0 to 1 (via check box "Trailer Hitch Installed")
* 09 - Cent. Elect [Coding - 07]->[Long Coding Helper]->Byte 18, Bit 5 Changed from 0 to 1 (via check box "Trailer Hitch Installed")
* 10 - Park/Steer Assist [Coding - 07]->[Long Coding Helper]->Byte 0, Bits 0-3 Changed from 0000 to 0001 [Trailer Hitch Not Installed to Trailer Hitch Installed (Manually Removable) via pull-down list]
* 19 - CAN Gateway ->[Installation List]->Tick 69 - Trailer
* 5F - Information Elec [Coding - 07]->[Long Coding Helper]->Byte 10, Bit 5 Changed from 0 to 1
* 6C - Back-up Cam [Coding - 07]-> xx?0xxx: +1 = Trailer Hitch installed
* 69 - Trailer - No change required (unless wrongly coded before install)
These were the settings i needed to do on a Q5, i do not have any info a SQ5 is different, but if you just follow the checkboxes in VCDS nothing should go wrong (5F can also be changed in the hidden green menu instead of doing VCDS coding (check trailer hitch in Car > extdevicelist ), 6C is optional, if you don't have a backup cam you wont have this module.
However, when I scanned the car it came up with a sea of red!
The engine will start and run for a couple of seconds and then cuts out.
I disconnected the battery before doing the wiring .
I've attached a scan and would appreciate any advice.
Thanks
Russ
Thanks
Russ
Monday,25,May,2020,11:01:07:63302
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8R8FA079650 License Plate:
Mileage: 58010km-36045mi Repair Order: scan2
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
56 5C 5F 62 69 6C 6D 72 A9 C0
VIN: WAUZZZ8R8FA079650 Mileage: 58010km-36045miles
05-Acc/Start Auth. -- Status: Cannot be reached 1100
20-High Beam Assist. -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
5C-Lane Maintain. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: Malfunction 0010
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 HW: 4G0 907 589
Component: 3.0BTD EDC17 H25 0004
Revision: 57H25---
Coding: 2A2A4032257603020000
Shop #: WSC 06208 123 12345
ASAM Dataset: EV_ECM30BTD0118K5907589 001007
ROD: EV_ECM30BTD011_AU48.rod
VCID: 7EF275E8E100337679-802A
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Coolant temperature: 15 °C
Intake air temperature: 24 °C
Voltage terminal 30: 11.320 V
ACC target acceleration: 0.007 m/s²
ACC control module received status-Bits 0-7: 7
Active brake system error status-Bits 0-7: 48
Status of ACC/CCS acceleration interface-Bits 0-7: 3
Acceleration: 0.000 m/s²
Engine status: COENG_READY
4330 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 58016 km
Date: 2020.05.25
Time: 10:44:39
Coolant temperature: 16 °C
Intake air temperature: 25 °C
Voltage terminal 30: 10.320 V
ACC control module received status-Bits 0-7: 4
Active brake system error status-Bits 0-7: 1
Status of ACC/CCS acceleration interface-Bits 0-7: 0
U0428 00 [039] - -
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
CAN TimeOut meter - battery manager-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 244
CAN TimeOut meter - gateway-Bits 0-7: 0
CAN TimeOut meter - steering angle-Bits 0-7: 0
CAN TimeOut meter - parking brake-Bits 0-7: 0
CAN TimeOut meter - transmission-Bits 0-7: 0
4720 - Body Control Module (Central Electric 2)
U0141 00 [039] - No Communications
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:53
selected gear-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
P1570 00 [038] - -
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Immobilizer snapshot A-Sia Error Snap A: 39 00 1D
Immobilizer snapshot B-Sia Error Snap B: 0A 00 00
Part No SW: 8R0 927 158 AE HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1007
Revision: --H19---
VCID: 000E0B109BF445860B-8054
2543 - Transmission Control Unit
P1701 00 [167] - Locked
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Voltage terminal 30: 11.458 V
Immobilizer Snapshot 1-Param 0: 2F
Immobilizer Snapshot 1-Param 1: 00
Immobilizer Snapshot 1-Param 2: 1C
Immobilizer Snapshot 1-Param 3: 0A
Immobilizer Snapshot 1-Param 4: 00
Immobilizer Snapshot 1-Param 5: 00
Status data bus communication diagnostic interface-State Deashboard received: not received
Status data bus communication diagnostic interface-State ECM received: not received
Status data bus communication diagnostic interface-State ESP received: not received
Status data bus communication diagnostic interface-State Gateway received: not received
Status data bus communication diagnostic interface-State Parking Brake received: not received
Status data bus communication diagnostic interface-State Steering Angle received: not received
Status data bus communication diagnostic interface-State Steering Assist received: not received
12560 - Body Control Module (Central Electric 2)
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Voltage terminal 30: 11.460 V
Engine speed: 0 /min
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AP HW: 8R0 907 379 AP
Component: ESP8 quattro H09 0020
Coding: 24DDCC01
Shop #: WSC 06335 123 12345
VCID: 0E122528D9A023F689-805A
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:44:39
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x001A
Hex Value: 0x0282
Hex Value: 0x0000
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:44:44
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0022
Hex Value: 0x1B8A
Hex Value: 0x0000
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:44:46
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0045
Hex Value: 0x138B
Hex Value: 0x0000
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:44:46
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x002F
Hex Value: 0x238B
Hex Value: 0x0000
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:44:46
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x002F
Hex Value: 0x238B
Hex Value: 0x0000
Address 05: Acc/Start Auth.
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01211120141279
Coding: 3625028000
Shop #: WSC 06335 000 00000
VCID: 78FE63F0CB240D4633-802C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000951648401
Coding: 260000108074AFE00581404300001D0D0F9D670827090201000008004400030100000034000000
Shop #: WSC 50664 002 104857
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140825 H12 0050
Serial number: 90243015140820021300
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 23488562
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001511146557
Serial number: 37488D57000000000001
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:45:32
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0100
Coding: 007D8A
VCID: 377CA0CC86BAC23EFA-8062
00456 - Control Module for Access and Start Control (J518)
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:53
Temperature: 31.0°C
Voltage: 11.39 V
Hex Value: 0x008A
Lateral Accel.: 0.00 m/s^2
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Temperature: 31.0°C
Voltage: 11.39 V
Hex Value: 0x00C9
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
Temperature: 31.0°C
Voltage: 11.39 V
Hex Value: 0x005D
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
Temperature: 31.0°C
Voltage: 11.39 V
Hex Value: 0x00BE
01316 - ABS Control Module
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
Temperature: 31.0°C
Voltage: 11.39 V
Hex Value: 0x00C0
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H48 0610
Serial number: 003JPDC21U3M
Coding: 30473431313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 489ED330F344BDC683-801C
Serial number: 6334MSME4A6B2B05M
Serial number: 6344MSME4A596417K
Serial number: 6352QSME5C484164L
Serial number: 6362QSME5C4B216CV
Serial number: 63732SME3449245C%
Serial number: 63832SME714B487A9
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372NKI000FS
Coding: 0000FF
VCID: 4486C700C76C99A66F-8010
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
Fault Status: 01100101
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
(no units): 62.0
Text: 3E820000FFFFFFFFFF
Current: 0.000 A
Raw, Index/Key Err.: 255 255 255
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 951 HW: 8R0 920 951
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 03I32JJCF
Coding: 33E7220047012600010000
VCID: 74E657C0D74C69261F-8020
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Revision: 1Z120030 Serial number: 3041Z14B190417
Coding: 80CD07FF00
VCID: 4C96EF20EF3C51E6A7-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 4899974903
Serial number: 14311000484011200410
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:54
Bin. Bits: 10001
Voltage: 11.40 V
Count: 6
Bin. Bits: 00000
Time: 25.40 s
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:54
Bin. Bits: 10001
Voltage: 11.40 V
Count: 6
Bin. Bits: 00000
Time: 25.40 s
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02022064747464545425363E00
VCID: 7CF67FE0FF1C216657-8028
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.23
Time: 16:33:55
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000124832453
Coding: 01781B00000000000000
VCID: 428AC118DD7897965D-8016
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0334371538
Coding: 010312
Shop #: WSC 06334 123 12345
VCID: 3F8CC8ECA68AFA7E32-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0334316078
Coding: 010312
340484 - Databus
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0009187955
Coding: 100001010001
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
4205828 - Steering angle sensor
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Write only channel
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Write only channel
3161616 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Write only channel
Address 46: Central Conv.
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813037454706
VCID: 2D5082A474E678EE90-8078
Address 52: Door Elect, Pass.
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000545768
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7AB9F8BDA8DF5605-806E
333824 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Voltage terminal 30: 11.5 V
Internal Fault ID: 50
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
330240 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Internal Fault ID: 96
RWU: not active
DSD: not active
HTR: not active
ECD: not active
330496 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Internal Fault ID: 97
RWU: not active
DSD: not active
HTR: not active
ECD: not active
335360 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Internal Fault ID: 209
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109K60E7992209
Coding: 010103010000000001
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:42:10
Bin. Bits: 00000000 00000001
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 600214B2000165
Coding: 0002204
VCID: 377CA0CC46BAC23EFA-8062
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Fault Status: 00101101
Reset counter: 75
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Part No SW: 8R2 035 666 L HW: 8R2 035 666 H
Component: H-BN-EU H48 1036
Revision: -------- Serial number: 515K10E7503269
Coding: 1A0101060205A9EF7D80CB5E00000403E40000020000000000
Shop #: WSC 50664 002 1048576
Subsystem 1 - Part No: 8R0 060 884 GA
Component: EUR 2019 2802
Component: DU7 High H42 0104
Serial number: A130KZ0E3196812
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002055351
Component: CD-Database 5950
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:56
Text: DUA130,Front,M,0,0,6
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:58
Bin. Bits: 00100000 00000000
Bin. Bits: 00000000 00000000
03623 - Invalid Security/Release Code
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:55
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 62: Door, Rear Left
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: ConWys Trailer H09 0100
Revision: 1G001001 Serial number: 00000173782896
Coding: 0100000000000000
Shop #: WSC 00375 223 87350
VCID: 3560AAC49CB6302EE8-8060
Address 6C: Back-up Cam.
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D70B2E4A486E86E20-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:51
Address 72: Door, Rear Right
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 141021202723
VCID: 79F866F4F82E144E4C-802C
0005 - Incorrect Vehicle Type
U10D9 00 [009] - -
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0002
Serial number: 141021200750
VCID: 71E85ED4A05E5C0EF4-8024
U10D9 00 [009] - -
Reset counter: 35
Mileage: 58016 km
Date: 2020.05.25
Time: 10:41:52
End-------------------------(Elapsed Time: 04:28)--------------------------
